Leaking bloody carby bowl!!!
Posted: Mon Jan 17, 2011 1:36 am
by Sputzwagon
Hi all...ever since I've owned my EK sedan, the carby has dripped fuel from the main jet screw on the outside of the bowl.
I have re-kitted the carby about 2 months (or more) ago and thought the new brass gasket (ring) around the screw would fix the problem..but alas it was not to be. :cry:
This is starting to piss me orf because if I don't start the the car for a few days it takes a long crank to get the thing started due to the lack of fuel in the bowl. It always starts straight away one the fuel gets in there..no problems.
Does anyone have a solution to fix this leak..or do I have to put up with it?
Scotty.
Re: Leaking bloody carby bowl!!!
Posted: Mon Jan 17, 2011 4:26 am
by Trev
$180 carby off ebay, I hear they are worth every cent (strogger I think bought one).
If it's leaking through the thread on the jet, some sort of sealant (tape or the red paste you put on welch plugs to stop leaks) as long as it doesn't fowl up the rest of the carb? only a suggestion I have never had to deal with something like this before.
Trev 8)
Posted: Mon Jan 17, 2011 6:07 am
by Dakam
I have the same prob Scotty.
It will take forever to start if left for a few days. Now I just have a small can of fuel in the garage and just pour a bit down the carby and she starts pretty much striaght away. Its a bit of a pain in the ass, but its quicker than cranking her over waiting for it to fire. :roll:
Was looking at the carbies on Ebay, maybe worth grabbing one.
Dave.
Posted: Mon Jan 17, 2011 7:45 am
by Sputzwagon
Thanks Trev & Dave...
Might be worth looking into a new carby...at only $180 it sounds worth it! :D (Considering just a carb kit costs $45!!) :shock:
Scotty.
Posted: Mon Jan 17, 2011 9:44 am
by fbvan
Trev wrote:$180 carby off ebay, I hear they are worth every cent (strogger I think bought one).
Trev 8)
Are these the ones you mean on Ebay? Interested to hear if they are okay.
http://cgi.ebay.com.au/RECO-STROMBERG-S ... 20b6740452
Brian
Posted: Mon Jan 17, 2011 2:02 pm
by Trev
Trev 8)
Brian
That one is for a 202 (1 7/32) so it would be way too big for the grey, what you need for a grey is a 1 1/32 size carb.
http://cgi.ebay.com.au/Holden-stromberg ... _904wt_907
Found this, the price has jumped to $220 since last I looked.
Posted: Mon Jan 17, 2011 6:20 pm
by Dakam
I assume 138 red and grey would be the same size ?????
Dave.
Posted: Mon Jan 17, 2011 6:42 pm
by fb cruzn
we have liquid thread tape at work, maby some of that would do the trick, if not three bond liquid gasket.
we have liquid electrical tape too :shock: they make everything these days :roll:
Posted: Mon Jan 17, 2011 11:41 pm
by Craig
Scotty put triples on it one is bound to work alright
Re:
Posted: Wed Jan 19, 2011 7:17 pm
by Sputzwagon
Craig wrote:Scotty put triples on it one is bound to work alright
With my success on twins and triples it would be the same problem X3!! :roll: :lol: :lol: :lol:
I'll try some thread tape and see how it goes.. :?
Scotty..
P.S..I DO have a twin carb manifold ya know, Craig ! :twisted: don't tempt me!!
Posted: Sat Jan 22, 2011 9:06 pm
by JimmyJazz
ive had the same problem a few times. I just used thread sealant tape (the really thin teflon tape that plumbers sometime use to make joins water/gas tight) on the plug. Just pull the plug out, put a wrap or two around the threaded section (keeping it off the carby end) and wack it back in
Posted: Mon Jan 24, 2011 12:41 pm
by Devilrod
Mines started doing it too now!!! I'm gonna try the tape. Carb was rebuilt last year.
Posted: Mon Jan 31, 2011 6:12 pm
by Timmy
put a small slither of locktite 'form a gasket' silicone round the plug, works a treat.
Posted: Mon Mar 14, 2011 11:04 pm
by artyfartymarty
Not sure if putting nylon tape in contact with fuel will work for very long :)
Had the same problem to the point of car running crap and flooding with fuel. THe problem with my carbie was that the float had a few pin holes in it and filled up with fuel thus not stopping more fuel once the float was filled so kept on constantly overflowing. Check your float and the little valve that it activates. If you don't use a fuel filTer it may have something in there stopping it from closing shut. I sealed the float holes with a little solder and then reset the float level to compensate for the additional weight. Don't use nylon or epoxy or anything like that. It'll rot or dissolve in the fuel. Never know it may be just that the float level needs to be adjusted...easy fix.
