Hi all I have grabbed a drum brake HR front for my EK sedan.
To upgrade to disc can I use a complete assembly from a HQ, knowing that the stud pattern will change and I will need 14" wheels, if the complete HQ assembly can be used does any thing else need to be modded or purchased (other than master cyl & booster) and what will it do to the wheel offset??
Is there a better option???
Thanks in Advance
Matt, aka Coopa
HR Drum Front End to Disc
Re: HR Drum Front End to Disc
I recon the upgrade to Hktg disc brakes are great and you keep the early stud pattern, Trev.
Thanks Trev
Go the complete HKtG setup (stubs, discs, calipers, hub, backing plate) ?
Yes the complete setup, not that hard to come by either.
- State: NSW
Do HKTG rotors and calipers fit HR disc stubs ?
______________
living the dream.
living the dream.
99% sure they do fit.
Thanks Trev
