Grey motor bypass oil filter info request and questions
Posted: Wed Apr 13, 2011 12:19 pm
Ladies and Gents,
Now that the heater and windscreen washer enthusiasts guides are done, I would like to write a similar document about the accessory oil filters (cant help myself :oops: ). I've been collating together quite a bit of info on the filters, and will try to make the filter document similar to the last two guides. I'll cover identification, installation, overhaul and part numbers. I have also pulled together a fair bit of info as to what is required to turn a grey motor into full-flow filtration, and will include that in the guide. As before, I'll post the document onto the forum for all to use.
If anyone has any info on the oil filters (photos, installation instructions, scans from Accelerator magazines, anecdotes etc) and are willing to share, could they please forward them to me? Happy to pay postage to get hold of photocopies if needs be.
As a starting point, I am trying to tie down how to verify the manufacturer of each of the filters offered (AC Delco, FRAM and Ryco). From some digging, I would propose the following criteria:
RYCO - red lid, red canister, bracket either welded, clamped or U-bolted to canister, inlet on the side near the top of canister.
FRAM - black lid, red canister, bracket welded to canister, inlet on the side near the bottom of canister
A.C. Delco - black, engine grey or hammertone silver canister, bare cast metal lid (with lettering cast in), bracket clamped or U-bolted to canister, inlet on the side near the top of canister.
Note that the red paint is renowned for fading/ageing, and is often described as orange (original filters were nearly fire-engine red).
Does anyone have a different way of identifying the filters, or believe the above to be incorrect (especially the location of the inlet, which I have surmised from trawling through quite a few photos or original filters)?
Re: Grey motor bypass oil filter info request and questions
Posted: Fri Apr 15, 2011 11:33 am
In digging through some of the info, I've found some interesting bits.
FX/FJ's had their own unique oil filter part numbers (7405214 for A.C. Delco, and 7405426 for FRAM) whilst all the other grey motors (FE/FC/FB/EK/EJ) shared the same part number. Anyone know what makes the FX/FJ filters different to other greys?
The grey motor mounting brackets normally pick up the side-plate mounting screws. The mounting bracket in the picture below has an additional "ring" that fits over the bottom of the filter and has three holes in it - any idea what it mounts to?
