Done a compression test on my grey, No.'s 1-4 all read 150 psi (sounds high??)
Got to No.5......nothing, No.6.........nothing.
Pulled rocker cover off, No.5 had a valve jammed open,think it was inlet (closest to front of car)
No.6 valves both appeared to be working fine. Same amount of movement as the other ones.
Put it all back together, fired straight up, but its popping through the carby....pop pop pop pop
Just curious as to wether the valves may not be seating properly maybe?
I'm sure there's a simple explanation to this
ANy thoughts would be appreciated.
Cheers all Muza
