long winded question ............
just picked up my new grey short motor from Blueys in Bunyip.. top man ..knows his stuff on greys .......its been hot tanked , bored to 3 and 3/16 , blue printed ,balanced , grind 82 Clive cam , refaced lifters , block is zero decked ,aluminium timing gear fitted and oil pump reco,ed ...Got a head from Bumper at a fairly good price ....Thanks Bumper .the head has been shaved , red motor valves fitted , the exhaust ports have been fitted with hardened valve seats ...and a very aggressive port and polish job ....the question is ...
twin strommys or triple strommys got both ....got some 48 and 46 jets and 1 restrictors in my spares box .....anyone help with some retrictors ...........will probably use one of them electronic coversions in my dizzy ......Fingers
Re: long winded question ............
Triples, and progressive linkage. All the grunt down low, and all the spare venturi up top.
American Autos can do you the Holley 7448 restrictors, though they need some bending and trimming to fit. One of the earlier forum posts mentions a carb service mob (Extreme Fuel Systems? man, my memory is shot) that had a box of assorted restrictors on hand.
Harv.
Harv.
I would not recommend that mob Harv...after my joyful experience anyway..
Sent from Galaxy S3
Sent from Galaxy S3
<><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><>Harv wrote:Triples, and progressive linkage. All the grunt down low, and all the spare venturi up top.Harv.
Hey mate ...........please explain ..
Found the link, it was Xtreme Fuel systems in Cambelltown who had the box of restrictors:
http://www.fbekholden.com/forum/viewtop ... restrictor
Gotta agree Ash, whoever did your carbs did not appear to do an appropriate job (in my humble opinion). Blocked accelerator pump circuits and loose float bowl vents are not acceptable on fully reco'd carbs.
Fingers,
Most Strommie linkages are set up so that both (or all three) carbs run equally (i.e. the connection is the same for all carbs). In a progressive setup, as you start to push down on the go pedal, only one carb starts to work. You get good snappy acceleration, and can cruise around town on one carb, which is good for fuel efficiency (not that triples can't be tuned lean... its just harder). As you keep pushing the go pedal more, the other carbs start to open up. You now have extra carb capacity (ie not starving due to lack of CFM). It's similar in principle to vacuum secondaries on a 4-barrel - two barrels run in cruise mode, 4 barrels run when your boot is buried. Progressive linkage is a bit harder to build and a lot harder to tune, but is beautiful once running. See page 86/87 of the guide for a bit more info, and page 96 for photos of some cool triples with progressive linkage (can't remember whose carbs... but very, very cool
Harv.
Fingers,
Harv.
choppedfan
Triples, they are worth the effort and once set up they are easy to keep tuned.
Mine aren't on a proggresive linkage and they work well, venturi restrictors/sleeves are essential
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>choppedfan wrote:Triples, they are worth the effort and once set up they are easy to keep tuned.![]()
Mine aren't on a proggresive linkage and they work well, venturi restrictors/sleeves are essential![]()
Are there different size restrictors mate ......the only ones I know are the ones that were made for taxis going way back when cocky was an egg .......sort of tin plate maybe 1.5 mmm thick ...I had a couple but have lost one of them ....Fingers
choppedfan
Re:
Oh yeah, plus they look coolDevilrod wrote:That's the spirit, one in all in!choppedfan wrote:
- phpcuA8hvAM[1].jpg (44.37 KiB) Viewed 890 times
choppedfan
I went with the Holley ones filed and reshaped to suitfingers wrote:<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>choppedfan wrote:Triples, they are worth the effort and once set up they are easy to keep tuned.![]()
Re: Re:
quote]Oh yeah, plus they look cool
[/quote]
Oh Yeah mate ..............they do look cool ....
..Fingers
