Moderators: reidy , Blacky
Posts: 11650 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Sun Oct 28, 2018 2:20 pm
Finally found good metal
Posts: 1205 Joined: Thu Jan 19, 2017 9:57 am
Post
by ardiesse » Sun Oct 28, 2018 4:15 pm
Clay,
Strewth. Just aft of the idler arm. That's a lot of subframe to cut out. But I see you've already made a jig to suit. I was going to suggest (somewhat tongue-in-cheek) that the ute body was a ready-made jig.
59wagon
Posts: 645 Joined: Sun Jul 27, 2014 11:40 am
Post
by 59wagon » Sun Oct 28, 2018 4:34 pm
I'm rolling my eyes reading this Clay
, as I'm expecting similar challenges as I pull mine apart. Keep up the good work mate.
John
59wagon
Post
by 59wagon » Sun Oct 28, 2018 4:35 pm
John
Post
by Errol62 » Sun Oct 28, 2018 4:40 pm
Best practice would probably be to do it on the car, which is currently three feet in the air. I’m still resisting taking the front x member off at this stage. Bu then again I wasn’t going to take the motor out. Ten bolts later.....
These old mounts are on the piss.
They are 30mm too tall.
Thinking......
Mounts have to come off.
59wagon
Post
by 59wagon » Sun Oct 28, 2018 5:58 pm
Errol62 wrote: Sun Oct 28, 2018 4:40 pm
Clay, I like the patio you've built to keep your spare motors out of the weather
Post
by Errol62 » Sun Oct 28, 2018 7:14 pm
Thanks John
It’s an appreciating assset.
Post
by Errol62 » Sun Oct 28, 2018 8:52 pm
While the donor part is marinating in citric acid I started on the passenger side front dumb iron.
Amazing how much crap is still in there after all the hosing and blasting. I even found some nylon rope fibres around the subframe bolts. The front toe and driver side dumb iron look okay. The passenger side end of the dumb iron needs replacing so might just take it off so I can get access to driver side to clean out.
Post
by Errol62 » Mon Oct 29, 2018 6:48 pm
Replacement inner leg came up very clean
Posts: 1131 Joined: Mon Apr 26, 2010 2:08 pm
Post
by gpi » Mon Oct 29, 2018 8:05 pm
fresh!
Post
by Errol62 » Tue Oct 30, 2018 4:37 pm
How u know I’m getting good penetration is when I start blowing apart good 20 gauge steel.
This is my jig set up.
Post
by Errol62 » Tue Oct 30, 2018 5:19 pm
Me lil crane comes to the rescue again.
Post
by Errol62 » Tue Oct 30, 2018 6:29 pm
As usual plenty grinding to do but pretty solid.
Post
by Errol62 » Tue Oct 30, 2018 11:10 pm
Don’t laugh at my welding. Save it for when I get my paint brush out.
59wagon
Post
by 59wagon » Tue Oct 30, 2018 11:43 pm
You’re still ploughing through the work Clay.
Good stuff
John
