steering arms.
fj_225
steering arms.
Post by fj_225 »
im using hq stubs hq rotors drilled to ht stud pattern.do i use hq or ht steering arms :?: any help gracefully received. cheers shane :)
FB MAD
Post by FB MAD »
If you are using the CRS V8 HR front end with Torana rack they use a HR steering arm that has been bent to, I assume , clear the wheel rim.
fj_225
steering arms.
Post by fj_225 »
thats what ive got :) but there hitting inside of tyre :( rims are standard ht :?: cheers shane
FB MAD
Post by FB MAD »
Are you able to get a spacer made to bring the steering arms away from the wheel rim, say, 1/4 inch and then use slightly longer bolts??.
Alternatively,
The HQ "power steering" arms are shorter than the HR style and may help with clearance issues.
There was a discussion on the various steering arms with pictures on the FE/FC Forum recently, I'll see if I can find it and post it up here.
FB MAD
Post by FB MAD »
Maybe this discussion and pictures may help.
http://fefcholden.org.au/forum/index.ph ... 986.0.html
Re: steering arms.
fj_225 wrote:thats what ive got :) but there hitting inside of tyre :( rims are standard ht :?: cheers shane
Have always had the same problem Shane, so I get the wheels offset changed to the same as HR disc wheels to solve that problem.
From what I have been told, with the width of a HR front end if you use different length steering arms it will change the turning track of the tyers, too short and the outside tyre will toe inn and scrub out the tyre, too long and the outside tyre won't turn enough and scrub out the tyre as-well, Trev 8) .
fj_225
steering arms.
Post by fj_225 »
had my eye on a set of jelly bean mags 14x7 with 4 and a half back space. now im not shore if they will fit :?: cheers shane.
fj_225
steering arms.
Post by fj_225 »
thanks 4 the info terry and trev. i will give ajax wheels a buzz. cheers shane.
I think they charge about $60 for the changed off-set, but sometimes you might need a new rim, depending on the condition, Trev 8) .
FB MAD
Post by FB MAD »
:roll: Thats probably not a bad price because it would give your problem a quick fix and save time stuffing around trying to find an arm that will do the job and as Trev said, you may have steering geometry issues as well.
ben
Post by ben »
I run the same setup Shane HQ stubs/hubs and HT 14x5 ROH steel rims which are 4inch backspace and nothing hits. From memory there are two lenght HQ arms and i used the short ones (or was it the long ones or maybe the HR ones). The knuckle is about 20mm clear from rim edge. So 4.5 inch backspace rims should still clear
Pics might help
Just looking at the link FB MAD posted and maybe i ended up using HR arms :oops: whatever they are they work anyway :wink:
Brodie
Post by Brodie »
I've got HQ spindles and HR front end/steering. I'm running HR arms at the moment but im unsure what effect it has on the geometry, scrub radius etc???
So which model steering arms are preferred/best? Do i use HR or HK/T/G??
The answers probably written above somewhere but im not sure :roll: :?
Cheers 8)
HR arms on a HR front!
vmx-mxr
Post by vmx-mxr »
This might seem like a stupid question but.........
Are there any differences between an HD or HR cross member, upper/lower control arms, steering arms etc. If not I guess a lot of them have already gone along the way as other stubs could be fitted etc.
I have a HR front end but it's so bashed up underneath I was thinking of broadening my search to HD? Unless someone has a clean one they want to sell?
Dave Mac :D
FCOV6
Post by FCOV6 »
vmx-mxr wrote:This might seem like a stupid question but.........
Dave Mac :D
Hi Dave , HD crossmember is the same as HR and has balljoints as well so is a direct swap for a HR front end.
