FB 308 INSTALLATION INFO
kelleigh54
Post by kelleigh54 »
Anyone out there able to help out with some info re:308 into FB? Picked up a good tidy unit that should keep me cruising till they take my liscence away due to old age. Any pointers appreciated. Live in Perth. utesncoupes@aol.com
G`day kelleigh54 , welcome to the forum - good to see another sandgroper on here :D There are quite a few V8 and V6 powered early Holdens on the road over here, where are you located exactly ?
kelleigh54
Gday Blacky, Im out in Huntingdale. Have an HR ute, about 13/14 years now. Was light blue, tidy up and resprayed LoneOranger about 3 years ago. Will be for sale when the FB is up and running.
Would like to speak to someone who has been through the paces installing a 308. Im an ol fart and not too good with these computers and key boards, so a phone number would be really good.
thanks bloke
Kelleigh54
(AUST)Mod
Post by (AUST)Mod »
kelleigh54 i will be closely following your progress, as a mod like this to my fb is a dream for me :)
CHOPPED
Post by CHOPPED »
hey there kelleigh 54 as blacky said welcome closest thing i can help you with is some very good friends of mine (workshop down the road from mine) instaling a 308 in a eh van will look like it came out that way when its finished ie no chrome with simple block hugger headers
happy to meet you there if you want cause if they dont know you you wont get a look inside the shop very particular with customers cars failing that your welcome to have a look at my ute even though youve probably sen many chev transplants :)
HEY IT WASNT ME
kelleigh54
Dont lose the passion (Aust )Mod, have had another project on the go for 18 years now and still a long way off yet.
Thanks CHOPPED,will take you up on the offer. You can email me at utesncoupes@aol.com
Thanks again
Kelleigh54
EK 308 Uterus
Post by EK 308 Uterus »
kELLEIGH,
Greetings from sunny Albany, I have done 308 into a EK ( same dog different leg
What would you like to know? probably first question will it fit ,,you bet it will, thou the exhaust has to exit the inner guards( looks really good ). The Firewall on the left has to be recessed an inch and a bit otherwise the left hand head will fowl. This is a really simple job and if I can do it anyone can.
I basically have a ek ute with HZ statesman running gear which consists of the 308, turbo 400 and a shorted LSD large sals rear end. The brakes are disc all round.
I hope this helps , any other questions dont hesitate to ask.
Luke ( EK 308 Uterus )
kelleigh54
Thanks Luke,
Any tricky bits, engineering issues for rego, m/cyl booster set up, trans tunnel used, steering set up and column.
