G'day Luke,
I've also been doing a bit of chasing for some HQ rotors in early Holden stud pattern so I'll share with you my multiple hours of internet research and phone calls if you like.
As far as I can find, DBA ( Disc Brakes Australia ) are the only manufacturer of undrilled HQ rotors however you can't buy them direct from DBA, you have to buy from their agents.
Repco,Supcheap,Bursons, Hoppers Stoppers etc.
DBA014U is the part number for their standard undrilled HQ rotors. The "U" differentuates from the normal HQ stud pattern rotor which is DBA014.
DBA don't have any in DBA014U stock at present ( up the 2 weeks ago anyway ).
They do make a more expensive racing type slotted rotor in their series blah,blah,blah but I wasn't really interested in a racing type rotor at a racing type price so never went any further than that.
Good news is that it seems that most of their agents still have stock of standard undrilled HQ rotors.
After many hours of ringing around I found the best place with the best price was Hoppers Stoppers down in Hoppers Stopping in Melbourne.
Ring them and ask for "Duncan". Phone number is 03 9748 6950.
They can supply undrilled HQ rotors for $180 each and machine the rotors to Torana/early holden pattern ready for an extra $60.
This was the best price I could find for new undrilled HQ rotors and $60 each to machine the stud pattern is pretty damn cheap as well considering that part of the process also invloves machineing the O.D of the snout of the outer bearing from 71.5 mm down to 63.5 mm to allow the early holden rims to fit over the bearing snout.
I think you still have to make a slight modification to the upper?? wishbone if your are using standard HK to WB stub axles to stop the HQ caliper from touching this wishbone on full lock, however in my case, I am using CRS lowered stubs that have the mounting point for the HQ caliper in a different position to avoid this.
So for $240 each you have new HQ rotors in early holden pattern ready to bolt to your stubs.Sounds like a lot of $$$ but is the only way I've found to do it at the cheapest price by blokes that specialise in brake upgrades.
The alternative is to fit blank Leyland P76 rotors and also after multiple hours of ringing around it appears that Hoppers are also the best and cheapest at this one as well.
Hoppers now produce an undrilled P76 rotor that doesn't require an adaptor kit to adapt the P76 bearings to the holden stub.
The adaptor kit that was used previously cost around the $180 to $220 mark so you save there by not needing it anymore with their now ready-to-bolt-up P76 rotors.
The advantage of using P76 rotors is that it brings the wheel track in approx 13 mm ( 1/2 inch ) each side and can help stop guard scrub on lowered cars with big wheels.
You would still need ( I think ) some caliper spacers but they shouldn't be much dollars ( just DON'T use washers as spacers ...... it's naughty and DANGEROUS
You would have to still check as to whether there would be any interference with the caliper or stub against the wishbones on full lock and under all wheel movement so I'm not exactly sure whether this is as easy an adaption as it seems.
Hoppers quoted me $240 each to supply and machine blank P76 discs to early holden stud pattern using ready to fit rotors ( not requireing adaptor kit ).
As another alternative,you could use normal new HQ rotors ( cheaper on initial purchase :- as cheap as $110 pair on evilbay ) and have them redrilled and machined but after buying them, having them sent to you and then having them sent to Hoppers Stoppers and than have them sent back to you, well , it all added up to around the same price and was more stuffing around to do it this way.
My new engineer ( last one now retired ) was OK with redrilled and machined rotors.
There was a set of redrilled used rotors on evilbay a few weeks back on a HK Holden but the seller was selling them as a full V8 brake conversion kit with booster,master cyl,lines,proportioning valve,discs and calipers for $550 start up bid and wouldn't separate them ( yep, I rang him ).
I know Shane ( FJ 225 on the forum :- Bumperau "Brett's" dad ) is using HQ rotors on his FB with a 253 V8 but can't remember whether he is using HQ pattern or early holden pattern ?? though I think from memory he is using early pattern with Volvo rims??
From memory a lot of his brake conversion came from Hoppers as well.
Maybe a PM to Shane or Brett might add a bit of actual experience and advice to you.
Hope this bit of dribble
helps.
Cheers.
