wheel nuts
dave a
wheel nuts
Post by dave a »
i'm looking to buy some wheel nuts and every one quotes in a basic 1/2 ins and 7/16 . does any one know what size EK/EH is in both imperial and metric. and are ht and hq different to ek, thanks.
BUILT NOT BOUGHT
EKjimmy
Re: wheel nuts
Post by EKjimmy »
7/16 i'm quite sure. can't see why they would have changed much
Re: wheel nuts
Dave a , be careful what you buy , there are 2 different tapers for early and later Holden wheel nuts , do you have one that fits your rims as a sample ? If not , take a wheel with you and go somewhere that knows what they are selling - not some crappy joint that mainly sells seatcovers and plastic hubcaps :roll:
Re: wheel nuts
Gday Dave
They are 7/16 UNF, there is no metric size equivalent
If you are using EK/FB stock rims, you will need EK/FB wheelnuts
They have a different taper where they seat into the rim to later H/KTG types
What wheels are you using?
Jeff
dave a
Re: wheel nuts
Post by dave a »
i'm actually using volvo rims so who knows what the tapper is? as long as they screw on i'll be happy.
BUILT NOT BOUGHT
Re: wheel nuts
they might screw on but wont stay - just ask minifb :wink:
Re: wheel nuts
dave a wrote:i'm actually using volvo rims so who knows what the tapper is? as long as they screw on i'll be happy.
Grab a nut (you know what I mean :roll: ) and sit it in the hole to see if the tapper matches, if they don't the come undone while driving, Trev 8) .
oldnek
Re: wheel nuts
Post by oldnek »
Easiest way to check taper.
Good tip is grab some plasticine put in on the end of the nut and place it gently in the wheel nut housing of the rim. Pull it straight of and section the plasticine with a stanley knife or blade, it will stand out like dogs balls if the tapers are different.
Regards John
dave a
Re: wheel nuts
Post by dave a »
ended up buying some nuts of e-bay,they where listed to suit fc fb ek etc... they are a chrome nut, not a mag nut. they fitted very well , a top quality product.i got 20 nuts for 40 dollars and they look good with the torana centers :D :D :D :D :D
BUILT NOT BOUGHT
Re: wheel nuts
Can you throw up a picture of them fitted?
Re: wheel nuts
Autobarn have 'em too.
