Red 308 Alternator bracket
Posted: Tue Oct 16, 2012 1:06 am
by Marko
Hi guys, just wondering if anyone has a v8 alternator bracket lying around that they don't need. All I need is the adjusting arm. Cheers Mark.
0428271188
Re: Red 308 Alternator bracket
Posted: Thu Oct 18, 2012 1:05 pm
by Doc Bob
Is the alternator passenger side top mount, or driver side low mount?
Probably have both types here and can post up to you.
Posted: Thu Oct 18, 2012 3:40 pm
by DOLLER
Hey doc do you know if the 308 alt mounts can be fitted onto the 304 inj engine?? Im not running power steering or air con and thought if I could mount the alt up high on the drivers side it will save cutting the inner gaurd on the pass side. Any thoughts????????????
Posted: Thu Oct 18, 2012 8:35 pm
by Marko
cheers Bob, much appreciated but I have since sourced one. ended up with brand spanken new one, but cost $20.
thanks any way.
the van goes to the auto Lecy early next week, exhaust end of week and upholstery after that.
Then the big road test.
It's getting close,
Posted: Fri Oct 19, 2012 11:36 pm
by Doc Bob
Great to see all is working out well Marko!
DOLLER wrote:Hey doc do you know if the 308 alt mounts can be fitted onto the 304 inj engine?? Im not running power steering or air con and thought if I could mount the alt up high on the drivers side it will save cutting the inner gaurd on the pass side. Any thoughts????????????
They all came out stock as passenger side high/low mount, was only the V8 Torana's that ran the drivers side low mount.
304/308 etc are all the same gear, only the VN headed stuff changed a bit, but still pretty much the same
You can fit a long bolt through to the front of the head and run a drivers side high mount, but would have to be custom made
Not hard or expensive, just need a mate with a couple of tools and an eye for detail
Let us know if you really need something made and I can suss it out.
All the best......Bob.
Posted: Mon Oct 22, 2012 7:22 am
by DOLLER
Thanks for that Bob.
Ill get a heap of different pics from the net and have a crack at fabbing one up myself. Surely others have done this mod
Posted: Tue Oct 23, 2012 12:36 am
by Doc Bob
DOLLER wrote:Thanks for that Bob.
No worries....best to do it yaself, then you know it'll fit
Posted: Wed Jan 02, 2013 1:46 pm
by DOLLER
Just found that the VL-VK runs a driverside high mount alt bracket
