- Are all red motor standard pushrods the same size ?
Are all red motor standard oil pumps the same ?
I think the old glass top fuel pump preasure is around 7psi, will this be enough to run a 465 four pot Holley ?
few questions about red donks
- MyEKisdriven
- State: WA
I think my memory's fading, I've got a few questions about red donks
0424 364 840
0424 364 840
choppedfan
Re: few questions about red donks
Be careful with the choice of carburettor, this is an area where "bigger is not always better" and I do realise that like any engine modification the carby choice is normally governed by cam size, head mods etc.MyEKisdriven wrote:I think my memory's fading, I've got a few questions about red donks
G'day MyEKisdriven,
Chopped's advise is good - the 465 Holley is good enough to feed a 202 screaming at 10,000rpm (@80%VE). Not a bad choice for cars that run at WOT all the time, but can be a pig down low (venturi restrictors will help a little).
The glass top fuel pump is good for 9gph @ 4.5psi. This will feed a Holley (Holley inlet valves are OK for 3-7psi), but will start to starve the motor when you get to around 115HP (assuming 0.5lb/h/hp fuel loading).
This may help:
http://www.fbekholden.com/forum/viewtop ... 25&t=15098
Harv.
This may help:
Harv.
basic.green
hi push rods are different 186 you need 186 and so on
i have a 465 on my car
192 10:5 comp yt head ported 616 crow cam (xu1) and so on
it needed to have the power vale changed to block off and bigger jets i had no vac in manifold (4)
i all so had it on a 173 (tired) extractors and 35604 crow cam and it went ok had a 3.5 power valve vac was (8)
i have a glass fuel pump and so far all good
oil pumps are same i think
building the dream Rick
- WesternWagon
- State: WA
G Day Graham
Im no expert on any of this just a few pick ups from my build.
A Small block fuel pump will bolt strait on and give you more fuel,if you need it, like basic. green's, there are some tough reds with glass pumps on them. (performed & won at Bathurst)
Some good push rod info on the Comp Cams web site, they also sell checking push rods. There are a lot of variables -----block deck,head deck,cam, rockers ect
I have some 202 & 186 std rods here ya can use to check with.
Great article Harv
Gazza
Great article Harv
Gazza
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
- MyEKisdriven
- State: WA
thanks for re-gigging my memory guys
I've come across a 186 block +60thou, it's got a ground crank (,10thou) and a nice set of lightweight flat top alloy pistons... all with new rings and bearings.
The engine build was started a few yrs ago by an old fella but he never completed it so it's all still new.. and no rusty bits ! I got it part assembled for $400.00. I'll be pulling it down and checking everything before going further with the build.
I've go an old YellaTerra clone (superflow) head that I've had for about 30yrs, it;s at the local engine reconditioners (Galloways) getting cleaned up and ready for ULP with new valves, springs, seating collars etc.. (,$770.00). I've ordered a Crow cam (,667 "I think" $277.00)and a 465 Holley, manifold, air filter and linkages (, $798.00) from Hume Performance.
The block is missing a few bits n' bobs which is why I was asking about what fits with what.
Thanks again for the info fella's
Graeme.
Graeme.
0424 364 840
0424 364 840
basic.green
hi graeme is it auto or manual
you will need a converter if auto of about 2000 2500
i have a gemini in mine and i think i will need a bigger one
- MyEKisdriven
- State: WA
The ute's a 5 speed manual
I checked the cam and it's a crow 35667, I've ordered one through the guys doing the machine work on the head for $229.00
cheers,
cheers,
0424 364 840
0424 364 840
basic.green
thats a good price got to be happy with that
