celica 5 speed
celica 5 speed
Hi there, You have no doubt been through this before ,I have a celica 5 speed w50 gearbox and am not shore what bellhousing to use behind a red202 ,I have the drive shaft so i can use the celica end to make up a shaft ,i have also read that the slave cylinder can be used has any one been through this thanks (Gary)
- Sammy
- Contact:
you need to get a specific bellhousing ... CRS make them as do dellow. get the right bits from them then the original aussie 4 speed hydraulic slave cylinder bolts straight on.
there are also custom yokes you can get for the conversion then you don't need a custom tailshaft .... i had a feeling it was an LH or LJ torana tailshaft is the right length when i did mine!
this is my celica 5 speed with dellow bellhousing
Regards,
Sammy.
http://www.oldholdens.com
Sammy.
