When in trouble ring Luis!
I learnt something new today...
1. Remove seal assembly from hub and press onto back of spindle.
2. Remove inner wheel bearing from hub and press onto spindle. You will need to get some hollow steel tube and gently tap the bearing into place.
3. The new cups stay in the hub.
4. Place rest of hub onto spindle and seat it onto inner bearing.
5. Insert outer wheel bearing. May need to gently tap this onto spindle too.
6. Don't forget the hex slotted washer.
7. Screw the nut on.
8. Dont forget the split pin.
10 minutes tops.
