Project EK
t950cat
Re: Project EK
Post by t950cat »
Hi all i think its about time for an update.As always didnt do much on the car but did alot in buying parts (thanks to my mate who works for rare spares).I have replaced every rubber with new all new suspension parts all new springs and shocks everything powder coated or painted and clear coated.Am in the process of having the block acid dipped and having the head done with stainless valves and will have new rings and a full gasket set.Have just purchased all new brake cylinders and having all new brake and fuel lines made up of the old ones.All seen bolts are stainless and the ones you cant have been cadium plated.
Stand and listen to knowledge turn your back on stupidity.......
Re: Project EK
Nice work t-cat 8)
V8EK4us
Re: Project EK
Post by V8EK4us »
Great work Tony, good to see some progress on the old girl. 8)
bebop67
Re: Project EK
Post by bebop67 »
Looking good mate, a lot of time and $$$$$ there,thats for sure.
Member FB & EK car club of Victoria
Re: Project EK
Looks great, it will be like a new car, good to have someone one the other side of a rare spares counter :D , Trev 8) .
Re: Project EK
All that hard work and dollars you are spending will be well worth it in the long run, will be like a new car to drive. Great work.
vintageholden
Re: Project EK
Post by vintageholden »
looks good
why dint you go hr front....
t950cat
Re: Project EK
Post by t950cat »
Thanx guys the reason for not going for a hr frontend is i want to keep it original.The one change i will be doing is power assiting the front drums but the boster will be hidden inside the front guard.When you say big dollars its not really its money i have saved by stripping the whole car by paintstripper and elbow work and having a mate at his work sandblast all the small bits as door hinges,leafs etc.The change i wanted to do was change the cam gear to alloy but at 350 bucks plus i thought not.Will keep you updated as am working o/t in the shed but giving the beer fridge a flogging... :lol: :lol: :lol:
Tony
Re: Project EK
Get a steel timing gear and you won't have to do it again, Trev 8) .
t950cat
Re: Project EK
Post by t950cat »
Hey Trev
The bloke who did all my welding in the past photos who had one of the best engineering firms done here said you are better off putting an alloy cam gear on.have you heard this? :?: :?: :?: :?:
t950cat
Re: Project EK
Post by t950cat »
hey garry if my build comes up half as good as yours i will be over the moon :o :o :o
Re: Project EK
From the experience of members here,
The alloy one is cast around a steel bush in its center, the steel center can work loose.
The fibre gear will strip teeth eventually, will strip a lot quicker with a high lift cam.
Steel gear is the most reliable in the long run, it will be the last one you will need to fit :wink:
Jeff
Re: Project EK
t950cat wrote:Hey Trev
Thommo wrote:From the experience of members here,
Jeff
:D
bebop67
Re: Project EK
Post by bebop67 »
Totally agree, go for the steel timing gears, i put em in my motor and wont need to worry about it again.
As for paint colour if i were you i would paint the ek in the original colours as it is a reasonably rare colour.
Just a thought,
Cheers.
V8EK4us
Re: Project EK
Post by V8EK4us »
Jeff
I second that Thommo, Reidy fitted the new steel timing gear to Sue "Pearl" before doing the 4500km trip from Darwin to Mildura, she is still being used everyday and racking up another 140kms a week with no problems.....love these old girls :D :D .
