Straightening rear leaf spring mount
Posted: Thu Aug 08, 2013 2:57 pm
Now that the rear diff assembly is all out, The drivers side rear leaF spring mount has been bent somehow. (The very rear mount) Its bent out about 20 degrees towards to side of the car. no obvious marks to how it got bent, but I reckon it happened the same time something pushed the petrol tank inwards from the bottom of the car.
Anyway, my brother is bringing the gear on Saturday we are going to heat it up, straighten it and then cool it down. Now I have seen fitters in the workshop just use a wet rag/shirt to put over the steel once heated and moved to correct position to cool it quickly. My brother has mentioned he has been told to use oil and spray that onto the heated area. He cant remember but he said the oil doesn't effect the steel??
Any advice why to go oil? and should it be a particular type of oil? I am still keen to just use the wet rag, seems easier.
