blinkers
Posted: Mon Jan 17, 2011 9:16 am
by samprinci
G'day all,
having a few blinker problems with the ute.
When the engine is running both lights in the dash are lit up, along with the blinkers out side. When u engage the blinker, the dash only shows green the side thats engaged. On the outside, the engaged one goes brighter & the non engaged one goes dull.
I've followed the manual, they say, check flasher unit, its New. check fuse, it is good.
the next option in manual is take steering wheel off & check indicator switch unit, but if I can avoid that??/ that would be great???
an ideas?
thanks
Sam
Posted: Mon Jan 17, 2011 11:32 am
by Devilrod
I'd check your earths first. Then the column.
Re: blinkers
Posted: Mon Jan 17, 2011 1:24 pm
by samprinci
Ok, will do, thanks DevilRod.
let u know how I go.???
