Page 1 of 2
Need ID of some parts
Posted: Tue Feb 14, 2012 12:18 pm
by WayneXG95
I need to identify some parts I have collected
Any Ideas Guys and maybe value?
I'll put them up one at a time so they can be quoted.
Cheers :thumbsup:
Re: Need ID of some parts
by WayneXG95
Ist up 4 hubcaps, one a moon by the looks of it?
Posted: Tue Feb 14, 2012 12:19 pm
by WayneXG95
2nd up swaybar
by WayneXG95
3rd up oil pump, I figure the Ryco number might help.
by WayneXG95
4th up 4 wire type hubcaps, no id name or numbers?
by WayneXG95
5th up twin mufflers with mounting bracket?
Look in good nick and large pipe system
Posted: Tue Feb 14, 2012 12:29 pm
by WayneXG95
6th up unknown bracket
by WayneXG95
7th up more unknown brackets
Posted: Tue Feb 14, 2012 12:30 pm
by WayneXG95
8th up some choice chrome bits.
by WayneXG95
9th up another bracket
by WayneXG95
10th up radiator from a ek manual?
Posted: Tue Feb 14, 2012 12:31 pm
by WayneXG95
11th up radiator from a EK Hydamatic?
by WayneXG95
12th up unknown Holden radiator?
Has number.
by WayneXG95
13th up Subframe supports, would they fit a FB?
Last one Cheers :thumbsup:
Posted: Tue Feb 14, 2012 3:37 pm
by Mick
1. correct 4 hubcaps :thumbsup: other 3 EK worth nothing up to what the idiots pay $50each
2.rear sway bar probly any early holden, usually good money on ebay
3. red motor oil pump once again worth nothing, except if there is a large cross on the other side then maybe $50 up
4. no idea
5. sports mufflers look like 2" but hard to tell maybe $50 - $100 i'll give you $20 if they're straight through 2" and yor goin to clarendon
6.top bar here bonnet locks down on FB/EK goes from side to side between guards maybe 0- $20
7.gearbox cross members to suit hadfield chassis kit
8. push in oil cap for aftermarket chrome rocker cover, water neck from holden V8 other bits no idea worth a couple of bucks
9.fabricated gearbox crossmember at a guess out of EJ/EH possably could be used in auto body EK once again a few bucks
10. might be the rare EK mnaual heavy duty radiator as it looks like an auto one but seems to have dfferent part No and only 1 outlet
11. i think is EK auto
12. EH auto
all radiators 0 - maybe $50
13. part of a hadfield chassis kit goes on subframe where front end bolts up, worth probly nothing
