Torana Sump
Posted: Thu Jan 20, 2011 5:15 pm
by cramfest
I've heard you can use an LC LJ Torana sump instead of an EH sump for putting red motor into FB-EK.
Is this true? I anyone can give me more details on this it would be muchly appreciated
Re: Torana Sump
Posted: Thu Jan 20, 2011 8:43 pm
by Trev
I have tried but the rear section hit the cross member.
Re: Torana Sump
Posted: Fri Jan 21, 2011 4:39 pm
by stinky
I actually swapped an LC Sump for an EH as the guy who built the motor said the Torrie sump won't fit.
Re: Torana Sump
Posted: Sun Jan 23, 2011 12:05 pm
by bat53retro
g,day the torana pan is further back so dont see how it can hit
cheers bat
Re: Torana Sump
Posted: Sun Jan 23, 2011 1:40 pm
by stinky
Steering component clearance?
Re: Torana Sump
Posted: Sun Jan 23, 2011 1:44 pm
by Trev
Trev wrote:I have tried but the rear section hit the cross member.
bat53retro wrote:g,day the torana pan is further back so dont see how it can hit cheers bat
I should have said it hits the steering link arm, the first step down on the EH sump is above where the torana one only has one big section that hits.
Re: Torana Sump
Posted: Sun Jan 23, 2011 9:08 pm
by Mick
cheers bat
i roughly measure the deepest part of the drop in the sump on an EH and a torana sump, the EH drop is about 70 mill further back than the torana so the EH drop is much further back and someimes there is issues even with the EH sump if the mounts aren't in the correct spot
