Shotgun!Brown Bear wrote:At the going rate It'll be up for a lap around the block at Christmas
Great work Dave and Stew
I've found that a large flat bladed screwdriver (with appropriate protection for the weather strip) dropped down into the gap, then turned (not levered) gently at each of the retaining clips does the trick.parisian62 wrote:Does anyone have the phone number for the bloke who invented those weather strips at the bottom edge of the door window...I'd like to tell him what a pleasure they are to install...![]()
...classic I can hear it now...For all those whines and odd looks like "the window is hard to wind down", "the door didn't shut properly", "I thought you fixed this" etc etc...
Hi Rosco are you talking about the channel the actual door galss sits in or the weatherstrips? If the weatherstrips I'm not sure if that will work as the metal retainers have 'teeth' that lock onto the weatherstrip to stop it moving when the glass is wound up and down.I might try to "bump" off the metal retainer on the next one
