Can you put a HR rotor/hub assembly straight onto a HK through to WB spindle ?
HR rotor/hub to HK-WB spindle
Re: HR rotor/hub to HK-WB spindle
This is a good article to follow generally... or speak to a professional!
http://www.hoppers.com.au/stoppin%20holden.htm
cheers
NoMAD
cheers
NoMAD
Foundation Member
Foundation Member
you can put it on but the calliper will miss the rotor there may be an adaptor
Old man was looking for a temporary fix, he's changed his mind now
Cheers anyway..!
Cheers anyway..!
