harvs ek 327 wagon
Re: harvs ek 327 wagon
Stolen from Facebook Image
On a prepped track, a short, sharp burnout is all that is needed to clean the road debris of the tyres and slightly warm them...
'course, muggins here can't help himself, and treats it like a smoke machine until he runs out of room to the start line :oops: :lol:
Harv wrote: Fri Mar 14, 2025 7:35 am On a prepped track, a short, sharp burnout is all that is needed to clean the road debris of the tyres and slightly warm them...
You say that like it's a bad thing :thumbsup: :lol:
BS
Post by BS »
Rippa photo!!
spanners
Post by spanners »
Hey Harv. On the subject of dissy issues, I've used Vintage Racing Developments in Epping to build my electronic dissy for the HAMBster. I haven't touched it in years and it has never let me down. He's a nice bloke to deal with, even coming to WSID a couple of years ago when he knew I was running to check how it was working. Check out his website at what he builds for racers and restorers.
VRD do great work. Dave rebuilt the dizzy in Graces Ute when it was eating rotor buttons, and supplied the o-rings and tapered gear pins when I had that pile of magnetos converted to grey motor. He is good people.
More $&@“ ignition problems. When wringing the motors neck then backing off sharply, it stalls. Not great on the highway, rather embarrassing after a burnout at the drags (don’t ask me how I know). 14.4 second pass. No burnout for the second run (ashamed of my earlier stalling). Thought I had gone around the water box but must have caught some water - spun like crazy off the line, 17 second pass. That’s close to stock grey motor time :(
Erratic pinging under mild load again. Have had enough, and ponied up for an ICE ignition set. Should have followed this advice some time ago, but was too stubborn.
Now have a coolant leak, somewhere on the drivers rear above the starter. Can’t see it with all the steering, headers and booster in the road, so borrowing Number One Son’s borescope. From memory there is a welch plug at the engine mount, and some more in the bellhousing. The bellhousing will be easier to get at… and an excuse for more converter :twisted:
Shed still hasn’t been built (they are digging foundations today, 4 months in), so likely repairs in the open driveway.
Time flies.
Shed done, and wagon went in for some TLC. Forgot how nice it is working inside a shed with everything handy instead of walking up and down the driveway.
Coolant leak turned out to be a head gasket. Easy enough to get the heads off, not so much fun getting them back on again. A rocker cover gasket that refused to seal. Got there in the end.
Fitted the ICE ignition (magic box of sorcery, voltage booster, coil, dizzy and leads). Runs a lot better - no more pinging under initial acceleration, or stalling when backing off. Runs well under "spirited driving".
Some more test runs and some tidy up, but looking good for Day of the Drags next month.
What a saga that MSD ignition turned out to be:
I screwed up making No1 plug lead, it had high resistance so the dizzy would fire THROUGH the rotor plastic and burn it out. At least two tilt tray rides home and replacement rotors, one ride from Mount White.
Had the billet dizzy module crap out, replaced with a CDI box.
Replace coil, though suspect that was overzealous.
Learned that a CDI ignition has enough zoot to jump a 4" gap and throw me on my backside.
Corroded the inside of the billet dizzy, twice, before replacing with a knock-off one.
Had the replacement dizzy module crap out.
Suspect the module is again shagged, giving erratic timing.
There is no doubt I am a slow learner.
Harv,
I have a few friends that used MSD for their ignitions, they have had similar discomfort.
The parts have been made in you know where and failed similar to your story.
I'm not sure if ICE is any better but they have been getting good reviews.
I have had ICE for a couple of years now. No problems at all. Every now and then I consult the chart and dial in a new curve- keeps me off the streets. In recent weeks I moved the coil from the steering box brace, on to a bracket I made to sit above the engine mount. Works just the same. The computer box is sitting on the carpet under the passenger seat. Not very professional, but keeps it out of the engine bay and makes it easy to flick the curve switch. I had to add some length to the wiring loom with no ill effect. If you are not a fiddler, they are set up and forget I think. Oh, and peeps are in Melbourne and very helpful and interested. They are 100% made in Aus I believe.
Managed to get the wagon out to the track last night. Bit of a trial run with the new ICE ignition, though it had been running ok around town. Good shakedown test for Day of the Drags Saturday.
Got three passes in. Was hoping for more, but a blue oval ute dropped coolant the whole length of the track, and a Bavarian taxi lost it off the start line, crossed lanes and love tapped the wall. Lots of down time for cleanup.
First pass was about 14.2, one second slow. Rev limiter kicking in at the top end. I forget where it was set, but I left it wherever ICE had it. Can’t get at the limiter adjuster without a socket, and stupid me did not bring one. Did not fancy fiddling under the dash by braille, especially with the most ignition curve adjuster next to it.
Second pass was better - hit the limiter, threw to third and ran better. Only 1/2 second off where it should be.
Third pass was slower. Anticipated the limiter, threw to third and it slumped off revs.
Had to laugh. Staging lanes had me, a relatively sedate looking naturally aspirated 4-door HQ, and a Porsche GT2RS supercar. I was there for shits and giggles, but the Porsche meant business. It lined up against the HQ, and sent it. Porsche did 10.7… but could not catch the HQ at 10.1.
Show them Porsche wankers mate
There’s the problem… 5900rpm limit. Two-step is not connected, so the 4500rpm limit is inactive.
Some adjustment for more spinny spinny…
Harv wrote: Thu Jun 25, 2026 8:16 am
A bloke over here runs a XW tarmac rally car and on the back window he has a sticker that reads "my other car is a Porsche - but today I am in a hurry " :ebiggrin: :ebiggrin:
i was gunna come down for DOTD but it's gunna be raining again :problem: :thumbsdown:
