fitting red motor to ek with auto whats involved
bonnie
Post by bonnie »
:roll: Hi i am nearly about to start on my ek, it still has grey motor and hydromatic gearbox, and i have purchased a hr front end if i put a red motor in wich auto will fit in without changing floor tunnel and also does any one know if you can still buy new callipers for hr disks, cheers
Re: fitting red motor to ek with auto whats involved
Think you'll find a Trimatic will fit fine. As for HR calipers, not sure. Have you got old ones to rebuild?
DR's on the money i think just about any auto you want will fit in the tunnel, certainly a trimatic or powerglide will definately fit
J
Post by J »
I used to have the same, put in a 161 with a trimatic and its all good :)
definitely do the front end now though, my old one is rooted and I have to get this HR one sorted.
You will need to make a gearbox crossmember, another option is to buy the trimatic to grey motor adaptor kit and use some of the kit in that to hook it up.
Matthew4655
Post by Matthew4655 »
Instead of chucking a HR front end in it would it be possible to just put on HQ front disks instead of the drums? :?:
