HQ stubs
Posted: Sun Aug 21, 2011 6:00 pm
by wolf3881
Hi every one
I am looking at using lowered springs with HQ stubs.
Can I still use HR disks or do I have to go HQ?
Thanks
Re: HQ stubs
Posted: Fri Sep 02, 2011 8:34 pm
by neatride
I personally dont know but have you tried ringing Hoppers Stoppers brakes in Hoppers Crossing VIC. I'm sure they could give you an educated answer,cheers.
Re: HQ stubs
Posted: Wed Sep 14, 2011 9:25 pm
by wolf3881
Thanks,
I,ll give them a call
Re: HQ stubs
Posted: Fri Sep 16, 2011 1:02 am
by ek61
use ht hg rotors
Re: HQ stubs
Posted: Wed Oct 05, 2011 12:24 pm
by ekstevo
the whole idea of using hq stub axles is so you can use Hq ventilated disks.
As I'm retaining the original steering box I wasn't able to rear mount the calipers so I got some stubs from crs, if your going for a front mounted racknpinion you may be right .
Rear mount the calipers use Hz alloy calipers , the hq girlock calipers wont fit. (too bulky hit member at full lock)
I'm using the original steering box with crs stubs hk steering arms hz alloy caliper the original ek drag link. Hoping that the ginger-beer doesn't make me go a collapsible column so it may change down the track. I intend on running hq wheels with 60 series tyers on them ,(you need at least 14 inch wheels for the caliper to clear).
