Can I convert a trmiatic floorshift to column??
stucross
Post by stucross »
Hi all,
I have a trimatic auto with a floor shift behind a red motor in an EK sedan (originally column manual) I'm wanting to move the interior back to original and put in the old bench seat. Is it possible to change the shifter to the column and if so - how?? :? :? :?:
Do I need to change the steering column to an auto and is it possible to get this type of linkage ??
(AUST)Mod
Re: Can I convert a trmiatic floorshift to column??
Post by (AUST)Mod »
It is possible.
Ask J - he has a column operated trimatic is his EK.
I believe he used a standard EK Auto column.
As for you wanting to install a bench seat, why can't you do so already? I had an EK with a trimatic in it and it had a bench seat.
Andrew
I am doing the same to my sedan now (floor shift to column shift), you will need an auto column EK EJ HD HR will all fit.
stucross
Post by stucross »
awesome!! thanks guys. Great tip with the compatible columns Trev - good to know. 8) :wink:
excuse my ignorance, but just so I have it clear in the old melon :)
1. if I get an auto column out of say a HR - do you change the whole thing right down to the steering box? and if so does the HR steering box attach straight onto the EK drag link??
2. does the orginal EK steering wheel go straight on to the new HR column??
Thanks for your help mate
They are not collapsable, change the whole thing.
You also need to check that your trimatic has the shift arm on the drivers side - if its a later one on the passengers side of the box then its going to make life harder for you.
you can also save yorself alot of drama and just move the shift forward on the floor so it clears the bench seat
stucross
Post by stucross »
All good tips and info thanks guys
You might have a slight difference between the wheel and the honey pot, not sure if they are a match :? .
EK JAY
Post by EK JAY »
ive got a HR auto column in my ek sedan and a ek steering wheel
wont fit on it :(
the HR column is quite a bit shorter and takes the wheel away from your face and chest
wich is a good thing :)
also the bolt holes in the sub frame need to be filed out slightly to line up with the holes on the sterring column
EK JAY SINCE 1990
stucross
Post by stucross »
thanks Jay, am really wanting to keep the original steering wheel so good info to know - am now trying to locate an original auto column from EK & go from there
Stu
matches
Post by matches »
original ek auto columns aren't cheap, but they are around from time to time. i'm hunting a hr column at the moment for mine.
cheers, luke.
