Gearbox crossmember for tri-matic?
I'm just wondering if there is a crossmember I can use to bolt the trimatic in my Ek. Or is it the sort of thing I will need to make?
Re: Gearbox crossmember for tri-matic?
Bump, has anyone got any insight on this?
you will need to fab one
Behind a Red or Grey?
Red motor, make one.
Grey motor you don't need one, the rear engine mounts support the box.
Yeah its behind a red. I haven't found anything on the net, so im guessing fabing one is the only option.
I've answered a similar question before, thought I'd answered this one but obviously didn't.
If you do a search on here you should find a pic of what I did. May even be in my build thread. As others have said you will need to make one.
