My new Fb
59wagon
Re: My new Fb
Post by 59wagon »
Wrongway Roger wrote: Sat Mar 03, 2018 8:01 pm Heh John, I was very interested in the manufacture of the hinge Spring tool.
A lot of years ago now, I worked for a company (Litchfield Tools ), that made them and all the other " service tool" for early Holden.
If only I had loaded up the car when they closed the business.
If only, Roger. Did you manage to get any of the tools? I’ve made a few tools along the way. I enjoy it and sometimes they actually work!
John
59wagon
My new Fb
Post by 59wagon »
Today I tackled the steering wheel after visiting Neil FireKraka for a pleasant morning and grabbing a spare wheel he had to see what I had to do to mine. Checked out Neil’s Ute and he’s done a lot of work to the old girl and the colour really sparkles in the sunlight.
Well, this is what I started with - a steering wheel with two large bits broken off and a chunk missing from the other side
I cleaned off the surface rust from the plastic bits and the metal support ring and used a super glue to stick them back onto the wheel
After reading in a thread on wheel repair in this forum that a large gap was needed for “Knead It” to work properly, I used this rotary tool to grind out the 3 vertical joins and the long horizontal join to about 1/4” wide and went right through so that the goo would penetrate to the inside of the hub and have a good anchor. I also bored blind holes into the inside of the hub for extra purchase
Not having used this product before, I wasn’t sure how much to use in one go so I cut off about a 2” length - man, does this stuff go off quick! It was pretty hot in the shed, though. I wasted a bit then did the rest in 3 separate goes using shorter lengths.
Then some die grinding, filing and sanding, using 240 grit for the final sand. I wasn’t too fussy with the inside of the hub as you can’t see it and I thought the more gunk the better strength wise
Some primer and paint and good to go, and Neil can have his wheel back Image
John
Re: My new Fb
Re: My new Fb
nice work John, at this rate you will have her on the road well before the nationals ! 8)
Re: My new Fb
Great work John the wheel came out really good.
Your welcome out my place anytime mate.
59wagon
Re: My new Fb
Post by 59wagon »
Thanks guys.
Just waiting for a few bits I’ve ordered Blacky, and then I’ll book in for an inspection and find out if I need to do anything else.
Good to see your work, Neil. You’re doing a great job bringing the Ute back from the dead.
ekv8ute
Re: My new Fb
Post by ekv8ute »
Hey John, your wheel looks good, but I think you need to have bare metal where the horn contact touches the wheel for the horn to work
59wagon
Re: My new Fb
Post by 59wagon »
ekv8ute wrote: Tue Mar 06, 2018 10:50 pm Hey John, your wheel looks good, but I think you need to have bare metal where the horn contact touches the wheel for the horn to work
Yeh 👍 I was in a bit of a rush when I got to the paint stage and couldn’t be bothered masking up. I’ll need to do a little bit of sanding. Thanks for the reminder.
John
59wagon
Re: My new Fb
Post by 59wagon »
Made up a “Genuine, except for some bits, NOS reproduction battery clamp”.
I welded some flats for the spring washer to sit on ....
.... and a cable clamp
As the battery is shorter than original, the rubber bump stops won’t work properly, so I used a piece from a kindly donated & used plastic chopping board from the good wife to make a diffferent one
Fits up nice and snug
The battery tray’s not in great nick so I’ll make a new one down the track...
In the meantime, I gave it some rust converter, primer and paint.
John
Re: My new Fb
Good one John. Lump of conveyor belt rubber has been my lazy fix in the past.
CHOPPED
Re: My new Fb
Post by CHOPPED »
looking good john
untill the wife goes to cut your toast in the morning on the cutting board :roll: :lol:
HEY IT WASNT ME
Re: My new Fb
Might be something else she’s cutting. John Chopped??!
59wagon
Re: My new Fb
Post by 59wagon »
We removed the front hubcaps today to check for play in the bearings and found this sticker inside each of them
That joint was about 3k’s from where I am now. Note the 3 digit phone number.
John
59wagon
Re: My new Fb
Post by 59wagon »
Got these in the mail from RET yesterday.
Re: My new Fb
hows progress John , do you think you will have her on the road for the Nationals mate ????
