Red Rattler Revamp
Re: Red Rattler Revamp
Finally got a night on the rattler - it’s not looking good for the Nationals now … ImageImage
Started making a mount for the electric water pump, it needs to sit in here , it’s pretty tight there isn’t a lot of room
Figured out a plan then started with the CAD mockup and old tacho was the right size or right enough as it was on the bench right in front of where I was working….
Close enough
Then back in the car a couple of times to figure out the bottom of the mount
Then started on the metal bit
And then made a new fuel pump block off plate and made it longer so I could bolt this to it with rubber mounts
Will finish this bit off tomorrow night- I hope , wasted nearly an hour when I dropped a fkn bolt and it wedged itself in the rack mount - and do you think the bastard would come out???? :evil: :evil: :evil: :evil: :evil: :evil:
Had to pull the rack out and ended up belting it out with a length of 1/2” round bar and a hammer :twisted: :twisted:
You should have gone out and got smashed instead, like I did....
Brackets done , remade the pump one out of 4mm aluminium as the 1.2mm galv was a bit flimsy
gledge
Post by gledge »
Did ya gut the water pump ?
gledge wrote: Sat Jun 01, 2024 7:50 pm Did ya gut the water pump ?
Not yet but I will ….. starting to wonder if it’s not a good idea to whip the head off and make sure the steam holes line up …..
gledge
Post by gledge »
Yeah I’m thinking something isn’t right in there.. at least check the lash.. maybe tight on the exhausts
gledge wrote: Sat Jun 01, 2024 8:23 pm Yeah I’m thinking something isn’t right in there.. at least check the lash.. maybe tight on the exhausts
I have 1.6 intake and 1.5 exhaust rockers - Harv said when they first went on shouldn’t they be the other way around and I kinda thought so too but the guy who built the engine swore that’s how it should be , might swap them over
gledge
Post by gledge »
Still wouldn’t think that would make it hot so quick.. also on your break in with the Holley the headers were glowing pretty quick didn’t they? Was the water temp high then as well?
Yes it was getting hot and as you say the headers were glowing red - haven’t had that issue since the blower went on
Big day yesterday - fitted the washer nozzle and the top radiator hose ImageImageImage
Hey - at least I did SOMETHING ImageImage
dumb question as i'm sure you would be on top of it, but re your overheating does your radiator have walls (for want of a better description) in the tanks to force the coolant to flow through the radiator seeing as your intake and outlet are on the same side
Mick wrote: Sun Jun 30, 2024 9:44 pm dumb question as i'm sure you would be on top of it, but re your overheating does your radiator have walls (for want of a better description) in the tanks to force the coolant to flow through the radiator seeing as your intake and outlet are on the same side
Yeah mate I checked it with a borescope to make sure it has a divider in it - its not a perfect seal but its mostly there.
Can timing checked over the weekend and found to be correct- have also tigged a bung into the radiator for the temp sensor to go into and will put an idiot light switch in the back of the head as per original
Had to tap the snout of the crank to fit the degree wheel
