brake lines
ekstevo
brake lines
Post by ekstevo »
ImageI'm in a bit of a rush I,ve got the brake fitter here and we're trying to work out where to put the brake lines anyone able to show me a few pics of how its done. It's going to have 4 wheel disks from a firewall mounted booster and master cylinder.
Thanks for your help.
Re: brake lines
Are your calipers rear or front mounted ???? Bit hard to tell in your avatar, if rear mount the hard lines should run the same as stock ???
ekstevo
Re: brake lines
Post by ekstevo »
rear mounted but can't remember where the original went and would like to show the brake fitter a pic or 2 he normally works on trucks his hobby is old fords.
Re: brake lines
The best pic I could find at short notice ---- there is block mounted behind the steering box which is fed by the master, then theres one to each front and one to the diff.
ekstevo
Re: brake lines
Post by ekstevo »
Cheers blacky my mate the brake fitter looked at it for a while then decided he didn't bring the right pipe bender then drank all my beer.
Hes coming back next week to have another go anyone got any pics how you've run your brake lines please post them up so i can show ole mate of what other blokes have done.
Re: brake lines
I didn't worry about how the stock lines went when I did mine, as long as it's neat and works :thumbsup: .
