FB wagon
Post by mrs ratbox »
so is it pretty much done then trev
edna that por15 stuff aparently comes out near like sprayed when brushed on
Wag62
Post by Wag62 »
Give yourself a pat on the back Trev.
Its amazing how much patience we have when doing our own cars and so little for anything else,
Well done mate.
Mick T
ratbox wrote:so is it pretty much done then trev
Pretty much Mick, need the back decked out, visors covered, exterior mirrors, stereo and then we'll see when thats done :roll: .
Thanks Mick T, patience maybe, I call it working, having a social life and bringing up 4 kids, then having time to work on the car when I can be bothered :wink: .
I have a question! I have 215/75/14's on the rear with a 3.36 ratio diff, it felt a bit slugish taking off, would it go better with 185/75/14's?
is there much height differance between the 2 tyres ? that or drop to a 3.55 centre i just did this with mine it was sluggish with the 3.36 but is better with the 3.55 and still sits on 100-110 still suffers on hills though
FB MAD
Post by FB MAD »
Trev wrote:
Just kleened up about 12 winding and inside opening handles to get a good set, what shits me is the ones with no pitting or blemishes have stuffed splines and don't work, the not so good ones have good splines :evil: , so I had to use the not so good ones :evil: :evil: :roll: , Trev 8) .
:roll: Now that I know Trev ,at the Nationals '10 I'll be deducting some points from your car for pitted and blemished inside door handles :wink: :wink: :wink: :lol: :lol: :lol:
FB MAD
Post by FB MAD »
With a grey that has a bit of a cam, it's engine torque at lower RPM is down and they can be sluggish off the mark and this is compounded by fitting a "taller" diff than standard .
The original crossplies had a rolling diameter of 24 inches if you need a standard reference point.
A 3.36 is probably about the limit with a grey and especially a worked one with 14 inch rims.
But I'd see how it goes Trev as your engine is new and will need time to bed in as well so after things settle down and it's tuned and running right then it may run a bit better.Although a change to a 3.55 is a quick fix ATM.
If you are running a Traumatic ( can't remember what box your using Trev :oops: :oops: :oops: ) and wanted to stick with the 3.36 then you could try a higher stall convertor as this will allow the engine to get to a higher torque point straight off the mark than a standard convertor and will help with sluggishness.
Thanks for nothing Terry :roll: :lol: , when you see it in the flesh the handles wouldn't be the only thing to stop me getting a trophy :wink: .
I think I'll be changing the tyers rather than the diff ratio, just went to check the oil in it and discovered it's a LSD :shock: .
RB and Terry, from my calculations the 185's would be about 1 inch less height than the 215's, Trev 8) .
Cal
Post by Cal »
Running the car with no exhaust will also rob it of some low end power.
As far as tyre sizes go, try this site.
http://www.miata.net/garage/tirecalc.html
Thanks cal, cool site :D , Trev 8) .
Well done Trev. As for tyres wait till the exhaust is done. You may not need to change. Then again it is a grey, sluggish is normal..... :shock: :lol: :lol:
Thanks DR, yeh the grey might be sluggish but I will chose to call it "cruzie" :lol:
Just took the car to get the exhaust done LOUD :lol: :P .
Here are some updated pics.
And not one of the whole car :roll: , Trev 8) .
thropzed
Post by thropzed »
Thats Sweeet! Trev, I like the chocolate trim with the pyramid paint!!
Cheers Theo Z..........................
FB/EK Car Club of QLD.
FB MAD
Post by FB MAD »
You've done a lot of work there Trev since I last saw it in October.Looking good there 8) 8) 8) .
Stygian
Post by Stygian »
Looks great Trev, really nice :) 8) Pyramid Coral is one of my favourite colours for an FB/EK. Where did you get those seatbelts if I may ask?
