Harv's Norman supercharger thread
Re: Harv's Norman supercharger thread
Ladies and Gents,
One thing that has been bugging me for a very long time is trying to identify the different Norman supercharger models. Whilst there were a number of Norman supercharger models produced, little literature remains to confirm the exact types and models. To complicate matters, there is a significant amount of rumour and guesswork that has been applied over the last half century. Various discussions refer to a wide variety of machines, including Type 70, Type 75, Type 72 and Type 45. I will present the information below based on discussion with Mike Norman, together with some (limited) literature from the era and photos of different models. My thanks to Mike for helping to pull this together.
Eldred’s Superchargers – the start of something cool.
Eldred Norman became interested in manufacturing superchargers following a supercharged car being traded-in at his used car dealership in Adelaide in the very early 1960’s. Having removed the supercharger before selling the car, Eldred then sold the supercharger, and was astonished at the volume of interest expressed. This indicated a clear market, providing that the right vehicle was chosen to sell the supercharger to. Whilst there could be some benefit in selling superchargers to performance cars, there was a far greater market selling to vehicles with relatively poor performance. At this time General Motors Holden was a significant market player, but had yet to embrace the performance market… it’s first forays into factory “muscle cars”, the EH S4 and HD X2, were some time off. Holden thus became the logical target for Eldred’s manufacturing. The first Norman superchargers were made by Eldred in Adelaide, using both his own workshop and a small third-party foundry. Eldred continued manufacturing after moving to Noosa, utilizing a foundry in Maroochydore. In both South Australia and Queensland he made his own sand-casting moulds and forms.
Eldred’s superchargers were named by “Type”. Each Type was numbered according to it’s capacity in cubic inches per revolution, measured by subtracting the volume of the rotor treated as a solid form from the volume of the interior of the casing (see discussion above over how this differs from current methods of measuring capacity). Eldred made the following eight Types:
• The Type 65
• The Type 70
• The Type 45
• The Type 75
• The Type 90
• The Type 110
• The Type 265
• The Type 270
Type 65
The Type 65 has a capacity of 65ci/rev (118ci/rev if measured by the modern method). It is believed that Eldred began manufacturing superchargers with the Type 65 in late 1964 or early 1965 in St Peters, Adelaide. The early Type 65’s all have cast iron casings and steel rotors, and are fully air cooled. Some of the early Type 65’s had alloy rotors though this was quickly ceased and steel used due to wear. Later Type 65’s, which were made after the introduction of the Type 70’s, have alloy casings and are water jacketed with two welsh plugs. The welsh plugs were added primarily to support the sand around the jacket void during sand casting of the housings. Type 65 casings have seventeen radial fins, cast iron liners, have Type 65 cast into the casing and have separate inlet and outlet manifolds. Both Type 65’s and Type 70’s are often fitted with Eldred’s inlet manifold, which points back towards the firewall (some are fitted with an extra elbow to point the carburetor towards the passenger bonnet spring). The early Type 65’s were mounted via the Holden grey motor generator bracket, and connected by hose to the inlet manifold. The bracket was then tensioned up to provide a tight drive belt. This line-up was changed in Noosa to the use of a steel inlet manifold made from RHS, with a separate idler pulley providing belt tension. Surviving Type 65’s that I am aware of include Gary Claypole’s alloy cased unit (which has been overhauled and photographed above), and John Brown’s steel cased unit (which I need to get photos of). The image below appears to show an early steel cased unit (judging by the colour difference between the casing and end plates) and was taken from an early advertisement for the Eddie Thomas Speed Shop in a 1965 copy of The Australian Hot Rodding Review.
Mike Norman also drove an ex-PMG FE panelvan (repainted from red to grey) with a Type 65 supercharger around 1964-1965. Bill Norman raced a Standard 10 fitted with a Type 65 (his first race car, at age 17), which was later road-registered by Mike.
The photographs below show an early steel-cased Type 65 on an FJ Holden.
Pictured below is the steel-cased Type 65 owned by Lindsay Wilson.
Pictured below is an alloy-cased Type 65 advertised on eBay in May 2014.
Type 70
The Type 70 has a capacity of 70ci/rev (I have not had a Type 70 open to measure it’s capacity by modern methods). The Type 70 superchargers all have alloy casings (radially finned on one side, smooth on the other with a cast iron liner), alloy end plates and are water jacketed with two welsh plugs. These have Type 70 cast into the casing. Type 70’s were mounted on the passenger side of the Holden motor, with Eldred’s inlet manifold. The carburetor, usually a 2” SU, was mounted at the passenger rear of the engine bay. Externally, there is little to differentiate the Type 65 and Type 70 other than size (the Type 70 being slightly larger) and the name (Type 65 or Type 70) cast into the water jacket.
Pictured below is Lindsay Wilson’s Type 70 from his EK Holden stationwagon, with both photos showing the finned side of the casing. Carburetion is single 2” SU.
Pictured below is Peter Wooley’s Type 70 from his FJ Holden sedan, showing the smooth side of the casing. Carburetion is twin SU.
Pictured below is Ian Gear’s Type 70 from the Rowe/Wigzell SA#2 WonderCar speedcar. Carburetion is triple Stromberg 97.
Type 45, Type 75 and Type 90
The Type 45, 75 and 90 were developed as a family of superchargers, often referred to as Series 2 (Series 1 compromising the Type 65 and Type 70). The Type 45, Type 75 and Type 90 were manufactured by Eldred whilst still living in Adelaide. Using Eldred’s measurement process, the Type 45, Type 75 and Type 90 had a capacity of 45, 75 and 90ci/rev respectively. Using the modern measurement system gives 83 and 149ci/rev respectively for the Type 45 and Type 75 (I have not been able to find a Type 90 to measure). Interestingly, when using the modern method the Type 75 (149ci/rev) has a larger capacity than the Type 110 (145ci/rev). This is due to the placement of the inlet and exhaust ports, which is not accounted for in Eldred’s method. The target market for the Type 45 was engines up to 107ci (smaller than a Holden red motor), whilst the Type 75 and Type 90 were targeted at the 186ci Holden red motor and 225ci Valiant slant-6 engine respectively. The Type 45 was sold as a blower-only package, with manifolding being made by the end-user to suit the specific application, whilst the Type 75 and 90 could be purchased as a package, utilizing the original vehicle’s carburetor. Note however that some Type 75 installations swapped Valiant Carter carburetors on to Holden 186ci engines, probably due to the 111/16” Holley 1920 or Carter BBD carburetors (235 or 260 cfm@3”Hg) being of greater capacity than the replaced Holden single barrel 15/32” Stromberg (210cfm@3”Hg), albeit less than a WW-series carburetor (280cfm@3”Hg) fitted to the HR “S” 186ci engine.
Type 45, 75 and 90 superchargers have steel rotors, radially finned alloy casings with a cast iron liner, steel end plates and integral inlet and outlet manifolds (all other Norman superchargers have separate inlet and outlet manifolds). Type 45’s have seven radial fins, whilst Type 75’s have twelve (I do not know how many fins a Type 90 had). Type 45’s and Type 75’s had “45” and “75” stamped (not cast) into the housing (I’m not sure if Type 90’s did but suspect so). The Type 45 is air cooled, whilst the Type 75 is water cooled with no welsh plugs. An article was written for Australian Hot Rod magazine in November 1966, titled Blow for Go! Norman Style. The article has a lot of technical detail, and is very likely to have been written in consultation with Eldred… giving confidence it is factual. The article refers to two models, a Standard (no clutch) and DeLuxe (clutched). The article notes three sizes:
• the size shown in the article, which is a Type 75 supercharger.
• a 4” shorter size designed for engines up to 1750cc/107ci (the Type 45 supercharger), and
• a 2¼” longer size for engines up to 4000cc/244ci (The Type 90 supercharger).
Looking at the article detail, the Standard and DeLuxe have a hard-chromed steel liner. Note that this is interesting, as Mike remembers that none of Eldred’s supercharger liners were chromed or surface treated. The majority of Eldred’s liners were made from cast iron diesel truck sleeves. At one stage, Eldred managed to secure some chilled cast iron sleeves from Repco. These were found to be too hard, and Eldred reverted back to the normal cast iron sleeves. Also of note from the article:
• steel rotors (aluminum had been tried but had only 1/8th the life of a steel rotor). The Type 75 had a rotor of 4½” diameter, bored 2”,
• cast-iron end plates (aluminium had been tried but wore the rotor ends). The Type 75 was 13/8” (inclusive of the fins). Note that this is different to the earlier Type 65’s and Type 70’s, which have aluminium end plates,
• an internal diameter of 5½” and an overall width of 12” for the Type 75,
• four ¼” vanes lots to average 2½” depth, with ½” of support at the base of the lobe slot,
• a 1½” long boss for the pulley drive key back to the front bearing on the Standard, with no boss on the Deluxe (the pulley for the Deluxe being mounted on ball races).
Whist the Type 65 and Type 70 superchargers were largely used on Holden grey motors (along with other engines of similar size), the Type 75 marks Eldred’s change to targeting the Holden red motor. Unlike the earlier Type 65 and Type 70’s, the Type 75 supercharger is mounted on the driver’s side of the Holden engine, with the inlet to the bottom and the carburettor on the steering box. The supercharger outlet is fed across the top of the rocker cover via a cast alloy air/air intercooler.
The image from the article, showing the Type 75 DeLuxe, is shown below.
An additional article was written for The Australian Hot Rodding Review of January 1967, titled Blowers for Holdens!. The article was written inclusive of a visit to Eldred’s workshop in St Peters, Adelaide (the visit must have occurred before Eldred moved to Noosa in 1966), and is again very likely to have been written in consultation with Eldred and likely to be factual. This article refers to a second series of Normans (Series 2). Images from the article are shown below.
Looking carefully at the Australian Hot Rod and Australian Hot Rodding Review images shows that they are the same vehicle, being Eldred’s HD Holden utility.
The images below show Type 75 superchargers.
The image below shows my Type 45 Norman. As an aside, this unit has had an interesting history, having been used as a forge furnace blower in Noosa by Eldred. On request, Eldred made Super Light Weight (SLW) rotors for some superchargers (definitively some Type 110s and probably others). The Super Light Weight rotors were made from steel, initially milled from a billet, then with steel flat bar electric stick welded in place with the whole assembly then machined… no small task! The kerosene-fired forge (with the Type 45 supercharger blowing air through it) was then used to heat treat (normalize) the rotors. A Super Light Weight rotor, in an early Type 65 casing, is illustrated in Supercharge! (see image below).
Type 110
The Type 110, with a capacity of 110ci/rev (as measured by Eldred’s method) was the archetypical Holden red motor blower. The Type 110 superchargers all have alloy casings and are water jacketed with three welsh plugs. These are the only superchargers made by Eldred with longitudinal (not radial) fins. Between manufacturing the Type 45, 75 and 90 superchargers, Eldred had moved to Noosa in 1966. Production of the Type 110 supercharger may have commenced as early as 1967, though was definitely in full swing by October of 1968. The Type 110 was targeted at the Holden red motor, though saw use in some unusual places. For example, in Supercharge! (October 1969), Eldred refers to a Type 110 supercharger:
“In 1954, driving a supercharged Triumph TR2, I finished 4th in the Australian Grand Prix. On this car I used a “boost’ of 12lbs. The supercharger was a G.M. 271 Roots type unit operating at 1.1 times engine speed and driven by four ‘A’ section V belts. By the end of the race belt-slips had caused a fall in boost to a maximum of 8 lbs. Naturally I had to ‘nurse’ the belts by not using full throttle at this stage. My present Holden is some 50% greater in capacity than was the Triumph. I am using a 10 lb. supercharge from my type 110 vane type supercharger and drive it with only two ‘A’ section belts. Under these conditions the vane type is putting out almost 40% more air/fuel than did the Roots with twice the number of belts. Certainly the car is not being raced which is an enormous difference. But my belts last at least 5000 miles of normal road use. Detractors of the vane type supercharger have usually only seen the wrong unit on the job.”
The Type 110 is also illustrated in Supercharge! (see image below). The longitudinal fins are clearly visible from this angle.
A Type 110 supercharger was also used on the Dennis Syrmis/Richards Time Machine FJ Holden drag vehicle shown below. Syrmis is renowned for being the second National Director of ANDRA, helping found Willowbank Raceway and for initiating the "Wild Bunch" and "Top Doorslammer" drawcards.
The image below (from Street Machine magazine) shows a Type 110 on George and John Cole’s Vauxhall Viva gasser.
The image below shows the Type 110 on Ken Stephenson’s Front Engined Dragster. The three welsh plugs are clearly visible from this angle.
The image below shows my Type 110. This machine has had a hard, hard life, and was last in service on a Toyota engine at 20psi. Along with being helicoiled, the casing has had the original three-welsh plug jacket removed and the polished water jacket seen in the image fitted.
Type 265 and Type 270
The Type 265. This is where Eldred’s numbering system becomes interesting the Type 265 supercharger does not have a capacity of 265ci/rev. Rather, it has a capacity of 2 x 65 = 130ci/rev. The Type 265 superchargers were built by joining two Type 65 superchargers end-to-end with a common rotor (and hence the naming convention – two x Type 65). The casings were joined by recessing the Type 65 units to suit studs and nuts and bolting them together before line boring and honing. The Type 265’s were built as a response to a need in the market for a supercharger to suit larger V8 engines and rail dragsters. It is likely that all Type 265’s were alloy cased and water jacketed, though potentially some were made with air cooled steel casings. Type 265’s were made by Eldred in Noosa from 1967 onwards.
Similarly to the Type 265, the Type 270 has a capacity of 2 x 70 = 140ci/rev, and is made by joining two Type 70 casings with a common rotor. All Type 270’s had an alloy casing and water jackets, with cast iron finned end-plates. The Type 270 is illustrated on a &*#@ Y-block V8 in Supercharge! (see image below).
I know of only one Type 270 to have survived, which is currently owned by Mike Norman. This Type 270 was built by Eldred for Bill Norman in 1969/1970. Whilst Bill was driving a Type 110 supercharged GTR Torana, it still was not quick enough. Eldred’s answer was to build a Hillman Imp with a Buick Fireball aluminum 215ci V8, complete with the Type 270 supercharger. Sadly, whilst the Hillman was test driven for a yew yards, it was not completed prior to Eldred becoming ill and passing away.
Type 265 (water cooled) and Type 270 superchargers can be quite difficult to differentiate. The main visual two differences between them are that the Type 270 is slightly larger, and all had cast iron finned end plates (the Type 265 may have had either cast or alloy end plates). The photographs below show superchargers which could be either the Type 265 or 270.
Shown below is Cliff Kiss’ front-engined dragster, taken from Supercharge! Note that Aldred Engineering is not the company of the same name currently operating out of Helensburgh NSW.
Kiss’ dragster is also shown below from Australian Drag Racing Nationals Souvenir Edition 1973:
… in this photo below from The Elapsed Times of June 2008, which shows Kiss’ dragster at the 1968 Winternationals on June 23rd 1968 at Surfers Paradise International Raceway…
… and also in these two shots from the 2009 Street Machine Hot Rod Annual.
The photo below shows Chris Reid’s altered (originally built by Bill Jones and raced by Ray Knight).
Shown in the image below is the Warren Ramsay/Ian Burrows Semi Hemi front-engined dragster, running Olbis injection on a Valiant Slant-6.
Mike’s Superchargers – the blower is back.
Having been raised on a diet of supercharged vehicles, Mike Norman began building some superchargers from Eldred’s design in 1973-1975. Unfortunately, the original patterns and moulds for Eldred’s superchargers, stored under the house in Noosa, had been lost. From 1978 (through to 1984) Mike ran Offroad Automatics Pty Ltd at Magowar Road in Girraween, Sydney. Whilst the business was involved in fitting automatic transmissions to Range Rovers, Mike began to tinker with superchargers around 1983.
Mike’s superchargers represent a significant design change from Eldred’s. Rather than cast individual casings, Mike chose to extrude the casings from aluminium. Mike’s casings were initially manufactured by milling a 6” diameter solid aluminum billet… no easy task. Once the casing design was finalized, a two-piece extrusion was made by Comalco. The casings were then lined with a cold drawn seamless tube, manufactured in Adelaide (with a minimum order of 300m!) to a tolerance of around 0.004”. The liners were then Tufftrided in Melbourneprior to being installed. In some of the casings a rubber O-ring was fitted between the casing and the end-plates. The end-plates, of aluminium construction, were cast by Newcastle Foundries.
Mike’s rotors were milled from 4” aluminum round stock. Whist he considered having an extrusion made (similarly to the casings) the proposals from various manufacturers at the time were expensive due to the complex die and not very accurate. The non-drive end bearing support stub (shaft) is made by turning down the main aluminum body. The steel drive end shafts were made by drilling and tapping the rotor then Loctiting the screwed shaft in place. The rotor design was also different to Eldred’s, moving from four vanes to three.
By doing this, Mike was able to achieve a very deep vane slot whilst still having sufficient “meat” in between slots close to the shaft. The deep vanes allow for a long vane movement (high capacity) whilst still retaining enough of the vane in the slot to minimize bending moment. However, having a greater proportion of the vane in a deep slot moves the vane centre of mass closer to the shaft. This in turn lower centripetal force, making Mike’s vanes harder to move outwards than Eldred’s. Whilst the problem of the vanes sticking in is reduced at higher rpm, at low rpm the issue is noticeable – the noise of vanes clatter (lifting off then re-hitting the casing walls) is evident. To address this issue (clatter and the potential for increased vane wear at low revs) Mike fitted springs to each rotor vane. The springs were fitted in pockets milled into the rotor slots, and retained in place by a nylon bush. The springs were locally made in carbon steel as alloy material was not readily available locally and would have had to have been sourced from the US. Whilst this seems strange in a modern “everything is available online” world, bear in mind that Mike was manufacturing in the early 1980’s… the World Wide Web was still the domain of university geeks. Mike experimented with a number of other options to increase the centripetal force, including lightening the vanes and fitting them with lead weights.
A change was made to the material used for supercharger vanes. Eldred’s vanes are a dark brown colour, and are made from canvas backed Bakelite with a phenolic resin binder. Mike’s vanes were changed to a more modern epoxy resin based binder over a fine fabric matrix, supplied by a firm in Sydney. The cream coloured epoxy based material was much stronger and wear resistant than Eldred’s Bakelite vanes. I suspect Mike’s material was either National Electrical Manufacturers Association (NEMA) FR-4 or FR-5 fire retardant glass-cloth reinforced epoxy laminate, but am not certain. Additionally, Mike’s supercharger vanes have grooves that are milled all the way across the face of the vane. The grooves are used to assist the vanes in being able to move in and out of the rotor. The vanes should be a “flop” fit, though may experience some changes in dimensions due to moisture, fuel properties or dirt. If the vanes become a tight fit, the oily environment they operate in may allow them to form a seal with the rotor. In this case, the vanes will draw a vacuum at the vane root as they try to slide out, or will build pressure at the vane root as they slide back in. The slots allow the vane root to equalize pressure, allowing the vanes to slide freely. The slots also allow some flow of air/fuel/oil around the vane, helping lubrication. Vane grooves were not machined in the vanes made by Eldred.
Similarly to Eldred’s superchargers, Mikes superchargers employed a roller bearing at the non-drive end and a ball bearing (sometimes two) at the drive end. Some of the longer shaft superchargers were fitted with greasable drive-end bearings, though most of the bearings were of the sealed type. The bearings chosen by Mike were metric, being cheaper at that time than the imperial bearings available.
Mike made a total of six supercharger sizes (150mm, 200mm, 250mm, 300mm, 350mm and 400mm), designated by the effective casing length. The target market was engines from 500cc to 4000cc (30ci to 244ci). Whereas Eldred’s superchargers were referred to as “Types”, Mikes were referred to purely by number (for example “my Holden motor is fitted with a 300 supercharger, and goes like the clappers”). When the casings are measured, they are typically 5mm longer than the above sizes, as the end plates are recessed 2.5mm each end. The casing length is also reflected in the serial numbers stamped into the casings: the first three digits of the serial number reflects (approximately) the casing length in millimeters. Examples of serial numbers are shown in the table below.
The superchargers were identical internally, with capacity being determined by cutting the casing extrusions and milling the rotors longer or shorter. Both short and long drive shaft lengths were supplied, with the 300, 350 and 400 superchargers typically fitted with longer shafts whilst the 150, 200 and 250 superchargers typically fitted with shorter shafts.
The photographs below show a 150 supercharger.
The photograph below shows a 300 supercharger.
The photographs below show a 350 supercharger. As an aside, this supercharger has an interesting history, having spent time on Mike Normans’ 122ci SOHC Triumph Dolomite Sprint.
The photographs below show a 400 supercharger.
Around 1984 Mike was commissioned to supercharge the new four-door Range Rover owned by the managing director of Leyland Australia. This vehicle originally had 9.5:1 compression, and required new low compression pistons to go with the supercharger, manifolds and water injection. All up the project cost around $3500. Mike ceased automatic transmission operations in Girraween in 1985, moving to Noosa. The advent of newer more efficient supercharger type such as the Whipple and Eaton superchargers made for a declining market, and supercharger production was ceased.
Harv (deputy apprentice Norman supercharger fiddler).
Love your work Harv, very interesting read :clap: :thumbsup: :clap: :thumbsup:
Ladies and gentlemen,
This post will be a collection of odds and ends from a recent tidy-up of my notes. You know how when you put something together and there are leftover nuts and washers at the end? Thats how my notes looked :oops: . In the final Norman Supercharger Guide (the pdf version), the information will be slotted in as relevant.
• Rotor to end plate clearances
a) Clearance between the rotor and the non-drive end plate (labelled as A in the diagram above) can be set to 0.015”. For the early Type 65 machines where both the casing and the rotor are steel, it can be reduced to 0.006-0.008” (this end of the assembly absorbs the differential expansion of the rotor and casing, which is much less with steel/steel).
b) Clearance between the rotor and the drive-end plate (labelled as B in the diagram above) can be set to 0.002”. This end is held in place by the bearing assembly, though care needs to be taken at these clearances to ensure the assembly is adequately locked.
c) Clearance between the rotor and the casing (labelled as C in the diagram above) should be 0.004” maximum. High values (for example 0.020”) can cause considerable loss of boost pressure. This clearance is increased as the casing is honed or the rotor outer diameter milled. It can be rectified by changing the rotor offset, though this is no small task.
• Only seven or eight of Eldreds’ 3” SUs were ever made between around 1969 and 1971. The SU on the Eclipse Special was not one of Eldred’s, rather it was from a Maybach. When fitted to a 186ci Holden red motor and Type 110 supercharger the 3” SU would only lift around ¾ of it’s piston travel at 6,000rpm.
• Eldred’s HD utility (the supercharger test-mule) had all drum brakes. Fitted with the 110 supercharger and 3” SU it could make 140mph.
• The maximum recommended speed for a Norman supercharger is 5000rpm. 6000rpm is really pushing it. Friction and heat become a significant factor.
• The rotor slot sleeves in Mike’s superchargers were originally pressed to shape, Tufftrided, inserted into the rotor then steel riveted using an extension. The fixing method was later changed to punching (expanding) the rivets in using a pointy-ended drift.
• Mikes rotor springs were typically replaced after 5-8000km of driving. Running without the springs is rattly but does not drop performance.
• Tufftiriding was used by Mike over nitriding as it provides better anti-galling, was more wear and fatigue resistant and softer (easier to form).
• One issue to note however in running oil in fuel is that a significant proportion of the oil will condense in the cylinder and end up in the sump (i.e. Norman superchargers can make oil). Experience shows that approximately 80% of the added oil ends up in the sump in this manner.
• Andrew Mustard (the gentleman with the Norman supercharged Elfin from my earlier anecdote) made some (albeit very few) of his own vane type superchargers with cast alloy rotors.
• Mike’s superchargers sold for around $1000 bare.
• Mike had cast around fifty Range Rover V8 supercharger manifolds, though only around 15 were sold.
• I missed one version of the Type 65 supercharger. In previous posts I indicated that the Type 65 was either air cooled/steel cased, or water cooled/alloy cased. There was a third type, presumably made in between the two, which were water cooled/steel cased. I had thought that these were a one-off that someone had home-made by re-jacketing a Type 65 (kinda like my Type 110 had been) until I reviewed my notes and realised there were a few of them. The water cooled, steel cased Type 65’s have aluminium end plates and steel rotors. They do not have welsh plugs, and have water nipples not close to each other (one on the rear of the supercharger on the passenger’s side, and one towards the front of the casing).
The first of the two survivors that I know of is the supercharger from the Bobcat FJ custom. This vehicle was built by South Australia’s Bob Moule, with the magazine clippings shown below from Wild Wild Bobcat article in The Australian Hot Rodding Review of June 1968.
Bobcat was running 5psi boost on a relatively standard FJ grey motor. Note that the mounting here is low, with the generator mounted near the cylinder head and a hose used to connect the supercharger discharge to the standard grey motor inlet manifold. Triple v-belts are used to couple the drive the supercharger, crank and water pump with one belt also wrapping the generator. Both the generator and the supercharger are pivoted, with the combination of the position of the two providing belt tension). The motor was fitted with a Holley 94 carburettor from a &*#@ V8, which has the same flow capacity as the original BXOV-1 Stromberg (162CFM@3”Hg). The engine had Bedford truck valve springs, no vacuum advance, Speco headers and twin exhaust pipes. All up the modifications had increased the grey motors power from 60BHP to 82BHP. This supercharger was removed from Bobcat, and was subsequently fitted to Anthony Harradine’s EJ Holden Premier (see photo below).
The second of the two survivors that I am aware of was owned by EKDave (from the FB/EK and FE/FC forums) and is pictured below. Note that this machine also has the “hose to standard inlet manifold” connection.
Dave - if you are reading this, thankyou for trying to hunt down that Norman for me... itching to take some more pictures and/or measurements from the new owner :thumbsup:
Harv (deputy aprentice Norman supercahrger fiddler).
In a previous post I wrote an anecdote relating to the use of Norman superchargers on an Elfin sports car. The Elfin had been used for land speed record trials in both single and twin-Norman blown configuration. Whilst researching other material, I stumbled across the two articles below, which I thought I’d share.
The first article and accompanying photograph comes from The Canberra Times, Saturday the 26th of September 1964, page 28
Elfin in Attempt on record
The Elfin racing car originally used to test the surface of the salt track used in the successful attempt on the land speed record by Bluebird will attempt to break the 1500c.c. international standing mile and standing kilometre records. The record attempt will be staged on a recently completed sealed road at the Weapons Research Establishment at Salisbury, South Australia. Mr. Andrew Mustard, project co-ordinator in the recent successful attempt on the land speed record at Lake Eyre, will make the attempt. The car, built and designed by Mr. Gary Cooper, of Edwards town, South Australia, has been timed at 146 m.p.h. in a much detuned state. Extensive work has been done on the car since this time was recorded and Mr. Mustard feels sure that the car is capable of a much higher performance. The car has been modified from its original form for the record attempt. Originally it had a 1,500c.c. &*#@ Cortina engine, and developed approximately 120 b.h.p. With the fitting of two individual Norman superchargers parallel to each other with each one feeding two of the cylinders, over 200 b.h.p. should be developed. With an all up weight of 850 pounds and 200 b.h.p., the car (pictured above) should have staggering acceleration. As was shown by the Bluebird record at attempt, there are many factors that can set any record attempt off balance. Factors lo be taken into consideration are whether the car will be ready in the short amount of time the mechanics have to work on it, whether the Elfin, with its conventional parts, will be able to stand the strain from the enormous thrust of the 200 b.h.p. for the 10 seconds or so during the attempt, and the most important factor in any record attempt, the weather.
The second article comes from the same newspaper, from Monday the 28th of September 1964, page 3
Mustard fails in world land speed attempt
ADELAIDE, Sunday. — Andrew Mustard, team manager and project coordinator in the successful attempt on the land speed record at Lake Eyre by Donald Campbell ,in the Bluebird, failed in an attempt to break the 1500 c.c. international standing mile and standing kilometre records this weekend. He will, however, claim at least two Australian records, subject to official confirmation. They are the formula F flying mile record (at 136 m.p.h.) and the flying kilometre (138 m.p.h.). Mustard made the record attempt on a recently completed sealed road at the Weapons Research Establishment at Salisbury, South Australia, driving the Elfin racing car used originally to test the surface of the salt track at Lake Eyre for the Bluebird attempt. Bad weather and cross winds affected the result in Mustard's attempt. His top speed was over 155 m.p.h.
Ladies and gents,
A quick post to update my Norman-supercharged speedcar anecdote, following some excellent feedback from Ian Gear (who currently owns the SA#2 WonderCar). This update ties down the origin of the two Rowe Renault midgets.
Following the sale of the Norman-supercharged, Peugeot engine SA#2 WonderCar to Joe Braendler, Alex Rowe had the funds to build another Norman-supercharged car for Wigzell, with all new running gear. The first Norman-supercharged Rowe Renault started out with a Peugeot motor, followed by a Renault motor (firstly carburettored, and later injected).
The first Rowe Renault was bought by Cec Eichler and was raced under the Kevin Fischer of Murray Bridge South Australia banner alongside the Suddenly #88 Supermodified sprintcar. The Norman-supercharged midget was also numbered #88 and painted in similar purple as the Suddenly #88 car – see the image below from my previous post of the two vehicles. The midget had been fitted with fuel injection by this stage and was looked after by Fischer mechanic Ian Thiele.
In the mean time (1972) Rowe built another Norman supercharged Renault-engined car using a secondhand Edmonds chassis. The second Rowe Renault (also numbered SA#2 like the WonderCar) was driven by Greg Anderson until the closure of Rowley Park in 1979. Anderson drove the second Rowe Renault to win the South Australian Speedcar Championship in the 1973/1974 season, up against Wigzell in the first Rowe Renault (SA#88).
Harv (deputy apprentice Norman supercharger fiddler and historic Speedway appreciator).
Ladies and Gents,
A little piece of cool history for this post. The photo below shows Bill Norman's LC GTR Torana.
Bog stock standard 161ci (2600cc) straight-6 with a Norman 110 supercharger. Standard brakes, wheels, radials, suspension, exhaust, head and cam. Home made aluminium bonnet and door skins, interior gutted. The supercharger never reached it's full potential as the relief valve spring lifted constantly (too light).
The photo was taken at the Warwick Farm (Sydney) esses during a Sports Sedans practice on the 2nd of May 1970. Bill can be seen thrashing the Torrie at the same meeting in the last few seconds of the 8mm video clip below:
http://www.youtube.c...h?v=jjgNQy6YIRk
Warwick Farm is close to home for me. Dad used to race there on-and-off in the late 60's, early 70's, though pretty informally (he was more often at Castlereigh, crewing a V8 humpy 8) ). Dad was part of a group of 100 young mechanics who were selected based on their performance to take a look at the newly released LC GTR, including hot laps around Warwick Farm. Shame the only racing over there is by hay-burners now .
As an aside, I’m writing an Eldred Norman anecdote.... I’ll add this material to it (watch this space ). It needs some revision yet, and verifying by Mike, Bill and Bron before I post it though.
Ladies and Gents,
This post is a bit of a tease. As you are aware, as part of the Norman Supercharger Guide, I have a number of Normans to pull apart and put back together. One of the Normans on loan is Gary's Type 65, which has featured in a number of earlier posts (normally in pieces :lol: ). The teaser photo below shows how far we have come along with the overhaul:
Ladies and Gents,
For this post, I will take a look at the drive system that we use on our Norman supercharger. As a starting point, I will focus on belts.
For our Norman supercharged grey motor, we have a number of choices of drive system. For example, we could use:
a) Direct drive off the crank snout. Direct drive has been used in a number of vehicles, including the Daimler-Benz race vehicles of the early 1900’s and many GM Roots superchargers in diesel service. Your typical early Holden however has very little room at the front of the crank to direct mount a supercharger. Whilst not impossible, direct driving a Norman supercharger is not readily practicable, nor very period correct.
b) A gear set. Gear driven superchargers are not that unusual, with Rolls Royce Merlin superchargers often being driven through single or two-speed gear drives. Gear drives are available from The Supercharger Store (see http://www.youtube.com/watch?feature=pl ... 0nizAm3bPw, which shows the ERA coupler fitted to one). Whilst not impossible, driving a Norman supercharger through gears is not readily practicable, nor very period correct.
c) A chain drive, as used on Stud Beasley’s Norman supercharged midget and Andrew Mustard’s supercharged Elfin (ses anecdote below). A chain drive is pictured below.
We could fit a single, double or even triple row chain to the supercharger, and drive them from toothed sprockets on both crank and supercharger snout. This would provide a very positive drive, with no slippage. However, there will also be absolutely no slip should the supercharger stall (for example if the fuel/air mixture inside the supercharger and inlet manifold ignites during a blower bang). This means that during blower bang events the jarring energy can be transferred via the belt to the crankshaft. This can be like the unstoppable force meeting the immovable object, and lead to bending of either the supercharger drive shaft or the engine crankshaft. Unless we are chasing every last ounce of horsepower from our Norman supercharger (and are willing to wear the risks of damage), this type of drive is not recommended.
d) A gilmer belt, as shown in the image below.
This is a toothed (positive drive) type of belt, again minimizing the risk of slippage. This type of drive is common on modern drag racing superchargers. Gilmer belts do pose similar risks to chains with respect to transmitting blower bangs. However, the Gilmer belt is more likely to shred/strip the belt teeth. Not such a big deal at the drag strip on a dedicated race car, though pretty frustrating in the Woolies carpark on a road-going car. Gilmer belts are also relatively wide compared to say a vee-belt. The real estate at the front of your typical Holden grey motor (between crank and radiator) is pretty small. Whilst not impossible, it can sometimes be a challenge to get a gilmer belt to fit. Gilmer belts are also relatively difficult to purchase… try finding one in your local SuperCheap. Again not really a problem if you carry a spare belt in the boot, but not too easy after stripping the belt in the middle of nowhere on a Sunday afternoon. Gilmer belts are period correct (and often seen) on the later (Mike) Norman superchargers, though not usually on the earlier (Eldred) Norman machines.
e) A vee-belt. Vee-belts are period correct, and provide some ability for the belt to slip during a blower bang. They are relatively cheap, and readily available from SuperChepa, Repco etc. For these reasons it is recommended that vee-belts be used on most Norman supercharged applications. Vee-belts are typically available in two profiles – normal/plain (see lower image below) and ribbed/notched (see upper image below).
If a choice is available between normal and notched drive belts for Norman supercharger operation, then a normal belt should be chosen. The notched drive belt does have some benefits over the normal belt:
• They compress and grip better whilst still allowing good initial start-up slip (to avoid initially shocking the supercharger).
• The higher grip also allows them to compensate better for poor pulley surfaces.
• Less energy is required to bend the belt around the pulleys.
• They have a greater surface area for heat dissipation (i.e. they run cooler).
However, because the notched belts grip better, they are less likely to slip during a blower bang. The normal type belts however provide enough slip to prevent this occurring.
Note also that vee-belts are available in a ribbed format, as per the image below.
Ribbed belts are very common in modern vehicles. They began to be used in Holdens around the VL Commodore era, and have all but replaced normal vee-belts. Ribbed belts are easier to flex around tight pulleys. However, they are not very period correct for a Norman supercharger.
Given the above, I will focus on normal vee-belts in the discussion below. There are a vast number of systems for designing the sizes of vee-pulleys and the associated vee-belts. These range from simple automotive belts, through to agricultural belts to general purpose belts. One of the challenges of finding an appropriate belt drive for the Norman supercharger is that we will often have to match up automotive pulleys with other types in order to get the correct diameter, bore or number of grooves. The discussion below will try to pull together what is available, and some alternatives.
As a starting point, we will look at the original Holden vee-belts (and pulleys) found on grey motors. These are automotive type pulleys, and are likely to have been made to the SAE standard SAE J636 V-Belts and Pulleys. SAE J636 specifies both metric and imperial belts. Metric belts are labeled in three parts:
• A number denoting the closest mm width of the belt (eg an “11” belt is roughly 11mm wide). This ranges from 6 to 23.
• The letter A, denoting automotive
• A number denoting the belt length (e.g. “990” for a belt that is 990mm long).
In the example above, the belt would be labeled 11A990, and the pulley referred to as an 11A.
Imperial belts and pulleys are labeled as decimals of the approximate pulley width. For example, a “0.250” pulley is 0.248” wide.
Most automotive aftermarket belts that are readily available in Australia (Bosch, Dayco) are metric automotive. Note that Holden grey motors use two different types of pulleys – a wide belt on the earlier Holdens (FX and FJ), and a narrow belt on the later (FE through EJ) grey motors. For FX and FJ Holdens, a type 15A belt is used, whilst the later FE through EJ Holden grey motors utilize the narrower 11A belts. For example for FX/FJ Holdens Bosch recommend a 15A1130 belt, whilst for later grey motors a 11A0955 belt whilst Dayco specify a 15A11300 and either a 11A0900 or 11A0950 respectively. Whilst your typical early Holden is running a metric belt, it is very likely that the original Holden pulleys were specified imperial (Australia didn’t start going metric until 1968, well into the red motor run, with industry making significant change in 1974, halfway to the blue motor in 1980). This means that the FX/FJ Holden wide pulleys (both water pump, alternator and crank) are likely to be 11/16 (0.600) pulleys, whilst the narrower FE-EJ pulleys are likely to be 0.440 pulleys.
In short, our early Holden is running an imperial automotive vee-pulley, and probably a metric automotive belt. To keep things simple, it would be nice to be able to walk into Repco or Supercheap and use a similar metric automotive belt (or belts) on our Norman supercharger. Not only is it easy to find a Repco or Supercheap, but they are also likely to have a wide variety of belt lengths. This will make it easier to fine tune the belt length (rather than say ordering in a specialty belt from an industrial supplier, only to find it is slightly too long or short).
The question then becomes how many vee-belts we would need to drive our supercharger. From Supercharge!: “Now as to how many belts are required to drive a particular supercharger. This depends on the type of supercharger, its size and the amount of boost intended. As a rough guide a standard car engine of 1500 c.c. using a seven pound supercharge and pulleys no smaller than 4 inches will require one 'A' section belt. A two litre with the same boost can manage with one 'B' section. A three litre will need two 'A' section. And a five litre V8 will need three 'B' section.”
Translating this to a 138ci (2260cc) grey motor, running 5-10psi of boost would infer a single “B” belt, or two “A” belts under heavy loading. This is very similar to the modeling I will present later, which shows that a single modern 11A belt will probably handle most Normans, whilst a second belt is appropriate under heavy use.
Now that we have a view on belts, it is time to focus on the associated pulleys. For our Norman supercharger, we will be trying to connect the crank to the supercharger snout. This will involve a pulley on both shafts. It is possible to align the supercharger to the existing grey motor crank/water pump/generator pulley line, and use one belt to drive each of the fan, water pump, generator and Norman supercharger. However, for reasons which will be explored below this type of lienup is unusual and not recommended. Typically a dedicated supercharger belt will be required, and we will need to source both a supercharger drive pulley for the crank and a supercharger driven pulley for the supercharger snout. Bear in mind that we would ideally like to utilise the common (and cheap) 11A metric automotive belt profile.
For the supercharger drive pulley, a neat alternative is to bolt a flat pulley to the front of the grey motor harmonic balancer. The original GMH grey motor harmonic balancers have a flat face, though only the central hole (which is tapped to 11/8” UNF to accept the harmonic balancer puller tool). However, aftermarket grey motor harmonic balancers are available from PowerBond, and supplied by Rare Spares. These are Rare Spares part number 7401305 for the wide-belt FX/FJ (PowerBond part number HB17B-N) and 7408676 for the narrow-belt FE-EJ style (HB1049-N). Anecdotally (and just in case any of the red motor guys are reading this ), the respective EH-HZ red motor part numbers are M40284 and HB17A-N. Each of these aftermarket harmonic balancers has three concentric bolt holes, as shown in the images below.
The holes are tapped through the hub to 3/8-24UNF on a 213/16” (71.44mm) PCD. Whilst the holes are ostensibly there to mount a modern harmonic balancer puller tool, they also make a very neat mounting point to bolt up a flat pulley. The bolt-up pulleys from Holden red motors and Commodore Starfire 4-cylinder engines have this PCD, and are a neat bolt-on fit. An alternative is to find a flat pulley from another vehicle, drill three holes to the PCD above and bolt them on. Note that if you are sourcing pulleys (either drive or driven) from a wreck, almost all early Holdens (FE-WB, LC-UC Torana, VC-VK Commodore, VN-VS 308’s) used the 11A metric/0.440 imperial pulleys. Be wary though that many of these models had the larger 13A metric/0.500 imperial pulleys on air conditioning. From VL Commodore onwards the six cylinder engines began to move towards the ribbed vee-belts. Additionally, care needs to be taken to ensure that the pulley is truly centered before marking out and drilling the holes. This is particularly important if the pulley chosen does not have the same centre bore as the grey motor crankshaft (~1”). For example, small block Chev (SBC) double-row flat alloy pulleys are readily available. However, the SBC crank diameter is ~1¼”. This means that there is a risk that a SBC pulley will not be centred, imparting vibration to the crankshaft (they grey motor needs no help in this department). The holes could be drilled oversized (sloppy on the bolts), tentatively fitted up and then the crank spun around. By watching the pulley spin, the out-of-centre can be seen. Some gentle taps with a hammer can get the alignment closer to centralized before tightening the bolts. All up, not the best process for removing crank vibration. An alternative is to use a concentric ring (like a thin washer) between the oversized (eg SBC) pulley bore and the grey motor crankshaft. Finding the exact correct size ring (or turning one up on a lathe) is equally not that easy.
For the supercharger driven pulley, it is not too likely that a pulley will be sourced from another vehicle at the wreckers, and will instead need to be sourced from the aftermarket. Aftermarket pulleys are often sourced from industrial, rather than automotive suppliers. This means we will probably be mix-and-matching an automotive drive pulley with an industrial driven pulley. Aftermarket industrial pulley profiles are often referred to in articles about Norman superchargers (for example in Supercharge! Eldred refers to his HR Holden Type 110 supercharger being driven two ‘A’ section belts, and his Australian Grand Prix Triumph TR2 G.M. 271 supercharger being driven by four). A common specification for industrial (often referred to as “classical”) pulleys is ISO 4183:1995 Belt drives -- Classical and narrow V-belts - Grooved pulleys (system based on datum width). This aligns well with the standards used by the Mechanical Power Transmission Association (MPTA), a North American association which drives vee-belt standardization. Classical pulleys are labeled by a letter (A, B, C, D) in increasing order of width. Note that there are standard classical pulleys, and deep groove pulleys, which have different dimensions. The table below shows the various automotive and classical pulley dimensions:
The table below shows the dimensions for the various automotive and classical pulley sizes of the same rough size as an early Holden in order of pulley (and hence belt) width (perhaps a little easier to use than the table above):
From the table, we can see that if we want to mix and match automotive and classical pulleys:
• an A standard classical pulley will be closest to the original 0.440 narrow grey motor pulleys used on FE-EJ Holdens, whilst
• an A deep-groove classical pulley will be closest to the 0.600 wide grey motor pulleys used on the earlier FX/FJ Holdens.
Given that we would ideally like to utilise the common (and cheap) 11A metric automotive belt profile, this means we are hunting for an A classical pulley.
Aftermarket die-cast aluminum pulleys are available from Stenco, an Australian manufacturer based in NSW: http://www.stenco.com.au/images/STENCO-Brochure.pdf. Stenco make both tapered bore and straight bore pulleys. The Norman supercharger shafts are straight bore, with the bore diameter around the varying between .868-1”” and with a variety of keyways. When using Stenco pulleys it is likely that the pulley bore (and potentially also the keyway) will need to be bored/recut to suit the Norman supercharger. As an example, the pulley on Gary’s Type 65 Norman is a Stenco 5” 2A unit. The 2A reflects a double pulley and A-profile. I suspect that this is a part number 2A0503 whose 1” bore and 3/16” keyway were machined back to 0.890” and ¼” respectively. Note that Stenco are quite capable of producing one-off pulleys to given bore/keyway dimensions. Be wary however in measuring a Norman supercharger in that they are a delightful mixture of imperial and metric sizes – as an example, the Type 45 supercharger pulley has a 30mm bore and a 3/16” keyway.
Note that for those wishing to drag race their Norman blown vehicles under the Australian National Drag Racing Association (ANDRA) rules, the ANDRA Rulebook General Regulations indicate that cast supercharger pulleys are prohibited in ALL classes. This would negate the ability to use STENCO pulleys. The Regulations also indicate that all vehicles equipped with belt driven superchargers must be fitted with a guard to prevent fuel line damage in the event of belt loss, except in cases where braided lines are used. As an aside, the typical Confederation of Australian Motor Sport (CAMS) grey motor road racing classes (Na for Touring Cars pre-1958 and Nb for Production Touring Cars per-1965) do not allow supercharging as it was not an original GMH option… vehicle wishing to compete in CAMS events with a Norman blown grey would need to compete in Regularity events where there are not supercharger prescriptions.
In order to drive the belt, the vee-pulley must have sufficient friction with the drive belt. Vee-belts do not actually bottom-out in the grooves, but instead transmit their driving force through the side walls of the vee groove. As load increases, the belts smoosh further into the groove, increasing the contact area and hence grip. The amount of grip that we can generate with a vee-belt is proportional to the square root of the belt/pulley contact area – doubling the contact area gives 40% more grip. There are two number of ways we can increase contact area:
a) By using larger pulleys. The relative sizes of the pulleys (drive and driven) is largely determined by amount of boost required, which we have calculated below. In practical terms for our Norman supercharged grey motor, it is likely that there will be limitations on the availability of the crank pulley. This will probably then lead to using whatever crank pulley is available, then tuning the supercharger driven pulley. If we have a choice, we should aim for larger pulleys. As well as increasing contact area, the larger pulley diameters tend to flex the belt through less of an angle. This dramatically reduces belt loading and increases belt life. As a rough guide (and as noted in Supercharge!), we should be aiming for pulleys no smaller than 4” in diameter. As a comparison, the standard grey motor harmonic balancer has a 45/8” diameter, an approximately 1” bore and a 3/16” keyway.
b) By increasing belt wrap. Belt wrap is the amount (or angle) that the belt is in contact with the supercharger pulleys, measured through the pulley centerline – see image below.
The higher the belt wrap, the more contact area and better grip. Often we have little choice about where the crankshaft and supercharger pulleys are relative to each other – manifolding becomes the constraint. This means there is not much room to move the supercharger around to increase belt wrap. However, we can sometimes use an idler or tensioner pulley to increase belt wrap, as we will see below.
Whilst steel is far stronger than aluminum for supercharger pulleys, we are often likely to be limited to what is available in the market place. Chromed-steel pulleys should be avoided where possible due to the very slippery chrome surface promoting belt slip. Where aluminum pulleys are used, consideration should be made to having the groove faces hard anodized to reduce wear. Plastic is generally not suitable for supercharger pulleys, though is sometimes used for idler pulleys, and will be discussed below.
Having sorted out our belt and pulley, we can now look at tensioning it. As the supercharger drive belt is loaded, there is a strong tendency for the belt to move into a more circular shape. This phenomena is called orbiting, and can be seen by the green belt shown in the image below.
Orbiting reduces belt wrap, which in turn reduces the grip that the belt has on the pulley, leading to slippage. To reduce orbiting we can put the belt under tension in a number of ways.
In the standard Holden grey motor lineup, the engine belt is crank driven, and drives both the engine fan/water pump, and the generator. This lineup is shown in the image below.
Whilst the crank pulley and fan/water pump pulley are fixed to the engine, the generator is able to pivot about two points. By moving the generator in the direction of the blue arrow, additional tension is placed on the belt. The factory specification for belt tensioning indicates there should be 3/8” of slack between the fan/water pump pulley and the generator pulley. I will refer to this type of drive system (where one of the driven pulleys and attached equipment swings) as “swinging” in the text below.
A similar swinging drive system can be used to provide tension to the supercharger belt. If the same drive belt is used to drive each of the engine fan/water pump, the generator and the supercharger then the tension can be applied by swinging the generator. A swinging system of this type is shown in the image below.
This type of system however tends to have very low belt wrap, significantly increasing the amount of tension required to achieve a non-slip drive. Additionally, the belt is now driving a fan, a water pump, a generator and a supercharger. This is a significant amount of load for one belt to carry. For these reasons, this type of drive system is not recommended.
A different swinging drive system can be achieved if a dedicated supercharger drive belt is utilized. In this case the tension can be applied by swinging the supercharger. This type of drive system can achieve good belt wrap, lowering the amount of tension required to achieve a non-slip drive. Given the belt is dedicated to driving the supercharger, the loading is lessened (and either fewer belts can be used, the belt profile reduced or the belt life extended). However, swinging the supercharger is not without it’s down sides. The carburetor must also swing with the supercharger, which can provide some unique float bowl angles and hence additional work to attain a satisfactory fuel level. Further, the manifolding between the supercharger and the engine’s cylinder head must have sufficient flexibility to allow the supercharger to move. This can be achieved by the use of pipe, either rubber/silicon or convoluted metal. A drive system of this type is shown in the figure below, and also in the photograph below of the supercharger removed from the Bobcat custom humpy, and subsequently fitted to Anthony Harradine’s EJ Holden Premier.
Anthony’s system has a triple-groove pulley fitted to each of the crank, fan/water pump and supercharger. Two of the three grooves on these items are belted together, giving the green drive line shown in the image above. The third pulley groove on each of the crank, fan/water pump and supercharger is also run to the generator, which has a single-groove pulley. Both the generator and supercharger can be independently pivoted, providing belt tension as per the blue arrows above.
An alternative to a “swinging” drive system is to apply an idler (also known as a jockey or tensioner) pulley to the system. In this case the driven pulleys are all fixed, and the idler pulley moves to provide belt tension to the supercharger.
The “idler” drive system shown below has a dedicated supercharger drive belt(s), shown in green. The idler pulley is placed inboard of the belt.
By moving the idler pulley in the direction of the blue arrow, additional tension is placed on the belt. In this case the idler pulley runs on the vee-side of the belt, and must have a vee-pulley face. Systems of this type reduce belt wrap, increasing the amount of tension required to achieve a non-slip drive. The drive system on Gary’s Type 65, shown in the image below, has an inboard idler drive system.
The idler drive system shown below again has a dedicated supercharger drive belt(s), though in this case the idler is placed outboard of the belt.
By moving the idler pulley in the direction of the blue arrow, additional tension is placed on the belt. In this case the idler pulley runs on the back of the belt, and must have a smooth pulley face. Systems of this type increase belt wrap, lowering the amount of tension required to achieve a non-slip drive. This system is preferable to the one shown above. Note however that in this case the belt is being flexed additionally compared to the system above, which can reduce belt life. The Norman superchargers shown in the images below utilize this type of drive system.
Whilst the supercharger and crank pulley locations are often relatively fixed, there is generally more leeway to move around the idler pulley location. To mount an idler pulley, a number of options are available. These include:
a) Using a lever-type bracket directly back to the engine block (similar to the photograph of Cliff Kiss’ FED above,
b) Marking an engine plate-type bracket and mounting the idler spindle in a slot, similar to the image below,
c) Making a clamp-type bracket that clamps around the supercharger snout. This type of mounting is very typical of Norman superchargers, and can be seen in several of the images above. The image below shows the typical dimensions for a Type 65 clamp-type idler.
In terms of location, note that supercharger drive belts have a slack side and a drive side. Like a piece of rope, the crank can pull on a belt but cannot push on it. With the crank rotation as per the blue arrows in the image below, the slack side is on the driver’s side of the vehicle, and the drive side of the belt on the passenger’s side.
Where a choice is available, the idler should be installed on the slack side of the belt. This reduces loading on both the belt and the idler. The idler pulley should be located at least twice the idler pulley diameter away from the nearest other pulley. This gives the belt a chance to relax after it’s last bending, get aligned if the pulleys are not dead-true and also to pass through some air and cool down, each of which will extend belt life.
Regardless of whether a swinging or idler system is used is, the belts are under considerable duress during service. Stops, starts, acceleration and deceleration, the odd blower bang and constant vibration all add up to gradually slacken the belt tensioning. There is a trick that can both assist in maintaining tension, and also in getting the right tension in the first place. This is to utilize a turnbuckle (or similar threaded connector) to push against the idler pulley.
The turnbuckle is mounted to the engine block, preventing the supercharger, generator or idler pulley from slipping back out of tension. By twisting the turnbuckle it is also then easy to tighten the belt without using long bars to swing the supercharger, generator or idler pulley.
Plastic is generally not suitable for supercharger pulleys, though is sometimes used for idler pulleys. As a general guide, plastic is suitable to be used provided the idler is employed on the slack side of the drive loop (not the drive side), and when the belt wrap is at most 90º. Idlers operating on the drive side of the belt or with more than 90º of belt wrap should be made from either aluminum or steel. Some idler pulleys have a shoulder (or flange), such as the Kilkenny Castings KC160 pulley shown below.
The flange can help keep the belt aligned, and whilst no replacement for good setup alignment can help with minor belt misalignment. Some flat pulleys are also crowned, where the surface is gently curved at the top.
In theory this can help centre the belt (provided the initial alignment is perfect), as can be seen in the video here: http://www.youtube.com/watch?feature=pl ... sM0Qjumyro. However, practical terms for a home-built system is probably neither a hindrance nor help.
Idler pulleys are available from SuperCheap Auto as per the table below:
A single 11A vee-belt has a width of 11.2mm, and would run readily on any of above pulleys. A twin 11A pulley has an effective belt width around 25mm, which would rule out the use of the Gates TrueAlign 38015. The pulley that stands out though is the Kilkenny Castings KC160, pictured above. It has a width suitable to run either single or (most) twin vee-belts. The chromed steel look is also period correct. The pulley runs a SKF 6203-2RSH bearing, which is rated to 12,000rpm. The pulley internal bore is 17mm, suitable for an M17 bolt to be used as a shaft. M17 bolts are somewhat unusual, but have a shank diameter around 16.974mm. An alternative is to use a ¾” bolt (19.05mm) and turn the shank down to just under 17mm.
One issue that needs to be checked is the speed that the idler pulley operates at. The large diameter of the crank and supercharger pulleys will generally mean that bearings will tolerate the speeds involved. The smaller idler pulley however can often spin much faster. The pulley speed is proportional to the diameter of the idler pulley i.e.:
Idler pulley speed = crank pulley speed x (crank pulley diameter/idler pulley diameter)
As an example, the Gates DriveAlign pulleys noted above have a nominal speed limit of 8,000rpm. If we assume the crankshaft pulley is approximately the same diameter as the grey motor harmonic balancer (45/8”, or 117mm), and that we are running at a grey motor typical rpm redline of 4500rpm, then
8000 = 4500 x (117/idler pulley diameter)
, and we see we can go down to an idler pulley as small as 66mm diameter without any speed concerns (i.e. each of the above pulleys would be OK). Checking the Kilkenny Castings KC160,
Idler pulley speed = 4500 x (117/82) = 6420rpm
This is well below the 12,000rpm pulley speed limit, again making the Kilkenny Castings KC160 an ideal candidate.
Regards,
Re: Harv's Norman supercharger thread
Supercharged by Norman.
Manifolded by Malaby.
Ressurected by Harv.
Just a tease for now - more notes on the manifold etc once the allignment is sorted out... just sitting there very rough for now.
Looks great Harv, but I don't think the belts are up to the job ......... :shock:
You'll hear me swearing come Christmas time when I go to put the tent up and find the rope is 10' too short :lol: .
I had to cut the rope up anyway... Dave reckons my car trailer tie-down process is too complex :mrgreen: .
As noted in some of my earlier posts, I am pulling together a Guide for Norman superchargers. Whilst the Guide has a strong technical content, it will also contain a number of Norman supercharger-related anecdotes. I have previously posted two of the stories – one on a twin-supercharged Elfin land speed record holder, and one on speedway Normans. I have also been pulling together an anecdote on Eldred Norman, which I will now share below. Any errors in this anecdote are mine. Apologies in advance if I have failed to acknowledge the owner of any of the information – happy to correct (or delete) as requested. So here goes – hopefully an interesting story. Please bear in mind that I have written it for an audience interested in early Holdens, and who (like me) may not know what a monoposto is (I learn something every day).
1. Foreword, Forewarning and Thanks.
In the anecdote below I will try to paint a picture of an Australian character who was larger than life – Eldred Norman. I will focus on Eldred’s mechanical exploits, but also try to paint a picture of the times that he lived in and the people surrounding him. I will give some of the history of the vehicles Eldred campaigned, both prior to and following his ownership. I apologise in advance in that it can be hard to follow a timeline in the material below… Eldred would be racing a new vehicle while people were still campaigning his old one. I have roughly broken the story up by the vehicles he drove to try to help this.
I owe a huge thanks to Ray Bell for allowing me to use the information in the article he wrote about Eldred for Motor Racing Australia magazine (http://www.motorracingmag.com.au/). I have drawn quite a few facts from the article, and in some cases have directly quoted it, particularly where Ray has captured the spirit of the issue far better than I could.
Having said that, the information noted below is based on a variety of material, including that written by Jon Chittleborough in the Australian Dictionary of Biography, National Centre of Biography, Australian National University, an obituary written by the late John Blanden, a collation of anecdotes drawn together by Ken Messenger for the Sporting Car Club of South Australia magazine in the early 1980’s, an article on the Zephyr Special written for the Australian Motor Sports Magazine of February 1960, and an article written by Ted Robinette for his Technical Workshop column in issue 258 of Australian Street Rodding magazine. I would like to particularly thank both Patrick Quinn from Vintage Racecar magazine (http://www.vintageracecar.com) for access to the article he wrote on the Zephyr Special for the February 2007 edition of the magazine (not to mention educating me on Valano Specials… but that’s another story).
I have also drawn material from a wide variety of online sources, with thanks to several forum members who have corrected my appalling knowledge of circuit racing. Eldred was a frequent occupier of column space in many newspapers, and in particular Adelaide’s Advertiser. The National Library of Australia online files recording this era are outstanding resources – see the image below of Eldred in his late 30’s perched in his Maserati, taken from an (Adelaide) The News article of September 1952.
The article celebrates Eldred winning the Sporting Car Club of South Australia’s Morgan Trophy, awarded by the Morgan Motor Co Ltd UK for the most successful (top aggregate points) in speed events (races and hillclimbs). Eldred would also win the R.J Kennedy Perpetual Trophy for the leading club competitor in motor sporting events in that year. I have also drawn material from With Casual Efficiency, written by Dennis Harrison. This book chronicles the history of the Sporting Car Club of South Australia, which awarded Eldred the two trophies above. A special thanks also to Terry Walker for his excellent online recording of Western Australian race history, to Graeme Snape for braving a cold shed to take measurements on the Zephyr, and to Toby Carboni for having the patience to talk me through some of the Double Eight’s history.
A word of warning regarding the information below, most notably the anecdotes. Eldred was a particular larrikin, and stories of his exploits are legend. As one commentator has posed:
“One of my favourite Eldred stories occurred when I was driving up to a Port Wakefield race meeting at a sedate 70 mph and being passed by a tow car and trailer complete with Eldred sitting nonchalantly on the trailer mudguard doing up the exhaust manifold nuts on his Maserati race car as they whizzed by.”
Many of the people who witnessed the events below have sadly passed away. It has also been nearly a century since Eldred was born. In the eighty years of time since Eldred starting making his story some of the anecdotes have “matured”. Caveat emptor.
2. Eldred’s History, and Family
Eldred De Bracton Norman was born on the ninth of January 1914 in Adelaide, South Australia. He was the second of six children of Australian-born parents William Ashley Norman, solicitor, and his wife Alma Janet, daughter of Daniel Matthews. Eldred’s father William dabbled on the sidelines of building caravans for sale and hire. Thomas Magarey, an Irish-born miller and pastoralist and Member of the South Australian House of Assembly and the South Australian Legislative Council was Eldred’s great-grandfather. Eldred’s brother, Murray, was later to be killed in a motorcycle accident, tempering Eldred’s passion for two wheeled machines. Eldred attended Scotch College Adelaide and studied law at the University of Adelaide for four years, driving a Bentley during his student days. His 1934 exam results for Psychology are still available from the online version of the Advertiser (Eldred passed with Credit). In 1938 Eldred set up an engineering workshop and motorcar-dealership in Halifax Street Adelaide. Rejected for military service in World War II because of asthma and flat feet, Eldred drove taxis, then began to make garden tools and to manufacture charcoal-burning gas producers to power vehicles. His Ace Gas Producer was unique in providing cockpit controlled lighting.
Eldred was to meet (and in May 1941 to marry) Nancy Fotheringham Cato, a 24-year-old cadet journalist working at Adelaide’s The News newspaper. Nancy was born in Glen Osmond in South Australia on the eleventh of March 1917, and was a fifth-generation Australian. She studied English Literature and Italian at the University of Adelaide, graduating in 1939, then completed a two-year course at the South Australian School of Arts. Nancy’s The News cadetship lasted from 1935 to 1941.
As noted in Ray’s article:
“They met one night when, at a gathering, Eldred was playing “Tell me Tonight” on the piano. Nancy had two suitors, one holding each hand, but the strikingly attractive young woman only had eyes for the pianist”.
The vehicle taken by Eldred and Nancy on their honeymoon was fitted with one of Eldred’s Ace Gas Producers. The couple invested £6 for charcoal for the journey, with Eldred stopping along the route to Queensland, axe in hand, to top up on charcoal from the bushfire stricken roadsides. Eldred and Nancy had three children in the space of three years – Michael, William and Bronley (Mike, Bill and Bronnie). In filing out one of the children’s birth certificates, Eldred listed his occupation as “retired”, and his hair colour as “burnt umber”.
Bronley, pictured below with Eldred and Nancy, was born in 1943 and started writing while still in primary school.
She was educated at the Presbyterian Girls' College from 1949 to 1960, then trained at the Adelaide Kindergarten Training College from 1961 through 1963. She worked in kindergartens and nursery schools in Australia, England, the United States and Canada before deciding to leave teaching. She worked in the tourism industry for a while and lived at Tewantin, Noosa, working for Telstra and writing plays. Bronley began writing seriously in 1980, mainly one-act plays. Several have been staged by Little Theatre groups. Bronley became a member of Playlab (one of the largest theatrical publishers in Australia and the only professional organisation that works across the lifecycle of play – from initial idea to the stage, and on to the page) in 1985. Bronley’s drama works include Cyclone Warning (1980), The Girl in Green (1983), Nineteen Eighty-Three (1984), Eliza Fraser (1986), The Hand of Fate (1987), Letting Go (1989), Travellers (1994), A Game of Chance (1994) and Jessie Who (1995). Bronley co-authored I remember when ... : a social history of the Nambour Manual Assistance Centre (1990). Bronley’s work A Game of Chance also appears in the second volume of the anthology Noosa One-Act Winners (1994), which also contains her mother’s work Travellers Through the Night.
Bill Norman, pictured below, has followed a number of trades, including journalism (authoring for example the Motor Sport column in the Canberra Times in the late 1960’s), Sydney based manufacturing and farming.
Where Bronley followed her mother’s passion for literature, Bill inherited his father’s love of racing. Bill started racing at Mallala Race Circuit South Australia in a Standard 10 aged seventeen, winning his first race due to a handicapping mistake. He moved on to Steve Tillett's 1947 MGTC Special which had won the 1951 Australian Grand Prix on handicap. Bill took the MGTC to outright fastest position at the Canberra Sporting Hillclimb at Lakeview, Australian Capital Territory in 1965, running 22.1 seconds against a field of twenty-nine vehicles. Bill’s passion for racing has seen him own vehicles including a homemade Nissan Clubman TC2, a Mallock U2 powered by a supercharged &*#@ Cortina engine and a Reynard 92D Holden V6 F4000.
Mike Norman inherited his father’s pragmatic engineering skills. Having left home to go fishing, Mike later moved into an engineering role, operating Offroad Automatics Pty Ltd at Magowar Road in Girraween, Sydney. Whilst the business was involved in fitting automatic transmissions to Range Rovers, Mike also commenced manufacturing superchargers, as we will see below.
3. The Bryant Special – an introduction to twin V8s.
Eldred’s motor vehicle forays began at around the age of five at Port Noarlunga, a suburb in the city of Onkaparinga, South Australia. Having been left for a short period in a Stanley Steamer (similar to that shown in the image below), Eldred managed to crash the vehicle into a wall.
In (much) later years (sometime between 1936 and 1937) Eldred purchased the Bryant Special, shown in the image below.
The car had been built by Max Bryant of Clare together with Peter Hawker in 1934, and was also known as the Bungaree Bastard (Bungaree was the name of the sheep station in the north of South Australia established in 1840 by Hawker’s grandfather George Charles Hawker). The Bryant Special had two Essex four cylinder engines coupled together, a format that probably influenced Eldred’s construction of the Double Eight in later years. The Essex engines in the Bryant Special were likely to either the 2371cc "L-head", though potentially also the earlier 2,930cc "F-head” (both engine types were rated at 55bhp). The engines are believed to have been sourced from Norman “Wizard” Smith, albeit in single format. Smith held records for travelling between major cities and was an incredible autosportsman. He also worked for Dalgety & Company, Sydney agents for Essex cars around 1920.
In Bryant and Hawker’s hands the Bryant Special was driven at Sellick’s Beach (30 miles south of Adelaide) for the Sporting Car Club of South Australia’s Grand Opening Speed Meeting on Labour Day 1934. Bryant and Hawker also drove the vehicle at Buckland Park Beach (15 miles north of Adelaide). The Buckland Park Beach course was typically an oval lap, some two miles long with Hawker holding the lap record in late 1935. Hawker attempted to establish a national speed record in January 1935 in the Bryant Special at Buckland Park Beach (see image above right from the Advertiser of 29th January 1935), and held a novelty race against a Tiger Moth airplane (the plane lost due to headwind). The Bryant special was capable of 90mph on the sand, and could readily average 70mph over a two-mile course. With Casual Efficiency notes that on February 2nd 1935 Hawker attempted a national speed record at Sellick’s Beach, in the A class (unlimited). Being a flying start he crossed the start line at some 110mph, though a puff of blue smoke before the end of the course revealed that No.8 piston on one of the engines had failed. This effort was captured in Perth’s Sunday Times the following day. The Essex was also campaigned at the Sporting Car Club of South Australia’s first hillclimb at Newland’s Hill, Waitpinga in April 1935. Unfortunately, it broke a tailshaft and stripped second gear, reported by the press to demonstrate “it’s unsuitability for hill-climbing”.
By 1937 the Bryant Special was in Eldred’s hands. As reported in the Advertiser on the 8th of March 1937 under the banner “SPEED RACING AT BUCKLAND PARK”:
“Interesting motor cycle and motor car racing was presented by prominent speedmen at Port Gawler beach. Buckland Park, on Saturday afternoon. The non-appearance of E. Normans 'Bryant Special' robbed the car events of much interest. He had trouble with the car on the way to the beach.”
… and from the Advertiser on the 13th of April 1937 under the banner “SPEED METING AT BUCKLAND PARK”:
“Anzac Holiday Events
Entries for the Sporting Car Club events at the Anzac Day holiday (April 26) speed meeting arranged by the Southern Cross Motor Cycle Club at Buckland Park will close next Tuesday with the club secretary (Mr. G. L. Morris), or at the club's office in T. and G. Building. There will be two events, a six-mile handicap and a 20-mile handicap. Entrance fee for each race will be 2/6, and all competitors must hold A.A.A. licences. Minimum prizemoney will be: Six-mile, £1 and 10/; 20-mile. £2, 25/. and 15/. It is expected that the Miller car which was imported for the Grand Prix will be raced by its owner. Mr. Eric Morgan, and that the double-engined Essex car, previously owned by Mr. Peter Hawker, will be raced by Mr Eldred Norman. This car holds the fastest lap time ever registered at Buck- land Park. It averaged 71 m.p.h.. at the meeting conducted by the Sporting Car Club in January, 1935.
A post-meeting report from the Advertiser on the 27th of April indicates that tides cut the event short, and reports only results for motorcycle racing.
4. The Double Eight – a twin V8 monster from Army surplus
In 1946 Eldred was purchasing ex-army vehicles left behind by the Americans for Bill Hayes and returning them to Adelaide. He partnered with Ron Mann, a friend from his university days to make two trips to the Australian Territory of Papua-New Guinea (PNG did not become an independent nation until 1975). A 7,000-ton ship was chartered to carry home the vehicles from the Port Moresby auctions. Tasked with getting six of the trucks between Darwin and Alice Springs at a time, Eldred connected them road-train fashion with timber poles and drove them himself without sleep. In hilly country the sixth truck was started, otherwise only the lead truck pulled.
During one of the trips (which brought home fifty-five jeeps, around forty Blitz trucks and numerous generating and welding plant – see photo below) Eldred acquired a war-surplus Dodge weapons carrier chassis. This may have been the ½-ton VC series, or later WC series of military light trucks.
Eldred used the Dodge to construct a race car - the “Double Eight” (sometimes referred to as the Double V8, Bi-Mercury or Double Bunger). Eldred’s Double Eight, shown below with Eldred in the cockpit, was built from bodywork from aircraft and a tubular steel chassis with four-wheel independent suspension. The initial configuration, as shown in the image below, was a two-seater though the vehicle was to have several changes to bodywork over the years.
Power came from two &*#@ Mercury 239ci side valve flathead V8 engines for a total capacity of 7,800cc. These engines were good for 100-110bhp each when run independently, giving Eldred some 200bhp in the Double Eight.
Whilst weighing in at a hefty 2500lb, the Double Eight had a power to weight ratio two and a half times greater than an FB/EK Holden. The Double Eight also had radiators, with one mounted up front and the other at the rear behind the driver. Despite the radiators, engine cooling suffered, with a tendency to overheat on long races. The engines were coupled flywheel-to-crank snout with a double-row Renold chain. The engines were timed to fire as a V16, with a Scintilla magneto providing spark. This large machine had water-cooled drum brakes supplied by four US-made Toronto fuel pumps. The drum brakes produced spectacular clouds of steam as Eldred applied them (the water activated by a switch on the brake pedal), despite being undersized for the task. The rear brake drums were built inboard, operating on the back axle and additionally cooled by a fan worked by the tail shaft. The Double Eight was fitted with truck wheels, which were later drilled out (presumably to lighten them). The wheels would come under some scrutiny at an Australian Grand Prix, as we will see below.
Being South Australian road-registered, Eldred was frequently seen driving the Double Eight around the Adelaide hills… with trade number plates tied with string or a strap around his neck. During road testing of the Double Eight on the Port Wakefield Road beyond Gepps Cross a faulty steering pitman arm caused Eldred to pull into a service station. With the car up on the hoist it was evident that the spanner being used was a good fit. The spanner was welded into position and the car returned to service. Between 1948 and 1951 he drove the car successfully in hill-climbs and various race tracks in three States. The vehicle was also driven long distances to compete at tracks such as Fisherman's Bend, Victoria… a 900-mile roundtrip journey, sans mufflers.
The clipping below, from the News of the 19th of April 1949, shows the Double Eight at the Barossa Festival (Nuriootpa circuit, South Australia).
The clipping below is from the News of the 8th of October 1949. The meeting referred to at Woodside, South Australia was the scene of a tragic double fatality during motorcycle
races.
The Double Eight was also raced at Fisherman’s Bend later in October of that year.
In addition to circuit racing, Eldred raced the Double Eight at Sellick’s Beach, South Australia where racing was undertaken between mile posts. An annual speed trial and motorcycle races were held on three kilometres or more of sand along Aldinga and Sellick’s Beaches up to 1953. The Double Eight won both the unlimited scratch race and over 1500cc handicap race held at the beach by the Racing Drivers Association of South Australia in April 1950. This event drew more than 5,000 spectators. One Sellick’s Beach incident involved Harry Neale at the wheel of the Double Eight. The incident started with a fire and ended with the Double Eight deposited into the sea, ripping off the bodywork and leaving Harry sitting on the chassis, wet but unhurt – see clipping below from the Broken Hill Barrier Miner of the 2nd of May 1950.
This is likely to be the same event as that depicted on the cover of Australian Motor Sports Magazine of June 1950 (see image below), which depicts Harry behind the wheel of the Double Eight at Sellick’s Beach. Harry (also known as the “Black Prince” as he drove in black trousers, pullover and helmet) was six-times Australian Speedway Champion, and sadly passed away at Claremont Speedway in 1959.
Eldred’s can-do, larrikin spirit was also evident in the way he once retrieved the telephone cables laid out for communication between officials at each end of the Sellick’s Beach strip… by fitting a bare rim to the Double Eight rear axle and firing up the twin V8s to power what must have been Australia’s most powerful fishing reel.
The Double Eight was also campaigned in hill climb service, and was entered in the South Australian Hill Climb Championship at Glen Ewin, Houghton in March 1950. On the day Eldred’s was the fastest car. The image below, taken From With Casual Efficiency, shows the Double Eight at this meeting (the image is labeled as 1948 in the text, though I believe that to be an error).
The Double Eight marked the start of Eldred’s entries into the Australian Grand Prix. The 34-lap January 1950 Australian Grand Prix was a Formula Libre motor race held at the three-mile square layout clockwise street circuit in Nuriootpa, shown below.
Formula Libre (or “Free Formula”) allows a wide variety of types, ages and makes of purpose-built racing cars to compete "head to head", with the only regulations often governing basics such as safety equipment. Eldred’s Double Eight was driven by Harry Neale, came 5th in the over 1500cc championship, though retired from the Grand Prix after only two laps. Bear in mind however that only thirteen of the field of twenty-nine vehicles actually finished. The image below shows the Double Eight at the 1950 Grand Prix.
Eldred entered the Double Eight in the Onkoparinga class handicap at the Woodside circuit in October 1950, coming second place by one minute despite having speeds of up to 120mph on the straight. The Double Eight was also entered (and took third place by 3.6 seconds slower than first place) in the Western Australian Hill Climb Championship at Mundaring in February.
The 1951 Australian Grand Prix was again run as a Formula Libre event in March at Narrogin, Western Australia. Getting the #10 Double Eight across to Perth proved to be a challenge. Eldred travelled with Steve Tillet, who was also entering his MGTC in the Grand Prix. The MGTC was loaded onto a truck, and a trailer fabricated to carry the heavy Double Eight. The trailer had eight pairs of small dual wheels. Whilst unused, the trailer tyres were old, with many being consumed during the journey. The truck turntable also failed, which Eldred welded up using locally sourced fencing wire. This repair was faster than one driver they passed who had been waiting three weeks for an axle to arrive.
The 4.4-mile anticlockwise Narrogin circuit is shown below.
Eldred won one of the races early in the day before lining up for the main Grand Prix event. The bodywork of the Double Eight had been drastically changed prior to this race, turning it into a single seater and reducing weight. Additionally, holes had also been drilled in the truck wheels. The Double Eight is shown at this meeting in the two black and white images below, taken by Len Moore.
While leading on the seventh of twenty-four laps the Double Eight again broke down (this time due to suspension failure with the front axle locating rod coming adrift), leading to Eldred retiring from the race. Laurie Bug was Eldred’s mechanic, and travelled to Narrogin with Eldred for the event. Laurie saw the failure, and realized he had been working on the suspension prior to the race. Knowing Eldred’s volatile temperament, Laurie made himself scarce for the rest of the day.
The photo below shows the #10 Double Eight at the meeting.
Steve Tillet (pictured in the image below) went on to win the Grand Prix on handicap, with his MGTC later purchased by Eldred’s son Bill (see below).
The Double Eight was sold by Eldred later in 1951 to Syd Anderson. Anderson was proprietor of the Sydney Anderson Automotives used-car dealership in William Street, Perth and once Western Australia’s largest hire fleet owner with some thirty cars. During both Anderson’s and subsequent ownerships the car was modified repeatedly. According to legend, Anderson swiped a large mixing bowl from the kitchen, cutting it in half to make two air scoops for the Double Eight.
Anderson raced the Double Eight extensively, including the following West Australian meetings:
• The Great Southern Flying 50 meeting at Narrogin in March of 1952, winning the scratch race for over 1500cc (Eldred’s Maserati, see below, picked up the under 1500cc win), and coming eighth in the meeting main race (Eldred came second). Anderson can be seen in the #2 Double Eight in the photo below. The photo is labeled as Narrogin in 1952, though Eldred’s Maserati appears absent. The driver lineup, using Terry Walkers race results appears closer to Caversham in 1953.
• The Northam Flying 50 meeting at Northam in April, winning the three-lap scratch race for over 1500cc. Anderson also competed in the five-lap handicap but did not land in the top three positions. He did however place fifth in meeting main race.
• The Goomalling Speed Classic at Goomalling road circuit in June. Anderson placed the Double Eight fourth in the fifteen-lap handicap for Racing Cars, first in the three-lap scratch race for Racing Cars over 1500cc and first in the five-lap handicap race for Racing Cars. Anderson is shown driving the vehicle at the 2.4-mile anticlockwise circuit in the colour photograph below. The Goomalling circuit layout is shown below the photograph.
Image[/URL
• The Great Southern Fifty meeting at Narrogin in March of 1953, winning the three-lap scratch race for over 1500cc (Class A) and the Sports Car open handicap. In the race Anderson battled Sid Taylor in his TS Special and Sid Negus with his Plymouth. For several laps the drivers moved up the field but did not alter then positions with each other. Finally Anderson, the only driver off scratch, overtook Negus and almost headed Taylor. They finished together. It was in this lap that Anderson clocked 1 min 40 sec for the lap, an average of 80 mph for the circuit. The image below shows Anderson at this event, and receiving laurels at the meeting.
[URL=http://s929.photobucket.com/user/V8EKwagon/media/Andersonflattyre_zpsde08248d.png.html]Image
The images below show Anderson campaigning the Double Eight at this meeting (and on the same corner chasing an MG in the second image).
• The Caversham Speed Classic in December of that year, winning the three-lap scratch race for racing cars over 1500cc, placing second in the five-lap handicap for racing cars and third in the twelve lap handicapped main event for racing cars.
Anderson also competed in speed trials in the Double Eight. At Narrogin Airstrip in February 1954 he recorded the fasted time for the Standing Quarter for Racing Vehicles at sixteen seconds, and also for the flying quarter at 8.9 seconds.
Anderson entered the Double Eight in the Johore Grand Prix in Malaya in 1953. The race was not held in 1954 due to concerns raised by the Johore Welfare Committee, a part of the state government, and would not be held again that decade. This was the first time that an overseas entrant and vehicle had entered the Johore Grand Prix. Anderson can be seen in the image below, together with Neil Moncrieff's 1100cc Cooper JAP twin (for the curious, JAP stands for JA Prestwich Industries, an English precision engineering company which produced engines from 1895-1963, often used in racing).
Unfortunately, Anderson had to retire from the race due to overheating. Freddy Pope (then president of the Singapore Motor Club) was the winner in the #22 Jaguar XK120S.
In one incident during his ownership of the car Anderson was badly scalded when the radiator plumbing in the cockpit let go. At some stage between 1953 and 1955 Anderson ceased racing the Double Eight.
The next person to campaign the Double Eight was Toby Carboni. Carboni was a seasoned racer, having competed in the 1954 Redex reliability trial in the #254 &*#@ Customline at the age of 20 (though Carboni travelled from Sydney through Townsville to Darwin then Perth, he did not finish). Carboni also raced stock cars in the 1950’s at Claremont Speedway, and owned the ex-Potter and Winters "Vandal" Top Fuel car (a 1963 Plymouth Super Stocker known locally as the “Ramcharger”). Carboni would later found Perth’s Carbon Brakes with Greg Nolan, along with five other successful businesses as diverse as a Cleenaway operation and a spaghetti factory.
After racing in the Redex, Carboni was working for his brother’s truck repair business. He was tasked to take a six-wheel drive GMC truck to Syd Anderson’s business in William Street Perth to pick up a vehicle. Whilst finalizing the hook-up, Anderson appeared in a business suit, offered Carboni his business card and a job as a manager any time he wanted one. Carboni took the GMC back to his brother, returned on a motorcycle and took the job as foreman. Interestingly, Anderson had failed to mention to the old foreman that they had a new one… which became apparent when Carboni arrived for his first day of work! Not long after starting, Carboni noted that Anderson had the Double Eight tucked away in the rear of the yard under some sheet metal. After some discussion, Anderson told Carboni that provided he could get it going, he could use the Double Eight for races… as long as he didn’t beat Syd!. Carboni towed the car back to his home, and repaired it. He was then granted a permit to drive the car to work and back each day – all the way across the city of Perth!
In the period of 1955-1957 Carboni raced the car extensively in Western Australia. The images below show Carboni in the Double Eight.
Carboni remembers racing against Anderson at one track, and waving to each other as they progressed. Anderson lost control, skidded off the course and crashed, with his helmet seen to go flying. Carboni approached, fearing the boss had been decapitated due to his waving. Anderson was non-plussed, telling Carboni to get the Double Eight ready for the next race – and he had better win it! He can also remember spinning the car off the track through gravel at Busselton, convincing the boss he was racing as fast as he could.
Carboni entered the Double Eight in the following events:
• The Northam Flying 50 in August of 1955, placing sixth in the seven-lap racing car handicap (Anderson was racing an Austin Healey in that race and came fourth – luckily Carboni did not beat the boss). Carboni also entered the three-lap scratch race for racing cars over 1500cc though did not finish.
• The Western Australian State Championships in September. In the first heat of Race 1 of the Racing Car Championship, Carboni placed fifth (Anderson’s Austin Healey coming in third). Returning for the second heat of Race 3, Carboni retired after seven laps (Anderson winning this race).
• The Caversham Benefit Cup in October, placing fourth in the three-lap racing car scratch race.
• The Spastic Welfare Cup at Caversham in November. Carboni entered the six-lap handicapped Race 2 though retired after two laps. He returned for the twenty-lap handicapped Spastic Welfare Cup for Racing Cars but again retired after ten laps.
• The six-hour Le Mans Production Car Meeting at Caversham in May of 1956, placing second in the three-lap racing car scratch race and second outright in the fifteen lap Triangle Cup scratch race for Racing Cars (though not in the top four handicapped places). Carboni also raced in the main six-hour event in a Holden (with his brother Vince), placing fourth (he returned in an Austin Healey for 1959).
• The 152-mile Australian Grand Prix at Caversham in March of 1957. Carboni entered the Double Eight in the class for Racing Cars, and was gridded between Syd Taylor in the 3.8L Plymouth Special and Syd Negus in the GMC-powered TS Special. Anderson noted the grid position, and mentioned to Carboni that he should be careful, as Taylor and Negus were his mates. Carboni queried Anderson – what do you mean mates? This is a race! Unfortunately, Taylor and Negus viewed that the wheels and tyres on the Double Eight were not appropriate to racing, and raised a protest with the circuit officials. The protest was supported, and Carboni was not allowed to start.
By mid 1957 the racing game was changing, with cars coming under increased scrutiny. Being constantly under the microscope made racing the Double Eight difficult, and Carboni ceased campaigning the machine. The colour image below shows the car chasing Sid Taylor (in a TS Special) and Syd Negus (in a Plymouth) off the straight at Caversham, and is likely to be either the 1953 Caversham Speed Classic (Anderson at the wheel) or the 1955 Caversham Benefit Cup (Carboni at the wheel).
The Double Eight was then sold by Anderson to James Harwood, a navy veteran, musician and motor enthusiast in Perth. Harwood tossed a penny with Anderson to decide the purchase price - either £50 or £100. Harwood won. The vehicle was then towed to a business in which Harwood was a partner - Performance Cars at 173 James Street Perth where Bill Strickland (the renowned sports car and speedway speedcar/modified sedan driver) removed the two &*#@ V8 engines. The engines were later sold to a speedboat constructor. The Double Eight body was then placed outside Harwood’s business as advertising, though was removed a few days later at the request of Perth City Council.
Keith Windsor bought the Double Eight body (probably in 1957) and installed a V12 Lincoln Zephyr engine, shown below.
Lincoln produced these engines from 1936-1948, ceasing production nearly a decade before Windsor’s repowering of the Double Eight. I’m not certain if Windsor used the 267ci, 292ci or 306ci engine (110-130bhp), though in any case was a marked reduction from Eldred’s 478ci (~200bhp) twin V8 powerplant. The images below show Windsor and the #20 Double Eight in V12 format.
Windsor debuted the V12 Double Eight in the Christmas Cup at Caversham in late November 1958, competing in the five-lap racing car scratch race for over 1500cc, though did not place in the top three positions. Sadly, Windsor found the V12 vehicle was not manageable and subsequently scrapped it.
The image below is of the Double Eight, though I am not sure of the period or location (the vehicle appears in single seater format, so probably 1950 or later).
5. The Maserati 6CM – a gentleman’s car re-engined from scratch.
After the Double Eight, Eldred then bought a 1936 Maserati Type 6CM. The vehicle is shown below during part of its later life in Europe, and has a layout similar to the line drawing.
6CM stood for 6-cylinder monoposto (monoposto is a fancy Italian way of saying single-seat). The vehicle was fitted with a twin overhead cam 1493cc engine (shown below), with the GM Roots supercharger driven directly off the crank and being fed by a Weber 55AS1 carburettor. Eldred’s vehicle (chassis 1542), one of only twenty-seven built, had some 175bhp on tap… a power to weight ratio four times greater than an EK Holden.
The Maserati had originally been delivered to Franco Cortese in April 1937. It then went to Scuderia Torino and to Ecurie Auto-Sport for de Graffenried and Balsa after World War II. It was later sold in the United Kingdom to Sam Gilbey (1947), then to Colin Murray (1949). Murray raced the vehicle in the Formula 1 class, including:
• The April 1950 Goodwood circuit race,
• The June British Empire Trophy at the Isle of Man circuit. He vied against a thirteen car field, though retired after nineteen of the thirty-six laps due to an accident,
• The August Silverstone race. He again retired, for reasons unknown, from the field of nineteen (which included Juan Manuel Fangio and Stirling Moss).
Murray brought the car to Australia in 1951, racing it in the March 1951 Australian Grand Prix. Like Eldred, Murray did not finish the race, completing nineteen of the twenty-four laps against a field of twenty-eight (remember that Eldred, in the Double Eight, completed only seven laps during this race).
Murray (who is shown in the photograph below under the bonnet of the Maserati at the 1951 Australian Grand Prix) sold the Maserati to Eldred.
Eldred built from scratch a new engine block from steel blocks and welded sleeves with hard chromed spun-steel liners, cast two new magnesium bronze cylinder heads with hardened steel inserts and revised valve geometry, adapted connecting rods from a Singer 1500 (purchased by Jim Gullan in the UK and air freighted over), pistons from a BSA motorcycle and reconditioned the rest of the engine. Reading through what Eldred built from scratch shows an incredible engineering feat… and essentially a new engine (the Maserati crank was however salvaged). Eldred’s engine delivered 200bhp at 6,000rpm from the newly engineered engine, four and a half times higher power to weight than our EK Holden.
Nancy was concerned with Eldred’s health during this feat of engineering, working long nights in the cold shed. She admonished him
“For heavens sake, Eldred, bring it inside and work on it. You’ll die if you keep working out there every night!”.
The next day Eldred removed the dining room window, lifted the engine inside by a crane and worked on it each night… on the large, French polished dining table given to them as a gift by a friend. As Nancy later recalled:
“How could I complain. After all, I had burnt it (the table) with the iron!”.
Eldred circuit-raced the Maserati in the 10½-mile race held at the Woodside closed-street circuit in October 1951. The course route is shown below.
Some overnight welding work by Eldred saw a chipped second gear tooth replaced in the gearbox of Stan Jone’s Maybach I. Eldred finished the Woodside Jubilee for High Powered Cars race in third position, with his gearbox repair taking Jones’ Maybach to second place. After finishing the race Eldred stopped in the pits, raised his bonnet, and with a pair of pliers released two tins of pork and beans that had been wired to the exhaust manifold to cook. Eldred’s culinary skills were noted in Adelaide’s News The Odd Spot column. The vehicle was also planned to be raced at the Lobethal, South Australia street circuit in December of 1951, though South Australian cabinet came to the conclusion that “Highways or roads controlled by the Highway Commissioner will not be closed for such events”.
Similarly to the Double Eight, the Maserati saw service in a variety of forms of motorsport. In December the Maserati was entered in the 460-yard Glen Ewen hillclimb at Houghton, South Australia recording the fastest time, breaking the previous hill climb circuit record and winning the meeting’s Unlimited class race. The vehicle was crashed in the March 1952 hillclimb at Collingrove, South Australia, stripping the gearbox in the process. This made for hard work in preparation for the Great Southern Flying 50 at Narrogin, Western Australia a week later. Eldred did however manage to get the Maserati back into working order and 1700 miles across to Western Australia. He achieved first place (and fastest lap at 2:27) in the under 1500cc scratch race, third place in the five-lap handicap race (posting both the fastest time and fastest lap at 2:20), and second place in the main handicapped Great Southern Flying 50 race event (again posting fastest time and fastest lap at 2:19). Remember from above that Anderson had also entered the Double Eight at this meeting – see the clippings below from the West Australian from the 14th and 22nd of March 1952.
The Maserati also got a work-out in March 1952 for the public opening of the Collingrove Hill Climb track (see clipping below from the Sunday Mail of March 1952 and track layout).
Eldred posted the fourth fastest time of the day (43.2 seconds), and won the category for Racing Cars over 1500cc and all supercharged. Nancy would also compete in this event, which was one by Judy Rackham in an MG TC.
The clipping below is from the News of the 21st of July 1952.
Whilst campaigning the Maserati, Eldred also drove other vehicles. In May of 1952 he won the South Australian Sporting Car Club's reliability night trial in a Holden. Only eleven of the twenty-two starters finished, with Eldred losing 580 points over the ninety-mile course, returning at 1am. In a normal trial of this kind, the winner would have lost 30-40 points and got home by about 10.30pm.
Eldred raced the Maserati in the April 1952 Australian Grand Prix. This was again a Formula Libre motor race, held at the 3.8-mile anticlockwise Mount Panorama Circuit near Bathurst, in New South Wales. The course is shown below, along with a blurry image from the Advertiser of April 8th 1952, shows the Maserati prior to the race.
Eldred did not finish the race, completing ten of the thirty-eight laps due to engine troubles (the Maserati’s supercharger relief valve had come unscrewed). Eldred’s race-mate, Frank Kleinig, had to retire his Kleinig-Hudson 8 Special after only four laps. Kleinig’s name will be familiar to early-Holden fans as the man responsible for quite an array of grey motor speed equipment.
Several articles indicate that Eldred’s ownership of the Maserati sowed the seeds of a lifelong contempt for small capacity engines with multiple camshafts, a view that is likely to make many early Holden enthusiasts smile. The noisy supercharged Maserati was never very fast, and had an insatiable appetite for pistons, including melting one out at Sellick’s Beach in October of 1952. The photo below shows Eldred (on the left) racing the Maserati on Sellick’s Beach (alongside Tom Hawke’s #5 Allard on the right) at this meeting, the first all-car beach program held in South Australia after the war. Tom Hawkes (who usually ran under the banner of 'Ecurie Corio') was from Geelong, with the Corio name coming from nearby Corio Bay.
Bill Norman remembers being employed at age six to tightening the Maserati engine's many inaccessible nuts, one-sixth of a turn at a time.
By 1953 the Maserati had been twin-supercharged, adding a second-hand Arnott supercharger to the existing GM Roots machine to deliver 285bhp,. The Arnott supercharger sat in the cockpit under the scuttle. The first supercharger remained crank driven, with the second supercharger duplex-chain driven off the first (that is one looong drive chain, running the length of the engine).
The car was being tested at the Collingrove hill-climb on Easter Monday. The vehicle would not run under 40mph, was good for 0-120mph in ten seconds, would stay at 120mph at half throttle, got 80mph in first gear and slurped methanol at one mile to the gallon. The power to weight ratio was now six and a half times greater than an EK Holden.
The vehicle returned to Port Wakefield, South Australia for the Anzac Day race of April 1953, the Official Programme of which noted:
“Eldred is never one to let the grass grow under his feet or the Maserati’s wheels”.
The clipping below is from Adelaide’s Advertiser of the 6th of October 1953, again linking the Maserati to Collingrove hill climbing.
Eldred also raced at the Port Wakefield Tourist Trophy race that month, snapping the gear lever off the Maserati and finishing in third gear at 9,000rpm (the redline was 7,000rpm…) despite suffering badly from hay fever. A race report from one of the Gawler Airstrip meetings indicates that “Eldred Norman drove a steady race in the Maserati, stopping once to admonish two small boys who were too close to the track”.
Alex Rowe was a close associate of Eldred Norman. Alex was significantly involved in South Australian speedway, building a number of supercharged engines. Alex was made an OAM on the 26th of January 1987 for service to speedway racing, an honour he shares with the likes of Bill Wigzell, Allan Grice, Craig Lowndes and Mark Skaife. In the mid 1950’s to early 1960s Alex Rowe had a workshop 9 Eliza Street St Peters, Adelaide. Alex later moved to what was called the St Peters Speed Shop in Payneham Road, St Peters and then to Winston Avenue. Rowe and his wife Helen later ran the Golden Fleece Service Station in about 1967/1968 at 87 Winston Ave, Melrose Park (now the current Winston Avenue Music Shop), and lived nearby at 130 Morgan Avenue. Rowe did a variety of work, including manufacturing and selling floor shifters for early Holden grey motor crashboxes. Part of the workshop would later be offered to Eldred to manufacture superchargers in the 1960’s (Eldred had his own workshop in Halifax Street). Eldred’s larrikin nature was well demonstrated one Friday night when he popped around to visit Rowe’s Eliza Street workshop in the early 1950’s... in the Maserati. The South Australian Police were looking for a race car seen coming up King William Street from the Halifax street region... funnily the car ‘vanished’ around Franklin Street! On arrival Eldred leapt from the vehicle and had time to light a cigarette before the Police pulled up. The Police ran in and asked whether a racing car had just driven in. “It went that way” said Eldred, after which they departed. This makes two Australian capital cities (Perth and Adelaide) to witness Eldred’s race machines trundling along, after Carboni’s daily commute in the Double Eight described above.
Eldred sold the Maserati in October of 1953 to Ted McKinnon (a Melbourne motor dealer), who raced it in the 1953 Australian Grand Prix at Albert Park, Victoria (again in Formula Libre trim). Ted finished 15th out of the thirty-nine car field (Eldred did not enter the Australian Grand Prix in 1953). The vehicle then passed to Eddie Thomas in 1954, possibly for the Seaton brothers, who entered it for Ken Cox the same year. Cox later raced it with a Holden engine from 1957-1959, mainly on Victorian country tracks. The Maserati fell into disrepair, and was sold by Gavin Sandford-Morgan to Alf Blight in 1966. It was restored over many years until it raced at Mallala in 1982. Alf is shown at Amaroo Park in the 1980’s driving the #79 Maserati in the image below.
The Maserati passed to the United States, then to Robin Lodge (United Kingdom) in 1987, René Mauriès (France, who held it from 1988-1997, having been sold to him though Christies Monaco sales
for $197,000), until sold at auction to Bernie Ecclestone in 1997.
6. The Singer SM 1500
Eldred’s racing interests were diverse, as can be seen in the cuttings below from the Port Wakefield Grand Opening Speed Meeting programme of January 1953, and the 21st of October 1952.
The advertisements (which both use the same photograph, just cropped differently) show Eldred winning the Production Car Handicap at Sellick’s Beach. The #39 vehicle Eldred is driving is a production Singer SM 1500 Sports, with a 48bhp 1497cc engine. The Production Car handicap referred to is Eldred's Sellick's win from October 1952. The 2nd place win ten days earlier is probably Eldred’s also. As an aside, it is interesting that there were three Singers in the 1938 Australian Grand Prix referred to in the advertisement, piloted by Seville, Pike and Beasley. All three retired from the race (an interesting way to advertise for new car sales). The 1939 Australian Stock Car Championship was Brady's win at Lobethal.
In November of 1952 Eldred entered the Singer in the Collingrove hillclimb, recording a time of 51.5 seconds in front of the crowd of 4,000 people. As noted above, Eldred won the South Australian Sporting Car Club’s Kennedy Memorial Trophy that year for gaining the most points in all forms of competition. He went on to enter the Singer (as the #53 Maughan Thiem Motor Co Ltd vehicle) at the Port Wakefield Grand Opening Speed Meeting of January 1953 taking second place (he was also racing his #5 Maserati at the same event, also gaining second place).
7. The Triumph TR2 – a cross country driven Grand Prix machine
After not competing in the Australian Grand Prix in 1953, Eldred returned in 1954. In the interim he had purchased South Australia’s first Triumph TR2 by Christmas 1953. The Triumph was registered SA 1435 and bought for £1,189 – see clipping below from Adelaide’s News of the 22nd of February 1954.
The original disc wheels were replaced with wire wheels, and an overdrive fitted (operated by a lever mounted beside the transmission tunnel). The vehicle had a completely standard white body and red interior, with a passenger tonneau, single aero screen and headlight tape... no roll bar or seatbelt. The Triumph utilized a Standard Vanguard engine, fitted with a 136ci/rev G.M. 2-71 supercharger, driven at 1.1:1 by four A-section belts and producing 12psi of boost. Eldred experimented with home-made fuel injection, eventually returning to a 2" SU carburettor. Engine internals were largely standard but the crankshaft was ground undersize, then built up with hard chrome. The Triumph was fitted with oil and water reservoirs, pressurized from the GM supercharger and controlled by a tap on the dash. The small 12½ imperial gallon fuel tank was replaced with a larger 30 gallon unit. Tyres were Adelaide-made Hardie cross plies, similar to those used later on the Zephyr Special.
Mac Wilton was one of Eldred’s racing mechanics for a period in the 1950’s. Wilton arrived in Adelaide from England, and went job hunting the next day. After securing a job, Wilton walked down King William Street and was attracted by Eldred’s parked Triumph. Eldred wandered out and started talking to Wilton. Soon thereafter Wilton found himself employed as a racing mechanic, at less money than the job he had secured earlier in the day (ten shillings a week for endless hours). Wilton however viewed his time with Eldred as both fascinating and memorable, sharing many of Eldred’s highs and lows. Mac’s section of Eldred’s Halifax Street workshop became known as Dr Mac’s Surgery.
In November 1954 Eldred and Dr Mac drove the Triumph 1300 miles to Southport, Queensland ready for the Australian Grand Prix.
The Triumph was towing a trailer over mainly unpaved roads with two 44-gallon drums of methanol racing fuel. The 5.7-mile clockwise Southport circuit is shown below.
Winning the Brightways Trophy and Cords Piston Ring Trophy support races on the morning of the Australian Grand Prix gained him entry into the main race. Eldred removed the #8 Triumph’s engine decompression plate, gaining some power for the race in which he came fourth. By the end of the race the supercharger drive belts had stretched so much that boost had dropped from 12 to 8psi. One of Eldred’s race-mates, (later Sir) Jack Brabham, had to retire his Cooper T26 after only one lap, whilst the 4.3L Maybach Special II of Stan Jones broke in half at two chassis welds, depositing Stan in the scrub at 100mph. The images below show Eldred and the Triumph at the 1954 Australian Grand Prix.
Eldred’s Triumph was driven from the Grand Prix track, and without any rebuild it then towed the trailer, trophies and two Longine watch prizes 1300 miles back to Adelaide, rattling gently from cracked pistons. The photo portfolio given to Eldred as a prize was later cut up by Nancy as it showed “Miss Cord Rings” by Eldred’s side.
Whilst the Triumph is famous for its Grand Prix performance, it also received a considerable workout in other events, as can be seen by Eldred’s (aquatic) racing in the clipping below from Adelaide’s Chronicle of the 24th of June 1954.
Image[/URL
The race shown is the mud-trial run by the South Australian Sporting Car Club, in which Eldred and Nancy took third place. The course included a creek crossing and hill at Brownhill Creek, a narrow hills track at Coromandel Valley, and the crossing of the Finniss River as shown to the right with a mud slope and sand course. Imagine doing that in a modern Grand Prix car, and afterwards racing in a Grand Prix.
The Triumph was also entered in the Collingrove hillclimb of April, and took first place in the 1,001-2000cc class at Port Wakefield in that month. In September the Triumph was raced at Fisherman’s Bend, Victoria then at the Port Wakefield races a day later. Eldred was to come fourth in the Churchill Motors scratch event at the latter meeting. The image below, from Adelaide’s Advertiser of the 8th of October 1954 shows Eldred preparing the Triumph.
[URL=http://s929.photobucket.com/user/V8EKwagon/media/thirtyseventh_zps282e27c7.png.html]Image
In one incident in the Adelaide hills, Eldred noted that the Triumph’s tyres had all deflated. The cause was finally found – high loading under speed had forced open all the tyre valve stems.
After Eldred’s campaigning, Eldred’s Triumph was raced briefly by his Eldred’s good friend Andy Brown then disappeared. The image below, taken from With Casual Efficiency, shows Brown in a supercharged Triumph TR2 in the fourth row of the starting grid of the third qualifying heat of the Australian Grand Prix at Port Wakefield in 1955.
It is likely that this is Eldred’s vehicle. Brown was not successful in the qualifying rounds, and did not proceed to the main Grand Prix event. Eldred was racing his new project at this event, which we will see below.
8. The Zephyr Eclipse – incredible engineering.
Eldred formed a relationship with an Adelaide &*#@ dealer, Eclipse Motors, and race a Zephyr sedan. The Zephyr sedan had a link to his next mission – a car for the 1955 Grand Prix. Eldred assembled a new car in ten weeks, only coming inside the house to eat and sleep in order to complete the new Zephyr Eclipse. As the design of Eldred’s Double Eight was likely influenced by his ownership of the Bryant Special, this new project is likely to have been influenced by the Clisby Special. The Clisby Special was built by Harold Clisby, and raced against Eldred in events like the Collingrove Hillclimb. The image below, taken from With Casual Efficiency, shows the Clisby Special at Collingrove in 1952.
The vehicle utilizes a unique chassis/driveline technique (where no chassis is used other than a tube enclosing the driveline) which Eldred was to use in his new project. Clisby’s special utilisd a Douglas 350cc motorcycle engine, and with no body weighed only some 336lb, It had a power-to-weight ratio around 1½ times that of our EK Holden.
Eldred’s design was initially laid out in chalk on his workshop floor, with a heap of components from the wrecking yards supported on house bricks so that Eldred could get the wheelbase and seating position right - the driver of the Zephyr sits offset to the right. Like Clisby’s design, Eldred’s was unique in using no chassis – the front crossmember, engine and transaxle are all stressed chassis-members. The Zephyr engine was canted 45º to the right with a modified FJ Holden front crossmember. The crossmember is bolted to the timing cover, itself made from a hollowed-out piece of steel. A large diameter 6” tube bolted directly to the engine extending back to the rear-mounted clutch and transaxle, with the drive shaft running through the tube. The overall result is a wheelbase of 6’ 9.8” and a track of 3’ 11”. The humpy front end was fitted with unequal length wishbones, coil springs and telescopic shock absorbers. The rear end was fitted with a single upper transverse leaf spring, lower wishbone and telescopic shock absorbers, all bolted directly to the three-speed ZF transaxle, from a Tempo Matador truck. Double universal half-shafts provide drive. A Holden steering box is used. The body, fuel tank and seat are bolted to brackets welded to the tube, with the fuel tank immediately to the drivers left. The gearshift is high on the left side, almost chest height, with the shifter connected to a ball joint and an exposed square rod that runs along the top of the tube toward the rear. Girling drum brakes were taken from a 1.5 tonne Standard Vanguard, covered by 5”x13” wheels made from FJ Holden centres machined down to fit Zephyr hoops. Tyres were 6.4x13. The front wheels were originally drilled to lighten them and increase cooling, though this idea was later scrapped due to weakening of the wheels. The motor was originally a &*#@ Zephyr 2,262cc unit, supercharged at 1.5:1 with a Wade RO20 supercharger operating at 10psi. The supercharger is connected to the motor via rubber hoses and fed via a single 23/8” SU carburettor. The carburettor was rumoured to be either from Stan Jone’s Maybach Special Mark II, which crashed at the Australian Grand Prix in Southport, Queensland in 1954 (remember that Eldred campaigned the Triumph TR2 at this meeting), or from a Mayback military vehicle. The truth however is that the special methanol SU was specifically ordered from SU in England, and picked up by Alf Harvey from the SU factory before being delivered to Eldred (this story was shared by Alf to Graeme Snape). The SU is fitted with a second fuel bowl to prevent starvation. The fuel tank is pressurised (via a regulator) from the supercharger, though could be pumped up by hand by the driver for start-up. Visible through the hand-made wood and aluminium steering wheel were five gauges, with no tachometer (Eldred arguing that he valued a speedometer more). Recent photos shows this has increased to six.
On completing the car, Eldred drove it to Adelaide (with trade plates) to have the body hand-built in aluminum. Bear in mind that during this journey the bodyless vehicle was running open exhaust headers, punching out some 116dB… sixteen times louder than average family sedan at 76dB, and similar to putting your ear 1m from a car horn. Nancy and Bill followed the new race car to Adelaide in the family &*#@ Zephyr convertible. The top bodywork section of the Zephyr was able to be lifted off for access, with the front grille showing a remarkable similarity to the Tempo Matador bonnet badge (see image below)… though of course with an “N” for Norman.
The two-piece body is in light aluminum with an undertray suspended by brackets from the tube and the front cross-member. The bright yellow paintwork was completed with road-marking paint.
The completed Zephyr weighed in at 1,527lb. The engine generates 280 to 300bhp (… a standard Zephyr is around 86bhp) – a power to weight ratio some 6½ times that or our standard EK Holden (… a bit higher than Clisby’s 1½ times). The Zephyr is good for 90mph in first, 130mph in second and on a long straight just under 160mph in top. Nancy’s recollection of the Zephyr was that it cost some £10,000 to build.
On firing up and test driving the newly built Zephyr Eldred realized that his connection to the Tempo Matador ZF transaxle had delivered three reverse gears and one forward. Eldred is said to have laid into the work bench with a hammer for half an hour on realizing. On further test driving (along Halifax street) the sump was holed, a nasty thing to repair as the sump was difficult to remove. Eldred went down Halifax Street to Carrington Street, home of the Adelaide Milk Supply Co-Operative Limited (Amscol’s) Ice Cream works (pictured below) and returned with a bucket of dry ice. He filled the sump with the dry ice, allowing him to weld out the hole without distortion.
Eldred found that the low-volume Zephyr oil pump was not up to the task, and replaced it with an agricultural-type gear pump at the end of the camshaft sitting out over the front cross member. Hoses run to the wet sump, oil filter and back into the main oil gallery without the use of an oil cooler.
John Cummins remembers watching Eldred in the Halifax street workshop shaping springs from flatbar. The intention was to make driveshafts for the Zephyr that would also act as suspension… one design feature that did not end up on the finished vehicle.
The early name for the car was a bit of a mouthful - the Norholfordor - because it was built by NOrman from HOLden, &*#@ and Tempo MatadDOR parts. For the curious, a Tempo Matador was a VW-powered light commercial vehicle made from 1949 to 1954. It was then called the Eclipse Zephyr. The name Eclipse came from the Adelaide &*#@ dealer, Eclipse Motors who gave Eldred the Zephyr motor.
The 80-lap October 1955 Australian Grand Prix was held at the Port Wakefield circuit, in South Australia. The 1.3-mile clockwise circuit is shown below.
Refueling during the race was undertaken from a 44-gallon drum pressurized with nitrogen oxide to speed things up. Eldred and the Eclipse Special finished eighth out of a field of twenty-three. The race was won by (later Sir) Jack Brabham in a Cooper T40, six laps ahead of Eldred.
The Zephyr Special was so unconventional that it was referred to as that "diabolical device". As Ray relates:
“Scrutineers, too, found he had the answers. Concerned that the Eclipse Zephyr may not be strong enough, they obliged him to prove it was. “It’s strong enough o hold up a truck” Eldred boasted and was made to park it under a tabletop and jack up the tray body. Even so, many bets were laid about how many laps it would last before it broke in half!”
The photo below shows the #2 Eclipse Zephyr Special in 1955, taken in the pits at the Australian Grand Prix at Port Wakefield.
There is a fair chance that one of the gentlemen in the photo is his mechanic, Ramon Monkhouse. Ramon remembers that one of the teething problems with the Zephyr Special was that it was always tested on a straight road, and subsequently suffered from fuel starvation on corners.
This was Eldred’s fifth, and sadly last Australian Grand Prix entry as driver, having entered in 1950 (DNF), 1951 (DNF), 1952 (DNF), 1954 (4th position) and 1955 (8th position). Whilst he did not collect too many trophies, Eldred did have his own trophy cabinet of melted pistons, broken valves and other mementos carefully arranged behind glass.
The image below shows the Zephyr Special at Port Wakefield some time after the Grand Prix.
Like anything that Eldred built, the Zephyr has its share of anecdotes. After lunch on a particularly dusty day at the Port Wakefield circuit Eldred’s pit crew desperately tried to push start the Zephyr Special. With no success from the pushing, they then resorted to towing the Zephyr through the pits. Finally, with a few pops and bangs the zephyr fired up – spitting out flaming pieces of rag out of the exhaust. One of the helpers then admitted he had carefully tucked a piece of rag into the enormous SU carburettor before lunch to prevent the dust from getting into the engine. Whether the forgotten rag was passed through the supercharger, cylinder head and out the exhaust, or instead was blown out the inlet by a blower bang is debatable, though in either case must have been spectacular.
Eldred’s practical (and somewhat agricultural) approach to engineering was also demonstrated in another discussion held with an enthusiast who had fitted a supercharger to a Morris Minor. To richen the mixture on the Morrie’s SU carburettor he had started to fiddle with the needle profile. This was done fairly exactingly by marking along the length of the needle at 1/8” increments and taking diameter measurements. The needles were then mounted in a lathe and the appropriate sections carefully machined down with some fine wet and dry abrasive paper to arrive at the “required” diameter. The enthusiast realized that Eldred’s recently completed Zephyr Special was also supercharged and fitted with a huge SU carburettor. Figuring that Eldred would have gone through a similar and probably more sophisticated exercise in matching a suitable mixture needle profile to suit the supercharged Zephyr, he approached Eldred. Eldred then proceeded to reach into his pocket and pull out an old tobacco tin, opened it up, and tipped out three or four of his “mixture needles”. The needles looked like 3” brass nails varying anywhere from hexagonal to triangular in section with very heavy filing marks along the length. On seeing our Morrie owner’s surprise Eldred commented that he needn’t be so fussy, as Eldred merely filed another flat on the SU needle about wherever he thought the mixture needed to be enriched.
Eldred entered the car in the March 1956 Argus Trophy. This was a twentyfive mile support race for the Australian Grand Prix at Albert Park circuit, Victoria. However, he did not win the race.
In late 1956 Eldred sold the Zephyr Special to Keith Rilstone, telling Keith "You will make this car perform" (which Keith did). The photo to the right is of Keith competing in the #2 Eclipse Zephyr at the Western Australia Racing Car Championship meeting in October 1961 at Caversham military airstrip in the Swan Valley (Keith retired from the race).
Caversham became Western Australia’s first dedicated motor racing circuit, and hosted the Australian Grand Prix in both 1957 and 1962. Military needs resulted in the Western Australia Sporting Car Club, the operators of the circuit, moving to their new home at Wanneroo in 1968.
The photograph below is from Rilstone’s ownership, and were taken at Mallala Race Circuit South Australia.
The photo below shows Rilstone working on the Zephyr at Port Wakefield in October 1959.
Rilstone fitted the Zephyr Special with the newer (and larger) 2,553cc Mk2 Zephyr engine with a Raymond Mays head that he got from Charlie Dean at Repco. The head had apparently been purchased by Repco for evaluation during the design of the Hoden Hi-Power head. Rilstone also made changes to the front suspension, adding an antiroll bar and lowered the top wishbone pivot point, thus lowering the roll center of the car. Shock absorbers were moved outboard of the coil springs. PBR assisted in the setup of dual leading shoe brakes based on Vanguard components and fitted with twin boosters. Over time Rilstone increased the reliability of the car, getting to the point where he wouldn’t even wash it, in case he jinxed it.
In 1959 Rilstone took second place in the Zephyr at the CAMS Gold Star race at Port Wakefield. In the same year he piloted the Zephyr Special in the Westernport Cup at Phillip Island gaining 5th place. In December of that year he recorded 124mph over the Flying Eight Mile at the Weapons Research Establishment Institute Sprints in South Australia.
Rilstone campaigned the Zephyr Special through several years of the Australian Drivers Championship series. This was a CAMS-sanctioned Australian motor racing title for drivers of Formula Libre cars, contested over a number of rounds. Points were awarded for various placings in each round, with the overall highest number of points at the end of the series being awarded the CAMS Gold Star.
• 1957 was a nine-race series. Rilstone placed fourth in the October Wakefield Trophy race at Port Wakefield circuit, earning him equal 17th position (of 22 positions) in the Australian Drivers’ Championship.
• 1958 was also a nine-race series. Rilstone placed third in the April South Australian Trophy Race at Port Wakefield circuit, earning him equal 11th position (of 15 positions) in the Australian Drivers’ Championship.
• 1960 was also a seven-race series. Rilstone placed third in the October Advertiser Trophy Race at Mallala circuit, earning him equal 10th position (of 18 positions) in the Australian Drivers’ Championship.
The image below, taken from With Casual Efficiency, shows the Zephyr (at far left) at Port Wakefield in Easter 1957.
The image below shows Rilstone in the #8 Zephyr at Port Wakefield in 1960.
Rilstone entered the Zephyr Special in the 1961 Australian Grand Prix at Mallala, which was a round of that year’s Australian Drivers Championship. The dark green Zephyr can be seen in the left background of the photo below.
The Zephyr started on the third row of the grid, but did not finish the race. The Zephyr Special was the first of seven cars to retire from the seventeen car field, completing thirty-three of fifty laps (105 miles). Whilst Rilstone returned to the Australian Grand Prix in 1964 (in a &*#@ powered Elfin FJ), the 1961 race represented the last time one of Eldred’s machines competed in the Australian Grand Prix. Eldred’s vehicles thus entered the Grand Prix a total of ten times:
• the Double Eight in 1950 (DNF) and 1951 (DNF), and a non-start (DNS) in 1957 under Carboni,
• the Maserati 6C in 1951 (DNF, albeit under Murray’s ownership), in 1952 (DNF), and then in 1953 (15th position, under McKinnon’s ownership),
• The Triumph TR2 in 1954 (4th position), and probably in 1955 under Brown (though did not get past qualification), and
• The Zephyr Special in 1955 (8th position), and in 1961 (DNF, under Rilstone).
Rilstone also entered the Western Australia State Championship in October 1961, competing in Event 5 the fifteen-lap Racing Car Championship. The Zephyr retired after ten laps. He also competed in the Advertiser Trophy at Mallala in October 1962. After qualifying fourth, Rilstone retired having completed twelve of the twenty-five laps. The image below shows Rilstone in the #8 Zephyr at Mallala in 1962.
Rilstone ran the car competitively right through to 1963 before selling it to Robin Reade. Robin had the vehicle until 1964, when it passed to Don McArthur, and then in 1968 to two young gentlemen who utilized the vehicle as a beach buggy. The car slowly lost shape, with the friendship of the two gentlemen equally declining. They finally decided to split the car between them, engaging a local garage to break the car behind the engine. It then sat in the mechanic’s shed for some years as the workshop had not been paid for the work.
The vehicle was tracked down and rescued in 1973 by Ken Messenger. Messenger purchased all the pieces and brought them together before running the car in historic racing. The Zephyr would melt pistons at the Sporting Car club of South Australia’s Historic Races in April 1975. Messenger then sold the vehicle in 1978 to Peter De Mack in Adelaide, who completely rebuilt the car.
The #6 Zephyr is shown in the image below in 1983 being driven by Kevin Shearer at the Victor Harbour Quarter Mile Sprints (Alf Blight was at the wheel of Eldred’s Maserati for the same event).
The Zephyr Special was purchased from Peter by Graeme and Robyn Snape of Gundagai NSW in 1983. Graeme is shown driving the (now green and #6) Zephyr in the image below.
The current engine is bored 0.040” over, balanced and has conrods from a Toyota twin-cam engine running on the standard Zephyr crankshaft. Mahle pistons are fitted that Peter de Mack had made during his ownership. Except for the original drop gear, it’s been some time since the gears in the gearbox resembled anything that left the ZF factory. First gear in the Zephyr Special is actually the same ratio as the original third and the box lost its reverse years ago. The car’s Achilles heel has always been the transmission, although that was sorted out once the Snapes found the right steel to make the input and output shafts. The car has thrown one rod in the Snape’s ownership due to low oil pressure. The car is very hard on clutches being very high-geared with 90mph in first gear, 130mph in second and more than 150mph in top. It will see close to 160mph down the straight at Eastern Creek and Phillip Island, pulling 6,300rpm. In a straight line it is a very stable car, but it hates fast, sweeping corners due to its short wheelbase.
When the Snapes were considering taking the vehicle overseas to the Goodwood meeting in 2000, the Zephyr Special was deemed to be a protected object under the Protection of Movable Cultural Heritage Act 1986, requiring a permit from the Commonwealth Department of Communications, Information Technology and the Arts for its temporary stay overseas.
The photos below are from the Snape’s ownership of the Zephyr. The photos below in the #6 guise I have taken from Patrick’s article, whilst those in #5 guise from Ted’s.
9. Odds and Ends – The Trials Vehicles
In the same year that Eldred sold the Zephyr Special, he also competed in a round Australia trial (the 1956 Mobilgas Trial). Eldred drove car #54, a &*#@ Anglia 100E. The navigator was racing identity David Harvey. Unfortunately, the Norman/Harvey entry did not finish. This was a grueling race, with only two of the thirteen Fords entering finishing (Holden did little better with four of thirteen entrants finishing). Whilst Eldred did not compete in the earlier 1953, 1954 and 1955 Redex trials (nor the later 1956, 1957, 1958, 1964 Ampol trials nor the 1958 Mobilgas trial), he does get a mention in the advertisement from Adelaide’s Advertiser (3rd of July 1954, se clipping below), which indicates Eldred used Redex. Note that the article but does not list him as a Redex trials entrant (it does however list “Possum” Kipling).
Some of Eldred’s race vehicles are a little harder to tie down than those noted above.
• Soon after starting out, Eldred purchased an ex-Black and White Holden taxi. The taxi was suffering badly from big-end noise. Eldred announced they were entering it in the Advertiser 24 Hour Trial the next weekend. After shimming the bearings with cut-down Benson and Hedges tobacco tins, he won the trial. During trial racing Eldred was known to keep himself awake by butting cigarettes on the back of his hand. He once became annoyed by a car which would not move over, until it was rammed with vigour.
• It is believed that a &*#@ Prefect used by Eldred in the 1956 Advertiser 1000 Mile Reliability Trial had some secret weapons: for short period power, a container mounted above the carburetor filled with nitromethane; windscreen wipers were put on the headlights, operated in conjunction with washers activated by the navigator from an upturned Holden fuel pump operated by foot; and tractor tread tyres. The weapons must have worked, as Eldred won.
10. Post Racing – inventions and travels
After selling the Zephyr in 1956, Eldred abandoned racing to concentrate on inventing. He built a large astronomical telescope in the property’s tin shed, then a rotating observatory in the "plane paddock". The plane paddock had an old twin-engined bomber training aircraft that Eldred had brought back from one of his trips to Papua New Guinea. The Norman children would play in the aircraft, and later cut it up with an axe. Eldred’s sunny observatory, complete with opening roof, became a favourite for Nancy’s writing. A car gearbox was employed to rotate the truck chassis base (mounted to a twenty-tonne block of concrete) to compensate for the earth’s rotation. The telescope operated with both pneumatic and hydraulic components, and had no fewer than twenty electric motors. Scientists from the Weapons Research Establishment (the Commonwealth body engaged in defence research, ammunitions and explosives or weapons industries, based in Salisbury South Australia) would visit to see his home-made automatic telescope mirror-grinding machine complete a cycle, watching as it automatically applied paste, water, rotated, oscillated and separated, grinding mirrors to a tolerance of 0.000003”. Eldred’s 14” cassegrainian telescope (a reflecting telescope that has a paraboloidal primary mirror and a hyperboloidal secondary mirror) is shown in the image above right from Ray’s article, and was later sold to Clive Clisby.
An anecdote related to Eldred’s observatory, Eldred’s fear of spiders and some interesting inventing is related by Ray:
“Steve Tillet once offered Eldred Norman a cigarette, handing him a tin which, when opened, revealed the arachnid. After letting out a scream, Eldred’s reaction was rage. Steve bolted out of the workshop and jumped into his Morris Minor, with Eldred in hot pursuit. A couple of times around the block and Eldred got alongside and pushed him into the gutter. He was about to pummel him when three police officers walked up...
So real was Eldred’s fear of spiders that he went to great lengths to keep them out of the observatory. But then. If anything caught his attention there seemed no limit to the effort he would expend...
A rail of aluminium was installed right around the base on the outside. It was insulated from the building, and located so that any visiting spider had to climb over it. Which was pretty tough, because it carried 2500 volts!”
Many of Eldred’s prototypes, including a car tow-bar and a photographic device to capture burglars, never reached the production stage.
With Nancy, he made a motoring trip in 1961 which took them through seventeen countries, including the Soviet Union, Poland, East Germany, Turkey, Iran and Pakistan. A sign of the times was ASIO’s interest in Communism. There is a one hundred-page file covering Commonwealth Police investigations into the Norman’s activities. ASIO intercepted the Norman’s mail and recorded telephone conversations leading up to their trip. A confidential memo dated April 1961 to Headquarters ASIO from the Regional Director South Australia, indicates that they have nothing known regarding Eldred, but Nancy's name was linked to others (details blacked out in the public report), was present at a public meeting of note, and had signed a petition organised by 'Overland' (a magazine who’s editor was an ex-member of the Communist Party). The Prime Minister Robert Menzies was well known for his anti-Communist views, and was kept informed by memo of the goings and comings of Eldred and Nancy. The trip was undertaken by shipping a 1961 &*#@ Falcon station wagon to Spain, complete with oversized 50-gallon fuel tank and camp bed in the back. They applied for passports to go to USSR and China in 1961. This request was vetted by ASIO, as part of their 'investigation' of the couple.
On returning from their trip Eldred and Nancy accepted an offer on the “plane paddock”. Whilst the labourers had to break up Eldred’s twenty-tonne concrete foundation, they had few tree stumps to clear… Eldred had done so some time previous with the gelignite noted below.
As Ray notes:
“No longer did the cleaning lady come in twice a week. She had worried Norman, desiring only to get her job done. For him it was a nuisance that she wished to hurry him, his daily reading of the newspaper before coming out to breakfast became a barrier to the smooth passage of her working day. Sometimes she would wash up the breakfast things before he rose, so that he would find the French polished table bare. One morning Eldred put an end to that problem. He got the hammer and put nails into the table to hold the table cloth on! It was not the only time he’d done something seemingly destructive around the house. A pop-up toaster insisted in troubling him, so he threw it on the floor, pumped on it and threw it out the window and over the hedge, where it lay for years.”
11. The Norman Superchargers – father and sons.
Eldred is also renowned for his sliding vane supercharger manufacturing, which started in Adelaide and then continued after the family moved to Noosa in 1966. He is likely to have been influenced by a second-hand incomplete Arnott supercharger he purchased during his ownership of the Maserati. Eldred manufactured eight different superchargers (the Type 65, Type 70, Type 45, Type 75, Type 90, Type 110, Type 265 and Type 270), and adopted some truly innovated designs, including a supercharger clutch drive reminiscent of Mad Max’s car. Eldred’s superchargers ended up on a number of Mike and Bill’s vehicles, including an ex-PMG FE van and Bill’s supercharged MGTC, a winner at Lakeview Hill Climb in October 1965. Eldred’s reflections on supercharging were published in his book Supercharge! published in 1969. The image of Eldred below, taken from Supercharge! shows Eldred in his forties.
Eldred’s habit of road testing race vehicle continued, with his HD Holden utility acting as a test-mule for many of his superchargers. The HD had all drum brakes… interesting to handle given that when fitted with the Type 110 supercharger and Eldred’s own twin-needle 3” SU it could make 140mph. Only seven or eight of Eldreds’ 3” SUs were ever made between around 1969 and 1971. Note that the large SU on the Eclipse Special was not one of Eldred’s, rather it was from a specialty order from the UK. When fitted to a 186ci Holden red motor and Type 110 supercharger Eldred’s 3” SU would only lift around ¾ of its piston travel at 6,000rpm. Barrie Broomhall Motors had the first electric dyno in Queensland and one of the first in Australia. This was a measure of his business acumen and many noted engineers and companies hired his workshop to do development work on their projects. Among the more famous was Eldred Norman doing testing with supercharging.
Eldred’s passion for sliding vane superchargers was taken up by his son Mike. Having been raised on a diet of supercharged vehicles, Mike Norman began building some superchargers from Eldred’s design in 1973-1975. Unfortunately, the original patterns and moulds for Eldred’s superchargers, stored under the house in Noosa, had been lost. From 1978 (through to 1984) Mike ran Offroad Automatics Pty Ltd at Magowar Road in Girraween, Sydney. Whilst the business was involved in fitting automatic transmissions to Range Rovers, Mike began to tinker with superchargers around 1983. Mike manufactured an improved version of the sliding vane design in Sydney the mid 1980’s, making six models (the 150, 200, 250, 300, 350 and 400). Around 1984 Mike was commissioned to supercharge the new four-door Range Rover owned by the managing director of Leyland Australia. This vehicle originally had 9.5:1 compression, and required new low compression pistons to go with the supercharger, manifolds and water injection. All up the project cost around $3500. Bear in mind that a new Range Rover in the UK was selling for around $18,000… This is roughly the equivalent (in today’s money) of buying a 2014 Holden Statesman and supercharging it for $13,000. Mike ceased automatic transmission operations in Girraween in 1985, moving to Noosa. The advent of newer more efficient supercharger type such as the Whipple and Eaton superchargers made for a declining market, and supercharger production was ceased.
Whilst Eldred’s Norman-supercharged HD Holden utility is renowned, Eldred did not actively race superchargers of his own design, instead utilizing Roots, Arnott and Wade superchargers. However, both of Eldred’s sons ran cars with Norman superchargers onboard. Bill started racing at age seventeen in a Standard 10 (shown with Bill in the image below), fitted with a steel-cased Type 65 supercharger.
Bill won his first race at Mallala circuit in GT class. After serving a hard life on the track, the Standard 10 was later road-registered by Mike, though did not last too long. After limited success with the Standard 10, Bill then purchased (and later rolled) Steve Tillet's 1947 MGTC. Bill is pictured in the MGTC in the image below.
The standard 1250cc pushrod overhead valve XPAG engine had been fully balanced after fitting a 90-tonne crankshaft. The cylinder head was treated to porting and large valves, and a high overlap camshaft fitted. Bill fitted a steel-cased Type 65 Norman supercharger (seen in the image below), using flexible piping to connect it in suck-through mode. Boost pressure was operated at 10psi, with carburettion was via a 1½” SU.
To improve braking the MGTC was fitted with finned brake drums, air scoops on the brake backing plates and competition linings. Handling had been improved by the use of telescopic shock absorbers all round, 15” wheels with wide rims and radial tyres. To reduce weight, the body had a fiberglass tail and an aluminum bonnet, with a Vertex magneto removing the need for a battery. Running methanol, the MGTC’s power had increased from 55bhp to 85bhp (65 bhp at the rear wheels), giving a power-to-weight ratio 5½ times greater than our standard EK Holden.
Bill also owned the front-engine supercharged &*#@ Cortina engined U2 around late 1968/early 1969. The vehicle had previously been owned by Tony Simmons, who crashed and very badly hurt himself at Oran Park circuit.
Pictured below is Bill Norman’s LC GTR Torana. Bog stock standard, complete with 161ci (2600cc) straight-six and a Norman Type 110 supercharger.
The car had standard brakes, wheels, radials, suspension, exhaust, head and cam, with race preparation limited to a home-made aluminium bonnet and door skins, and the interior gutted. The supercharger never reached its full potential as the relief valve spring lifted constantly (too light). The photo was taken at the Warwick Farm (Sydney) esses during a Sports Sedans practice on the 2nd of May 1970. Bill can be seen thrashing the Torrie at the same meeting in the last few seconds of the 8mm video clip here: http://www.youtube.c...h?v=jjgNQy6YIRk. Bill competed at this circuit the following day at the Royal Automobile Club Trophy event in the closed sports sedan race. He was slow off the grid when the supercharger blew back, finishing eleventh after passing a half dozen cars during the ten-lap event.
Whilst Bill was driving the Type 110 Norman supercharged GTR Torana, it still was not quick enough. Eldred’s answer was to build a Hillman Imp with a Buick Fireball aluminum 215ci V8, complete with the Type 270 supercharger and Corvair gearbox. The whole mechanical package was contained in a triangulated frame connected to the chassis by pins for easy removal. The Hillman was test driven for a few yards (snapping the input shaft in the process), though sadly was not completed prior to Eldred becoming ill and passing away. The Type 270 supercharger survived, and is currently owned by Mike Norman. Mike Norman also drove an ex-PMG FE panelvan (repainted from red to grey) with a Type 65 supercharger around 1964-1965, and a 350 supercharger fitted to a 122ci SOHC Triumph Dolomite Sprint (I currently own the supercharger).
12. Other Pursuits
Norman and Nancy pursued a wide variety of interests, including literary. Eldred for example had written a six-article series for the Motoring News section of Adelaide’s News in 1952 (including How Compression Operates). He also tried his hand at writing at this stage, completing (though not publishing) The Memory Beam (an alien story with brain erasing) and Coffins in the Sky. Nancy worked as a journalist and art critic for the Adelaide News, and became a poet and novelist. Her most famous trilogy All The Rivers Run, was published in 1958. The story was adapted to a television mini-series starring Sigrid Thornton and John Waters which ran from 1983 through 1989. Nancy also wrote The Dancing Bough (1957), Time, Flow Softly : a novel of the River Murray (1959), Green Grows the Vine (1960, with a dedication for Eldred), But Still The Stream: a novel of the Murray River (1962), The Sea Ants: and Other Stories (1964), North-West by South (1965), Brown Sugar (1974), Queen Trucanini (1976, with Vivienne Rae Ellis), Nin and the Scribblies (1976), Mister Maloga: Daniel Matthews and his Mission, Murray River, 1864–1902 (1976), The Noosa Story: A Study in Unplanned Development (1979), Forefathers (1983), The Lady Lost in Time (1986), A Distant Island (1988), The Heart of the Continent (1989), River's End (1989, with Leslie McLeay) and Marigold (1992). Her poetry includes The Darkened Window (1950), whilst she also authored the play Travellers Through the Night and edited the Jindyworobak Anthology (1950). Nancy became prominent as a conservationist and Aboriginal Rights activist.
An active member of the Sporting Car Club of South Australia, Eldred often took his children to events, leaving Nancy free to write. During a trip to Darwin Eldred had swapped a bottle of whisky for a .45 caliber sub-machine gun. An earlier purchase of a truck had yielded crates of ammunition. During construction of the Sporting Car Club of South Australia's 0.4-mile hill-climb track at Collingrove in the Barossa Valley, Eldred used the sub-machinegun to hammer soil in around fence posts. Another version of this tale is related by Geoff Berry in With Casual Efficiency. Berry assisted in the construction alongside Eldred, and, indicates that the gun was used to dig holes in order to place gelignite for blowing up stumps and rocks (rather than tamping down fenceposts). For years the case of hundreds of bullets lay open in the shed for the three Norman children to play with, together with a quantity of dynamite which Eldred finally disposed of when it began to weep nitroglycerine. Eldred was one of the foundation directors of Brooklyn Speedway South Australia Ltd, the company which built and operated the Port Wakefield track from early 1953. In 1958 Eldred would gift two hundred and fifty of his shares in the Brooklyn Speedway Company to the Sporting Car Club of South Australia. The image below, taken from With Casual Efficiency, shows (from left) Andy Brown, Gavin Sandford-Morgan and Eldred at the Easter 1963 meeting at Port Wakefield, where Sadnford-Morgan had won the Sports Car scratch race.
Stories abound of how Eldred outpaced police as he tested cars on the road between his Adelaide workshop and his Hope Valley home. The police would be on his doorstep moments later, looking to nail him for driving an unregistered vehicle. "Oh, no, it hasn't been running at all... not for a couple of days" he would tell them. Feeling the warmth of the engine cover, the police exclaimed that it retained its heat well and departed. Eldred soon learnt that it wasn’t a bad idea to hose down the bodywork after such a run. His tactics were not always successful though, as the clippings from the 11th of May 1938 and 3rd of October 1946 edition of Adelaide’s Advertiser below show.
Eldred was also booked for speeding over an intersection (with fines of £1. and 10/ costs in November 1939), and with driving an unregistered car (no penalty, though slugged with 7/6 costs) in August of that year. In one of the incidents above, the Assistant Police Prosecutor noted that “Practically every regulation In the Traffic Act has been broken”. In another incident, when the magistrate shook his head and said, "What will I ever do with you? You come in here so often it’s a waste of the court’s time" he quickly answered back: "Could I have a monthly account?". In 1962 the South Australian Police booked Eldred for low level speeding when he was heading to a race meeting, most likely to watch the first Elfin Formula Junior in action. Eldred was outraged to be caught by the state's first Police radar - he considered it to be unsporting of the Police. He went to enormous trouble in an attempt to prove that the radar was inaccurate. He even went to the extent of obtaining the exact same model of radar unit and spending weeks testing it for potential flaws by attaching strips of reflective alluminium to rotating wheels. When his court day arrived Eldred wheeled the radar unit into the court, to the consternation of the Police prosecutor. The magistrate found the offence proven but did not resort to a conviction, due to Eldred's GOOD DRIVING RECORD!
Eldred’s larrikin nature and engineering practicality are also demonstrated in the following anecdote from Steve Tillet. At a South Australian Sporting Car Club meeting Eldred had been told that Steve’s firm were installing a camshaft grinding machine. Eldred indicated that he had a Holden camshaft, and that as Holden spares were fairly sparse he wanted the camshaft ground. Steve went to Eldred’s Hope Valley home at the appointed time to pick up the camshaft, and Eldred started looking for it. As they walked through the house he noted that Bill, then about three years old, was walking up and down on the piano keyboard. "That kid's got an ear for music," Eldred told him. Finally, with no sign of the camshaft, Eldred called out to Nancy and asked if she'd seen it. "Is that that metal stick with the lumps on it?" she responded. "Yes, that's it," said Eldred. "Okay, I was using it to break those rocks out the front...". Nancy had a pile of rocks she was using for lapidary, so the camshaft was lying covered in dirt in the pile. Eldred picked the lump stick up and handed it to the cam grinder, "A bit more lift and a bit more overlap and they'll never catch me in the trials!" he said.
13. Larrikin Anecdotes
Some other Eldred Norman anecdotes include:
• As a child, Eldred’s father William operated a steam engine at home. The boiler pressure relief valve stuck, allowing the pressure to build to an alarming level. Being frightened to approach the boiler he rushed upstairs, took aim with a rifle and shot off the valve. In a separate incident, Nancy’s .22 rifle was employed during a trip to Fannie Bay (near Darwin, Northern Territory) to hunt a rat. The near dark conditions almost lead to the loss of a toe. Back home, Eldred’s issue of feral cats was solved by use of a length of guttering. The guttering was sealed at both ends and a rifle pointed down the length. Some milk bait and a length of string attached to the trigger led to the demise of many moggies (the exact number being subject to much speculation).
• On one interstate trip, towing a race car on the trailer behind the family Zephyr sedan Eldred proposed to travel with the least number of stops. Just before departing, Eldred purchased 200’ of rubber piping, draping it around the interior of the tow car. He reasoned it would be cold travelling at night, and connected the piping to the cars radiator to act as a heater, as well as to a container under the dash for warming beans. The Falcon car used for the Norman’s overseas trip had been fitted with a similar heater to allow them to stop for a cuppa en-route.
• Eldred’s love of warmed beans was matched for his love of chocolate. Whilst an ice chest was used inside the house, a dedicated kerosene fridge was located outside for the chocolate.
• On another interstate racing trip, Eldred’s packing must have been rushed as he forgot his shoe laces and the collar stud for his good shirt. He showed his ingenuity by arriving at the celebration dinner discreetly using welding wire for his shoes, and a nut and bolt for his collar.
• Eldred’s workshop office air conditioner car radiator fed chilled water from a drum of ice, electric fan. Eldred bough quality cotton handkerchiefs by the carton from David Jones, used them for wiping dipsticks and cleaning sumps then discarded them in a corner.
• When Eldred wanted to better enjoy his home movies, he built a bigger screen… around sixteen feet wide and ten feet tall. The screen was set-up in the front yard, with the projector on the verandah some eighty feet away.
• From Ray’s article:
“His workshop was to become the centre of his activity for some two decades. It was here he became the first person in Australia to put a racing car into series production. This started with a conversation with Steve Tillet, who frequently met Eldred for lunch. Many of Tillet’s stories about Norman commence with “I met him for lunch one day…” and continue with a story that reveals that Steve had to wait around and in doing so noticed things in the vicinity. In this case it was five Morris 8 van rolling chassis at the agents Motors Ltd. “They’d make a nice little racing car” He told Eldred “and the 4.5 diff ratio would be just right”. By 11 that night he had bought them for £200 each, the first chassis had been shortened and he was waiting for Snow Young to come around the next day to build an alloy body. According to Steve, they were quicker than an MG and sold for £450 each. Tillet recalls that David Hopkins bought one and Bill Hayes raced one at Woodside, but the last car was not finished. It had the front axle split and converted to swing axles, the rear end was coil sprung and had trailing links, and it hung around until bought by a certain youngster named Garrie Cooper in 1955. Known as the Cooper Butler (Norm Butler was to buy it and race it), Cooper never called the completed car an Elfin, but it started him on his way.”
Cooper went on to build three Cooper Butler vehicles (not to mention developing Elfin). It is possible that the first one, built from Eldred’s Morris chassis, is shown in sepia below.
The second (red) Cooper Butler, based on an Austin A40 is also shown.
• Ray also relates the following tale, one that Eldred favoured sharing:
“Like the time he got bogged in Western NSW. Hoping for a passing motorist to help got him nowhere, only one T-model going by while he was there, and it was driven by a farmer with his hat down over his eyes and his pipe upside down. There were however cattle in an adjacent paddock. Cutting the fence, he rounded up one and used fencing wire to hitch it to the car. It wouldn’t budge. More fencing wire was wrapped around one of its horns, then attached to a plug lead. The animal moved, got him out of the bog, and got itself jammed between two trees.”
14. The Passing of Two Legends.
Eldred was sadly taken by lung cancer on the 28th of June 1971 at Noosa Heads. Nancy passed away at Noosa on the 3rd of July 2000. Both Eldred and Nancy were recognised in a number of ways. Nancy, pictured below, was appointed a Member of the Order of Australia (AM) in June 1984 in recognition of services to Australian literature.
The Canberra suburb of Franklin includes Nancy Cato Street. The Jubilee 150 Walkway is a series of one hundred and fifty bronze plaques set into the pavement of North Terrace, Adelaide. It was officially opened in December 1986 as part of the celebrations commemorating the 150th anniversary of the founding of the state of South Australia. The plaques contain the names and deeds of one hundred and seventy people who made major contributions to the founding and development of South Australia. The plaques are arranged in alphabetic order. Eldred’s plaque, shown below is located between the Art Gallery Of South Australia and the University of Adelaide.
Whilst Eldred was nominated for Life Membership of the Sporting Car Club of South Australia in 1958, this was not granted as he had not been a member for ten unbroken years as per the constitution (his pre-war membership period apparently did not count). In 1963 Eldred financed the club’s trophy for Meritous Service, with the proviso that it was not for achievement in motor sport. The resultant Eldred Norman Perpetual Trophy has been awarded annually ever since.
Harv (deputy apprentice Norman supercharger fiddler).
Re: Harv's Norman supercharger thread
Ladies and gents,
Some interesting photos to add to the thread.
The two photos below were taken by the late John Brown, and show Bill Macintosh’s Norman-supercharged FJ Holden in Gympie, Queensland 1988.
Looks to be either a Type 65 or Type 70, running twin SUs. Does anyone know anything about the car, or where it is now>
I feel somewhat guilty about the four photos below. The Norman shown belongs to the John Brown. I had been having a good conversation with John over his Norman, though typically of me I kept getting sidetracked into other early Holden go-fast gear. When I visited and saw John’s Norman, I was foolish enough to not have taken a camera with me. John promised me that he would take some photos, which he did in the week or so before he passed away. Its typical of John that he went well out of his way to do this for me. RIP mate, and thankyou for the photos.
John’s Norman is an early water-cooled Type 65, with cast iron casing, steel rotor and aluminium end plates. This is the same as the Type 65 run in Bob Moule’s Bobcat humpy, which is currently living in Anthony Harradine’s EJ Holden Premier. Note that the water jacket nipples are offset, with one at either end of the casing. This is different to later Type 65s, where the nipples are in the middle of the casing and aligned. John’s Norman has the “NORMAN” cast outlet manifold, with the swoopy u-piece to bring the supercharger outet back up towards the bonnet, running between the engine and supercharger. This manifold uses a hose connection to run to the airhorn of the standard inlet manifold. Note the nipple on the discharge plenum for measuring boost. The mountings for John’s supercharger locate the unit low on the passengers side of the block, effectively replacing the generator. The generator is then located up high, close to the bonnet. John’s supercharger has been fitted with an aluminium box plenum inlet manifold... not sure what carbs it has been set up for. The drive end shows an open-race ball bearing. Most of these have been replaced over time with sealed bearings, so John's may not have been worked on for a while. The non-drive end of John’s Norman is blanked with aluminium plate.
