Rebuilding of Old Timer (EK wagon)
yes EKSPCL, i've kinda mentioned that before i think some people myself included would be quite surprised at what some cars would look like once stripped to this stage
from what i was told about the wagon that i have now it was suposed to be an untouched car, but it had been repaired and painted atleast once before
- State: NSW
- Contact:
spot on EKSPCL...here's a couple of extra pics for your viewing pleasure of what paint can hide...
as Ratbox says...untouched FB EKs are nowadays becoming rare breeds...
...these were dug out from the bottom of the A pillar on both sides...I should have been an archaeologist...
after the dry stripping Old Timer was loaded back on the flat bed and a short trip to Custom Body Works for a coat of epoxy primer...
Thomas' reaction was "Hmm not so sure about the colour Dad"...
After seeing the EK in such a bad state I thought the fresh coat of primer made it look a million dollars...
all tucked up back in the garage...the front fenders and subframe were primed a couple of days later...
rebuilding of oldtimer
Hi Stewart,
Good to see some good progress, its the only way to go stripping them back to nothing like that, it uncovers everything.
At least now you know what you got and you can get stuck into it.
Malcolm W.
progress
Hi Stewart,
you know you are doing the right thing - no surprises later on......
I'd be a bit reluctant in posting those first two pix - DMR might want it returned to the point (s) of origin
Keep going, loving this...
Dee
Dee
- State: NSW
- Contact:
thanks everyone. Tony - that quote sounds about right. Spot on Mal - with a rust bucket like this one the stripping really helped show what work had to be done
We've now moved into Jan 2008 when finally some real steel began to be welded back in by Loui...beginning with the right side rear floor pan...
This pic seems fairly ordinary but shows the first bit of welded steel being dressed up...one small step for man one giant leap for the EK...
what we started with
cut out...
cleaned up...
painted...
fitting pan...
welding...
tacked in with some more welding to do...bew-di-ful!!!
cut out...
cleaned up...
painted...
fitting pan...
welding...
Woofto Car Club Member No4
