Neils Frankenstein Ute
Re: Neils Frankenstein Ute
It would probably work for wipers, but pricey. New, around $350. The $180 deal on Ozrodders is a bargain.
EK electric wiper motor would be cheaper 😁
Thanks Harv really appreciated and makes sense I just tried to register on Ozrodders and I can't get in; can you provide me with the guys details that is selling the setup you have or if I gave you my details could he contact me?
The person I got the engine from was running it in a VH commodore and said he never had a problem with brakes so maybe it is my booster.
I will get a vacuum guage and measure the vacuum first and take it from there.
Thanks for the replies.
Bugger - he has sold the brake setup. It was only advertised for 12 hours.
Details below:
I have a Summit electric vacuum brake system that I never used. It was for the Vicki, but it turned out my master cylinder was too big, which gave me a hard pedal. I recently removed the electric vacuum brake system from the boot and it now sits on my bar waiting for someone who wants it.
It's this one HERE, if you're interested, and it also comes with an aluminium vacuum tank, but one of the mounting bolts has sheared off. Easy TIG weld job.
Asking $180, includes free postage anywhere in Aus.
Choco Munday, Technical Author, Hot Rod Handbooks
Ph:0412 883 235 or (02) 6255 9810
Hi Harv thanks for that but it would appear that it is no good contacting him now as he has sold it if I understand you correctly. :lol:
Hi Neil
I assume you have tested vacuum at the non return valve and the valve is free and working. Any difference to the brakes with the vacuum disconnected? You’ve probably tried all this.
Clay
Hi Clay
No mate I haven't checked with the line disconnected and what no return valve are you referring to mate call me dumb :crazy: :crazy:
The bit on the end of the vacuum line that plugs in to the booster. This stops the vacuum escaping when no manifold vacuum is being generated. You should be able to blow but not suck air through it.
If things are working and you pull out the line the brakes will instantly become noticeably harder. The revs should increase due to air being sucked in through the valve. Basic check to make sure the booster is actually getting vacuum.
Thanks Clay I will check it out I've also ordered a vacuum gauge from Supercheap so will try to sort it once I get the gauge.
Fitted the door cards yesterday couldn't help myself :roll: the colour was very hard to get an exact match so is the closest the trimmer could get big thanks to Drew "Northside Motor Trimmers" fitted the switches for the electric windows and just to complicate things further for myself I've fitted central locking :crazy:
Borrowed Blacky's template for a parcel shelf and started making one that I had to slightly modify as I was going I'm going to use this to put the engine ECU on.
NoMAD
Post by NoMAD »
trims look sweet mate :thumbsup:
Nathan
Foundation Member
WesternWagon
Post by WesternWagon »
Parcel shelf coming up a treat, will have to borrow the template :shock:
Gazza
Member : Holden Car Club WA.
:ASRF Member
Nice template. Great resource ol Geoffrey.
Fitted carpet to behind the seat just have to trim the edge below the rear screen a fraction overnear the drivers side and there are some loose threads to cut. Unfortunately the little bump in the middle top is where the join of the headlining is but I think I smoothed it out better than that after I took the photo :roll: :roll:
Next to do the 'B' pillar bottoms.
Put the bench seat sides on yesterday and made up a wire for the seat runners
B pillar sides also carpeted
