Red Rattler Revamp
Re: Red Rattler Revamp
Bugger mate! I’ve still got lungs full of snot from a virus I picked up in Sydney four weeks ago.
My prescription would be 8000mg vitamin C, daily.
Sorry the hear you are down mate I didn’t get a chance to get to the fe fc nats but I had a reason :lol: :lol: :lol:
All I managed to do today was get the rattler on the hoist and mow the lawns 😟😟
I MIGHT have had a win with the alternator - the charge post was loose and wobbly when I bolted it back in after lending it to a mate , I pulled it out this morning and thought I would have a look at it before ordering a new one.
Removed the back of it and looky here -
The nut on the inside was loose as buggery -
Removed it and the post , cleaned it up and reassembled it with a dollop of Loctite then fought the brushes back into their holders with the aid of a short piece of TIG wire and a scriber
Reassembled it and was going to put it back on but I am too bloody crook - half an hour in the shed and that’s the end of me ImageImageImage
Refitted the alternator today, plus replaced the crook O2 sensor. Took the throttle body off to check out the funky readings and it looks like the switch is dicky- is a second hand one by the look of it , has a Nissan brand in it but when you google it it comes up as a VL Commodore part. New one is $180 but a VN style one is $20 and it just so happens I had one in the shed so will make a bracket tomorrow and use one of them Image
VL style
VL vs VN
Checking resistance and compatibility
New plug required- can buy new for under $10
The RB30 TPS’s are notoriously unreliable. When they fail, the car runs, but erratic as hell.
Don’t ask me how I know 😖
Couldn’t find any aluminium plate thick enough but I have heaps of copper floating around so I cut a new mounting ring using the 2 holesaw method today
Finished off the TPS bracket last night - had to shorten the shaft to get it to sit nice - the original had spacers in there and it was a bit wobbly now it sits on the flange all the way around
Gauges turned up today ImageImageImage
Fast forward 2 months - put the new gauges in today
Also tried to fit this fiddly little bastard of a plug - I bought 2 of them and buggered up both of them ImageImageImage Fkn little wires I hate them …….
Also wired in a IAT warning light at the request of the tuner
Mounted up a catch can/puke tank as well - plus spent the first couple of hours avoiding wiring by cleaning the shed Imageso a pretty productive day
Red Rattler Revamp
Well , it’s ready for the dyno ImageImageImageImage
Last of the bits needed for a dyno session completed yesterday, also got the Caltracs nearly sorted - these are off to get welded tomorrow and then dropping them at the powder coaters, the front bolts have been at the machinists for a few weeks now , he is a mate so it might take a while Image
At last!
I want to hear and see this thing run as I'm sure you do Blacky :roll: :roll:
Red Rattler Revamp
Got the Caltrac bits from the machinists today, had a quick play with them
Bushes were a bit tight, had to machine them down a tad
Now they fit Image
Powder coat tomorrow hopefully
