4 wheel disc brake booster
Posted: Tue Jan 25, 2011 10:59 am
by tuffbwagon
hey guys im running commodore discs and hq calipers on the front of my fb and also running a xr8/vl type disc brake diff in the rear. can i use a vh 40 booster with this is there a modification that can be made to a vh44 to make it work. thanks wayne
Re: 4 wheel disc brake booster
Posted: Tue Jan 25, 2011 5:32 pm
by Mick
what master cylinder are you useing i think you'll need dual circut with 4 wheel discs and i think you would then need 2 boosters 1 for the front 1 for the rear, this is all just an educated guess though
Posted: Tue Jan 25, 2011 7:10 pm
I used Gemini booster and VN Commode master cylinder on mine.
Posted: Thu Jan 27, 2011 5:36 am
by tuffbwagon
yeah ok thanks blacky. did you have to reinforce the firewall behind it . cheers wayne
Posted: Thu Jan 27, 2011 11:45 am
No - but I had to modify the bonnet hinge for clearance - have a look here , http://www.fbekholden.com/forum/viewtop ... 4&start=15
Posted: Thu Jan 27, 2011 4:33 pm
by ekstevo
Posted: Sat Jan 29, 2011 9:34 pm
by ekstevo
big Kev a hot rod bloke from ringwood made this ,hoppers supplied the booster and master cylinder
Posted: Sun Jan 30, 2011 3:56 pm
by bat53retro
g,day why not move the peddle to center of the clusterand run the vn /vr booster marster cylinder like in the s/charged van at wa all holden day
cheers
bat
Posted: Sun Jan 30, 2011 8:23 pm
by ekstevo
bat53retro wrote:g,day why not move the peddle to center of the clusterand run the vn /vr booster marster cylinder like in the s/charged van at wa all holden day
In my case Im using the original seat wheel and steering box as I'm not altering the seating position i didn't see any reason to move the pedal position I put the pic up mainly to show how the fire wall is supported.
