water pump drive pully spacer kit
Posted: Sun Nov 10, 2013 9:03 pm
by Marko
Hi Guys,
any direction on where to get the above mention kit to suit a red 308 in Perth, my gilmer drive pully is just hitting the w/pump housing.
they are available on line but postage almost doubles the price,
Cheers Mark
Re: water pump drive pully spacer kit
Posted: Sun Nov 10, 2013 9:19 pm
Can you not machine a couple of mm off the back of the water pump pulley ?
I am not a fan of the gimlet type setups, they have a nasty habit of leaving you stuck on the side of the road with a shredded belt, you should always carry a spare when you run one of them.
Posted: Sun Nov 10, 2013 11:23 pm
by Marko
Cheers Blacky,
I have wondered about the life expectancy of the belts and gears, but they look cool - there is a very good chance I will come to my senses and revert back to a stock belt and fan.
I need to pack out the pulley away from the water pump - replaced the water pump on rebuild - must be a little different from the old one
If any one has a fan, standard pulley, etc to help me revert back please let me know, my engine came with the Gilmer Drive and I didn't get the original parts.
Thanks guys, Mark
0428271188
Posted: Mon Nov 11, 2013 6:07 am
Where does the belt sit on the pulley, can't you take a couple of mm off the back of it so it clears the pump ?
