oil light flashing
oil light flashing
strangly when the car is at idle the oil light has been coming on and flickering. when i give it a few revs the light disappears. basicly the light only comes on at low revs sometimes, could this be my sender? I hope....
Re: oil light flashing
have you checked you oil level? are all the electrical connections on properly? just a few thoughts...
cheers
Nathan
cheers
Nathan
Foundation Member
Foundation Member
oil is all good, electrical seems alright, gunna try a new sender today
Hi Mate,
Have previously experienced same issue.
Mine turned out to be the sender as well.
Although i did have a few worrying moments when it first occured.
Though at the time, i took the oil filler cap of and shone my torch in over the rocker shaft and oil was squirting out of the brass hex joiner and out of the rocker oil holes as well. Figured if oil had enough pressure to squirt out at the top of the engine, pressure must be fine else where.
(Watch out for the fan if you try to replicate this check.)
Anthony..
FB/EK Car Club of QLD
www.qldfbekholden.com
u r not using to light of oil r u as this will make it do that
How did you go with rego Tim? No dramas?
thanks for the help guys turned out to be the sender although i did sh1t myself when the light kept coming on and i thought the worst. Rego went with flying colours jimmy, thanks for the help. see you all at AHD
