Clutch slave cylinder
John
Post by John »
Hey guys, I need a picture of the clutch slave cylinder return spring on a crash low box. Not sure if the one I'm using is the correct one. Hard to say when it was all just thrown in the boot when I bought her :(
ingredient in beer
Mai Ki-Ki
Re: Clutch slave cylinder
Post by Mai Ki-Ki »
Cable clutch set-up...?
Mines an EK and hydraulic.....did FB's have cable..?
M
The Kardinals, Melbourne.
resto
Post by resto »
I looked through a heap of manuals and I can't find a picture of it. It is quite unmistakeable though.
It is about 75 mm long overall with a short section of spring (about 30mm). One end is like a normal spring end, whilst the other has a long extension with a kink in it. The spring only goes on one way as the kink goes around the rubber seal on the slave cylinder.
Resto
