engine mount position for red motor
premeh
Post by premeh »
hi , can anyone tell me the position (on HR crossmember) , for relocated engine mounts to be rewelded in place for EK with a Trimatic auto fitted with red motor. .. also pics would help me a lot . thanks, Art.
Re: engine mount position for red motor
Art , it tends to vary a bit , theres no hard and fast rules about where they go , the best bet is to cut the mounts off the xmember , fit them to your engine mounts , stick the motor and box (and radiator , carbs also if you are running triples or something which may cause clearance issues ) in the car and position it where it fits best , tack the mounts in then remove motor and box and fully weld the mounts.
Blacky wrote:Art , it tends to vary a bit , theres no hard and fast rules about where they go , the best bet is to cut the mounts off the xmember , fit them to your engine mounts , stick the motor and box (and radiator , carbs also if you are running triples or something which may cause clearance issues ) in the car and position it where it fits best , tack the mounts in then remove motor and box and fully weld the mounts.
What Blacky said, I found is the only way to get it right. I did similar with an FC years ago. But you can drop the front end back out and leave the motor and box in the car if you've got it sitting securely.
artyfartymarty
Post by artyfartymarty »
U still after the pics Permeh?
I have red with trimatic on HR front an can take pics and measurements for you if needed :D
FB EK Club WA
Don't follow me, I'm lost too
