slave cylinders/wheel cylinders
anybody recently bought or had there wheel cylinders recoed/resleeved etc i've seen the new ones on ebay at $290 a set but i think that's a rip off considering the same thing for say an EH is less than $100
haven't pulled mine apart yet may just need a clean and new rubbers but seeing what my options are
thanks
Re: slave cylinders/wheel cylinders
Probably not much help to you Mick as I only had to buy rears just before the Nats and they were HR, cost $44 for the pair.
thanks, yeah that's what's p!ssing me off a pair of EH/HR type $30 -$40 pair yet FB/EK type which are basically the same thing just a bit different in design are $150 odd a pair :?
so just trying to find the cost options of if i need to have mine resleeved or buying recoed ones, i know there are people on here that have recently bought recoed or had there's recoed
Craig Allardyce
Post by Craig Allardyce »
Mick wrote:thanks, yeah that's what's p!ssing me off a pair of EH/HR type $30 -$40 pair yet FB/EK type which are basically the same thing just a bit different in design are $150 odd a pair :?
Mick, I wouldn't bother buying new wheel cylinders. Just get your old ones sleeved.
Cost to do mine were:
$49.50 ea for 1" cylinders
$55.00 ea for 1 3/16" cylinders
New cups $13.20 all up
Cost to remove old sleeve if fitted $22.00 each
All up still cheaper than new cast cylinders that will corrode out. I also went a bit further and had bronze pistons made up which cost me a fair bit more and I'll be running Silicon brake fluid.
Last edited by Craig Allardyce on Mon Jul 08, 2013 8:25 am, edited 1 time in total.
thanks that's what i was after, i'll pull mine apart in the next couple of days maybe they'll just need new rubber cups that's usually worked on more than a few that i've done before
