These pin holes and cracks around the corner of the tank where the sender wire runs are easy to access with the car tipped over like this. Image
Used the copper bar behind and mig down low. Short bursts parallel to surface and away from the hole, building up metal and working back to fill hole. ImageImage
Should come up okay with a grind and Metal Fix.
fb delivery
Post by fb delivery »
Mate,
Drill a hole at the ends of the crack
Drilling the ends of the crack will stop it cracking ather welding
Thanks for the tip yeah makes sense. I just welded past the crack a bit. Also need to touch up the other side.
I’m pretty happy with how the repairs are going now. Goal is to weld tidier. My main problem is I can’t see what I’m doing so well. There is a fair bit of farmer welding (no mask shut eyes squeeze) and resultant “sunburn”.
Clay,
Wear your glasses inside the helmet, also a auto visor helps a lot as well.
I have found if you can shield the light from around the back of the helmet, rag, shirt, or towel works good as well.
Weld a spot and while its still red move a touch and spot again. You will get it probably at the end of the project Ha !
You’re right Greg. I appreciate the tips. I need to clean screens and yes I hav a pair of work glasses for 30 to 50 cm focus but still I tend to find I get a better result with fine stuff using the agricultural technique.
After a bit of a distraction last week chasing over to Port Lincoln to pick up the low mileage 179 from my mate, back in to it today. Finally tackled the inner sill and chassis tie. ImageImageImageImage I will finish the job when I flip the car over on its other side.
Also had a look at the 179. It’s an early block number M54091 from memory. I think this means it would have had a Hydramatic behind it. It has been sitting on the floor of mates shed for 30 years with no plugs or manifolds. Consequently there is a light rusting in bores one and six. Which were near bdc. It may get by with a serious clean or at worst a hone and rings. The timing gear was stripped hence the removal and numbers 1 and 3 inlet valves were open. No doubt a valve grind will also be in order. Anyway no hurry on that front.
Clay,
Quickest way to tell if the 179 had a Hydro is to look in the back of the crankshaft. No spigot bush means auto as original fitment.
You might be surprised about the internal condition of the motor. If it turns over by hand it won't be that bad. Of course, stripped timing gear will mean dropping the sump to get the timing cover off, and oil pump will have to come off to get the camshaft out. Fortunately red motor timing gear sets are cheap and easy to get. Or if you don't mind a highest-quality second-hand fibre timing gear, I can put one in a Postpak bag.
Thanks Rob
I’ll go with an alloy gear. Cheap insurance. Good point on the spigot bearing. I read somewhere the early EHs used the EJ manual box which wasn’t up to the 179. Although the early S4s were manual.
Errol62 wrote: Sat May 04, 2019 11:21 pm I read somewhere the early EHs used the EJ manual box which wasn’t up to the 179.
I thought it was only the 149 cars that used the EJ box ???
That’s why there no 179 manuals early on blacky. They were still developing the stronger box.
No spigot bush Image
Confirmed. An original hydro-179.
Ok I’ve hijacked my own thread.
Good progress on the under body repairs today. Took Greg’s advice an put a rag over my helmet which made a big difference to visibility, blocking out the overhead fluros. ImageImageImageImageImage Progress equals mess. Image
Digging around on the other side and wouldn’t you know I found similar rust in passenger side inner wheel arch. So I’m half wishing I decided to mini tub. It’s not nearly as bad as the driver side. I’ll just repair it for now and keep moving on.
Nice work mate keep at it and I'm going to try the rag over the helment thing as well; I have an auto darkening helmet but still have some issues seeing even with glasses on under it so it may be the light coming in from behind.
Good call.
