rotisserie wheels
Ed
rotisserie wheels
Post by Ed »
Hello,
I am thinking about building a rotisserie, and need some advice on wheel load rating.
If I build one to take 900kg. and I have 8 wheels, does this mean each wheel has to take 900/8kg = 112.5kg each since the load of 900kg plus rotisserie weight?
so 112.5kg + weight of rotisserie / number of wheels?
caster wheels are bloody expensive... any one know a good source of cheap/ good wheels?
Ed
FE/FC Holden Car Club of NSW
Re: rotisserie wheels
Yep - go and flog a shopping trolley :D
Ed
Post by Ed »
:lol: :lol:
I want my rotisserie to roll straight Blacky
Blacky wrote:Yep - go and flog a shopping trolley :D
fxfjholden.com
Post by fxfjholden.com »
On mine I have those pumped up tyres you can get from Bunnings or SuperCheap, similar to removalists trolleys etc. (you know the ones touch smaller then a wheel barrow wheel)
"From FJ to HZ, if you don't drive a HOLDEN you're better off DEAD"
fxfjholden forums - http://forums.fxfjholden.com
Ed
Post by Ed »
Is it easy to manouvre around?
I dont have much fore/aft space so need to go side to side easily.
Ed
Rusty EK
Post by Rusty EK »
You can get rated and non rated castor wheels , the rated ones are dear .
Go for a decent size non rated one , they will handle the weight ok .
Ed
Post by Ed »
Will look into that Rusty, thanks,
I have been even thinking of buying some cheap "car dollies" off ebay and just using those wheels...
fxfjholden.com
Ed wrote:Is it easy to manouvre around?
Ed
Yep no problems with the moving on the wheels. It also comes down to our heavy your rotisserie will be. The cars themselves aren't that heavy when they are a bare shell.
Jason
kelleigh54
Post by kelleigh54 »
Have 8 wheels from old hospital beds on mine , 200 diam and swivel . Flash stainless centres just like chromies :D Try your local hospitals maintainence crew . Cold block on a Friday arvo goes a long way.
stinky
Post by stinky »
JimmyJazz
Post by JimmyJazz »
Ed wrote:Hello,
Ed
Assuming the weight is distributed exactly evenly between them, which probably wont be the case depending on the design
