Mate your Ute is going to come out the other side really great, you will appreciate all the hard work when you are driving a reliable and safe Ute.
Thanks for the encouragement Neil.
Some paint
Not bothering with the axle and springs as they will be coming out later on when the springs and centre at the least.
Another coat and I will do some more when I flip it over on the other side. There are more areas I could work on with it up like if is but impatience may get the better of me.
Some paint
This is the stuff I used to prep Patrick
[IMG]//uploads.tapatalk-cdn.com/201906 ... 4e4ae1.jpg Phoenix Paints Floorprep 100.
[IMG]//uploads.tapatalk-cdn.com/201906 ... 4e4ae1.jpg Phoenix Paints Floorprep 100.Sent from my iPhone using Tapatalk
Thanks Clay, should last another 60 odd years now
Watching paint dry
I re-tapped tank mounting threads to 1/4 x 20 (UNC I think).
that’s what I assumed them to be but must have been wrong as thread stripped.
that’s what I assumed them to be but must have been wrong as thread stripped. Sent from my iPhone using Tapatalk
Next job to repair fuel tank surround. Fitted it up to tank to brace it up.
- State: SA
Your making some good progress there Clay. The finish of the underside looks great, keep at it.
You're cranking along there mate. Good stuff
- bolt/nut/washer/springwasher,
- larger sized self tapper,
- weld up the thread holes, drill and self tap with the original sized screws - I'd do a test piece first for this method though, as mig welding might be a bit too tough for a self-tapper if the new material is too thick.
Cheers, John
These are a sheetmetal, self-tapping type screw Clay, so the thread's different to a bolt type thread. If the screws don't hold properly now, some options are:Errol62 wrote: Sun Jun 09, 2019 6:32 pm I re-tapped tank mounting threads to 1/4 x 20 (UNC I think).
Cheers, John
Thanks for demistifying John. I’m sure the original screws will turn up one day. Re tapping to 1/4” uni seems to have worked. In some cases I needed to hammer down the thread plates to make them tight prior to re-tapping. The car is really a hot rod now!
this bit will be pretty well hidden so ready to ranex, wire brush and then zinc prime as it will be folded over rear body member where the spare wheel door attaches.FB ute fixer upper, EK van on rotisserie
The other side today
is goot enuf
is goot enufSent from my iPhone using Tapatalk
Hi Clay,
Looking great mate and the finished graft is awesome. Funny how a bit of colour can make ugly look fantastic.
Keep plugging mate wont be long now.
Thanks Greg
The Metalfix makes for an easy job of it. Continuing on the tank surround.
Love your work mate
- State: SA
Clay,
Appreciate watching and learning what your up to on the ute, it is a credit to you. You have certainly tackled some big things on the van and ute. Thanks for posting up progress and pics.
