Ute Rear end rattle
Beauii60
Ute Rear end rattle
Post by Beauii60 »
Hi All,
My EK Ute has a low speed rattle from the rear end that has got me beat.
It happens all the time at low speed independent of the road surface.
At first I thought it was the tailgate links but wrapping them in foam quickly eliminated them.
It's not rear wheel bearings (new), UJs (new), exhaust system (lots of clearance and securely mounted), fuel/brake pipes (new and securely mounted), spare wheel well contents (still there when empty), shocker mounts (new), spare wheel well door (no slop in lock or hinges), tray floor boards (good nick and the screws are nice and tight).
I've jumped in the back and had a mate drive but couldn't hear a thing.
I recently drove an FB Ute and it had exactly the same noise.
There's not much in the back of these things so there's little left to rattle.
Any advice/comments appreciated.
Tony
WayneXG95
Re: Ute Rear end rattle
Post by WayneXG95 »
Have ya checked the ashtray for earrings? :shock:
Sorry just saw the superchief ad on TV... :mrgreen:
Got me stuffed too :evil:
Gravel in the rear hubcaps?
... not that I ever did that to anyone as a kid :ebiggrin: .
roto
Post by roto »
G'day Tony,
It could be the rear shockys rattling internally.
Hope this helps,
roto
Beauii60
Post by Beauii60 »
Hey guys,
Thanks for the gags and advice.
I had a bad rattle in the front that, although I knew the radio blanking plate to be loose, didn't make the rattle connection.
I think the last thing to try is to run it without the rear shocks.
I have removed them and fully re-bled them and they seemed ok on the bench.
I'll let you know.
RobinGi
Post by RobinGi »
put the rear end up on axel stands and see if you can locate that way
whats your feeling? running gear noise or body rattle ?
choppedfan
Post by choppedfan »
Turn the radio up :thumbsup: :thumbsup: :thumbsup:
Seriously though theres nothing worse than not knowing what it is :evil:
Funny thing is once you know its this or that rattling you tend not to be as worried about it :wink:
Mick 8)
GusnElla
Post by GusnElla »
Can you describe the rattle? is it going around corners? what speed? engine revs? what gear? up hill? down hill? without or with a load? is it a dull rattle or a vibration? something in the inner rear tub area? that cap on the fuel tank sender? the fuel tank?rubber seal around fuel filler in good nick? light tight lenses tight? number plate bent? does it have a towbar? Those ideas will keep you busy for a while!
Cheers Gus
GusnElla
Post by GusnElla »
I cant help myself, a Loose baffle in the muffler, worn spring mount bushes, broken centre spring bolt, oh and of course check the nut behind the wheel... thats the tricky one!
Doc Bob
Post by Doc Bob »
GusnElla wrote:a Loose baffle in the muffler,
:evil: My Wagon has one of these and by christ it's the most annoying thing :evil:
The only thing I can think that has not been checked is the dust cover on the front bearing of the diff, just behind the yoke.
These do have a habit of coming loose from time to time and make a fair old racket for something so small and tinny :shock:
Keep us informed if ya solve the mystery :thumbsup:
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
igor
Post by igor »
Keep us informed if ya solve the mystery :thumbsup:[/quote]
X2
We have had our ute for over 25 years and haven't solved our utes annoying rattle :roll:
Roger and Lesley
GusnElla
Post by GusnElla »
I forgot about that 1 Bob!!!
mr hydramatic
Post by mr hydramatic »
this is a true story
around 2 years ago my mate bought a hx ute , v8 blah blah nice original thang ,it drove tight .... but it had this bloody noise in the left hand side , it sound like a rattle sqweek ,we changed the chassis bushes , checked gearbox mounts as the noise came from centre of the cab , for nearly 6months we would regularly check the ute over ,nothing ..so one day my mate was trying to tighten the passenger door striker bolt on the pillar ,he rounded the allen key head on it and decide to take it off , the plate holdin it dropped way low so he took the plastic air vent off and in there was a small " heinz spagetti tin, the tiny ones ) ..it had $2500 grand in it!! :ebiggrin: ! the noise/rattle gone ...my mate still hasthis ute and is doin a ground up rebuild on it
all very 100% true :)
ya dont know performance till ya have driven a grey motor with a hydramatic....[/i]
GusnElla
Post by GusnElla »
Hey Tony, Have you had a look @ the rattle in the Ute yet? the suspense is killing me!
