Red Rattler Revamp
Re: Red Rattler Revamp
Don’t forget to space the lower housing away from the head so you can whip the cover off and play with the rocker preload every five minutes……
Errol62 wrote: Thu Aug 29, 2024 1:02 pm Don’t forget to space the lower housing away from the head so you can whip the cover off and play with the rocker preload every five minutes……
The aluminium plate that is the support bracket for the blower belt tensioner does a pretty good job of that Clay :wink:
Back together and started running wires , got the stuff from under the dash , around under the driver side guard and up to the thermostat housing in tonight
Wires done and all put back together under the guard. Dash side completed except for one - ran out of green wire for the temp idiot light that I am going to put in the back of the head - that’s a 10 metre roll of green gone ImageImageImageImage
Engine side finished, waiting on a 12mm spacer for the rocker cover and I lent my alternator to a mate who needed one in a hurry for his hire car - a stretched 57 Chevy
Electric water pump controller all done bar the programming - leave that for the tuner to sort out.
When you going to give it another run mate??
FireKraka wrote: Mon Sep 02, 2024 12:50 pm When you going to give it another run mate??
Rocker cover spacer turned up this morning so once the alternator comes back jobs on 8) 8)
Great to se you get this running properly mate I want to hear the old slapper running.
FireKraka wrote: Tue Sep 03, 2024 2:34 pm Great to se you get this running properly mate I want to hear the old slapper running.
You and me both mate :twisted:
When is the hip getting done mate :eh: you will be able to join the cyborg group with Cooky and me (and whoever else in the club) having bionic parts mate.
October 3 , a month today - wish it was tomorrow ......
Blacky wrote:October 3 , a month today - wish it was tomorrow ......
Good luck with your upcoming surgery mate.
Got it all back together Image
Bastard won’t start - backfiring through the blower ImageImageImage
Bloody cars ……….
Started playing around with the timing wheel on the harmonic balancer last night - its the only thing that has been off since last time it ran, moved it and it at least sounded like it wanted to go but still no, moved it again - 90 degrees at a time is the only adjustment there is on it - and same same.
Ran out of time so will have another go at it tonight - have emailed the bloke I bought the kit from to confirm where it should be at so fingers crossed for a fire up tonight.
Fingers crossed
gledge
Post by gledge »
You still got that sonic trigger set up on it? I threw that trigger in the bin after two faulty ones.. I think I still have a replacement one here somewhere that he sent me if ya need
