Just sorted the rear suspension, this is what I posted for J and Ken.
OK, I do mine with the springs still in the car.
Undo the bolts that hold the diff onto the spring.
Put a stand under the diff to hold it above the spring (so you don't have to remove the rear end all together
Undo the locator bolt that holds all the springs together (use vice grips to hold the springs together so the bolt will undo.
Hear we have 5 leaves.
Take this one.
Flip it upside down like this.
Use these to clamp them together using a screwdriver to line up the bolt holes.
Bolt them together and put them in your car (if they are out).
I also used 1.5 inch lowering blocks aswell.
Put the wheels back on and drop the car down to check the clearances.
The bump stops, I'll be cutting these in half
And the tail shaft, I have about 2 inches.
This is what was like before. With the lowering blocks in
And after
much better
Hope this helps, and that I haven't done anything that will kill anyone
Like I said, you can cover your ass and get it done properly and probably safer
