EJ Auto colunm in my FB.....wiring questions
element5au
Post by element5au »
Hello fellow Holden guys and gals.
I needs some info. I have an FB Holden which has an EJ auto colunm, running a 173 with Traumatic. I have used the Holden wiring diagrams....but they do not have details on auto wiring in either FB, EK or EJ.
I have connected the (yellow) flasher can wire and the 2 (blue) indicator wires....work great. I have these last wires to figure out.
Upper loom
Tan ... Horn?
Grey ... illumination?
Purple
Pink
White
Lower loom
Red and white plug....reverse?
and 2 other plugs....starter?
and do i need to switch these around to match the Trimatic? I need to make it so the car only starts in Park. So i can take the car over the pits.
Hope someone can help.
Mark
Lucy Blue
EJ Diagram
Post by Lucy Blue »
ok according to my book
Upper loom
Tan should be grey... Horn?
Grey should be white?... illumination Auto trans quadrant light
Purple reversing lights {option on FB}
Pink reversing lights {option on FB}
White Neutral safety back up switch
Lower loom
Red and white plug....door switch and dome lamp
PS No responsibilty for the true nature of the information as your car could be diferent.
