202/trimatic conversion
Posted: Thu Oct 19, 2006 2:16 pm
by oldfb6
G,day everyone, just wondering if any one knows what standard holden tailshaft will fit when i install a 202/trimatic into my FB, with standard diff, can i also use my gearbox crossmember or do i need a different one. cheers, thanks for any help.
Posted: Thu Oct 19, 2006 4:37 pm
by mrs ratbox
if you change the diff centre which would be advisable an LC/LJ torana tail shaft fits straight in, cross member will need to be modified and also floor hump
Posted: Thu Oct 19, 2006 8:54 pm
by Sammy
are you sure about that ratbox ? i used to have a lc/lj tailshaft in my ek with a celica 5 speed, and its a good bit longer than the trimatic ....
Posted: Fri Oct 20, 2006 10:36 am
by Devilrod
I'm pretty sure Ratbox is right. I think that was what I used, I was given it so I can't recall but it fits fine with the trimatic.
Posted: Fri Oct 20, 2006 12:20 pm
by oldfb6
Thanks for the help, I will be changing the standard banjo center to a locked 3.36 banjo, what mods does the cross member need, cheers oldfb6
Posted: Fri Oct 20, 2006 12:28 pm
by Devilrod
Is it a factory auto? If not you have some serious cutting and fabricating to get the trimatic in.
As for crossmember see above question, if its manual you will need to make one.
Posted: Fri Oct 20, 2006 2:10 pm
by oldfb6
Its a FB factory manual, I will be putting in a HQ trasmission tunnel for clearence, thanks for the help, just one more thing do you know where i can get an FB bonnet bar that I don't need to morgage my house for, cheers oldfb6
Posted: Fri Oct 20, 2006 2:19 pm
by Devilrod
I'd suggest using the tunnel from Castlemaine Rod Shop ($95), that way you can use factory auto carpet. Plus you can also get a t700r under them. A few people have used them on here now.
Posted: Fri Oct 20, 2006 7:28 pm
by mrs ratbox
yes sammy done it plenty of times, even the current EK the 5 speed conversion i bought came with a tailshaft out of a LJ and it fit perfect, even an EK ute i put a 308 in with trimatic and 9" i got a tailshaft out of a torana that had a 9" and it worked
