Wilma FB project
Re: Wilma FB project
Thanks Clay, but it will be on the car by then. 🤗 I'll go and have a look at the utes tomorrow. I just wasn't thinking there was a similarity between the two body types. Can't find a picture in the manual or the parts catalogue, which is not helpful.
Going to have a go at making the sealing rubber tomorrow as a start- that should be funny. Not sure if the lip against the body and tail light base goes up or down at this stage.
That air cleaner looks correct to my non restorers eyes ......
Thanks Blacky. That was on the car when I got it but I can't trust that. EK front over riders etc.
Made my own dust deflector rubber and bracket today. Nice change from frustrating trim stuff.Image
The final product. May have to trim it, but I think it will work. Bracket made from Rares boot channel rust repair section cut down. Rubber from Clarkes: 2 sections glued at right angles. Curved light pieces from Better Auto Rubbers( they were also 2 glued sections). Trim press-in clips for light sections, stainless screws for straight bracket section.
Not sure yet if I'll glue up the overlaps or not. I will fill small gaps in each inner corner. ImageImageImage
Like a bought one
Bumper finally back on today. Rubber seal made it an easy job as it just sat on the rubber while I was positioning the bar for bolts. Still have to sort out quarter panel bolts, but think bonnet bump stop rubbers might work OK.
Rubber seal set-up worked really well, once I cut a slit for each bumper iron thingy. The flaps fold up hard against the bumper and should seal well. Painted inside of bumper and bolts with zinc paint. Next time I'm crawling around under the car I'll take a snap.
This photo will test who's awake....
Umm, EK rear bumper overriders? (Mind you, I never had an FB, and I sold my EK 32 years ago . . . )
Hey lets play facebook !!!
Yes they are EK over-riders he he he he he.
Good job Brett its looking good,
Errol62 wrote: Mon Apr 12, 2021 4:15 pm That’s it, it’s a hot rod now......
ardiesse wrote: Sat Jul 03, 2021 4:43 pmUmm, EK rear bumper overriders?
I have committed far worse sins. For the last decade, my FB sedan has sported wagon rear centre sections on the front bar.
If I was a club member, I suspect I could be court-martialled, or at least locked in irons for a week 🤣
😁 I don't like the look of FB overiders compared to the full length of EK's. I will probably stick the dumpy stumpy FB ones on the front bar. We'll see.
Zzzzzzzzz, what??
Nice bum!
Bonnet bump stops won’t cut it by any means Brett. Approximately 20mm thick and 40mm diameter.
Ok. Thanks Clay ( and Harv). Bunnings tomorrow for door stops.
I used some larger shock absorber rubbers and stainless bolts that i polished, worked well
