EK/FB regoed
Harko
Post by Harko »
A seasoned Pro builder :)
Post by mrs ratbox »
lucky we got into it early :shock: it's f#%king 28 degrees inside would have to be well over 30 outside :x
all doors done (gaps not great but they'll do) front and back windows in new front door rubbers on (does't that job suck balls) prolly do a little more when it starts to kool down a little tonight :)
for now it's off to the spa with my little esky full of burbons 8)
all windows in doors and working along with all other mechanisms motor and gearbox in still need to finish off gearbox Xmember radiator ready to go motor may be running tomorrow
COUPLE OF THANKYOU'S so far before i forget
tim. sunnytim lenses
trevor. trev headlight surrounds
andrew. (aust)mod door locks
mark. minifb back seat and headlight buckets
terry. FB mad transport of parts
bumper au pickup and store parts
thanks guys :D
matches
Post by matches »
looking good RB, and by the sound of it you've just about got all the parts you need.
i like the look of the primer/guidecoat FB flash 8) and different. i know your not leaving it like that but you could and i don't think it would look wrong.
cheers, luke.
matches wrote: i like the look of the primer/guidecoat FB flash 8) and different. i know your not leaving it like that but you could and i don't think it would look wrong.
cheers, luke.
thanks, not a bad idea as i HATE sanding :x
doesn't seem to bad for a $50 ebay motor that was locked solid when i bought it, figured it was worth $50 for the engine No and EH sump & pickup, pulled the head (wish i had a pic of what the inside of No 5 bore looked like :shock: ) but chipped the rust away give it a clean with emery cloth soaked it in old sump oil give the piston a little perswasion to move with a mallet, got it winding over by hand put the head back on and started it on the ground that was abot 9 months ago, stuck it in this car hooked everything up turn the key as soon as it got fuel up it fired and sat there and purred like a kitten 40psi oil preasure revving and a little under 20psi at idle next test will be how it pulls the car :?
(AUST)Mod
Post by (AUST)Mod »
What a beast!
(I am talking about the engine :lol: )
Sounds very healthy indeed.
With all of your FB/EK experience, how long does it take you do pull a red motor and whack in another>?
Andrew
my70wg
Post by my70wg »
you were wearing the exact same thing when i seen u at the all holden day this year... :lol: :lol: :lol:
aidan...
i'll get there....
red out red in ? if so less than a day
plenty of gray shorts i've got 2 draws full of blue singlets would definately be a different cut off flanno it's only fresh :lol:
Stygian
Post by Stygian »
ratbox wrote: ...next test will be how it pulls the car :?
Take it for a hotlap and post up a vid of it...
Thats value for money Rat!! Sounds good enough, hopefully will too with some load on it.
FB MAD
Post by FB MAD »
Yep, nothing wrong with $50 motors .Mines been running near two years now .Been to Yamba Nationals and Bendigo Nationals no probs.
Was that the 138 red from evilbay Mick??
FB MAD wrote: Was that the 138 red from evilbay Mick??
yep
minifb
Post by minifb »
FB MAD wrote:Yep, nothing wrong with $50 motors .Mines been running near two years now .Been to Yamba Nationals and Bendigo Nationals no probs.
Thats Cos a great bloke owned it at one stage.... :P :P :P Cheers Mark
FB/EKForum member 123
FB MAD
Post by FB MAD »
:roll: Ah, yeah :? :? :? , forgot you owned the car that my motor came from :oops: .
$50 worth of Minifb spec engine modifications :wink: :wink: :wink: :lol: :lol: :lol:
